    Duet 3 SBC DCS has stopped
    Beta Firmware
    8
    80
    4.5k
      jay_s_uk @Phaedrux
      @dhusolo
      Did you downgrade the firmware on the duet 3 manually to 3.1.1 before downgrading the software on the Pi?
      The connection between the two was changed significantly at beta 2 and a board running beta 2 or 3 can't connect to a lower version of DSF and vice versa.
      dhusoloundefined 1 Reply Last reply Reply Quote 0
      • dhusoloundefined
        dhusolo @jay_s_uk
        @jay_s_uk I can't remember 100% because I did a few different things in standalone and SBC. I think I used the erase jumpers and powered on the board.
          It would be good if we could get beta 3 on there and see if it's working at all. It sounded like you lost communication between the duet and pi entirely when you tried to update to beta 3. Is that right?
          • dhusoloundefined
            dhusolo @Phaedrux
            @Phaedrux Correct. Just making sure I'm doing it right, Is there a different way to erase the firmware on the board besides the erase jumpers or would even using a different SD card do the trick?
              Well you normally don't need to erase the firmware, but yes the jumper is the way to do that. Once erased you will need to use usb to flash a firmware again.
              A different SD card won't help since the firmware is flashed to the board itself. The firmware bin file on the sd card is just there for storage during in place flashing.
              What version is flashed to the duet right now?
              What version is the Pi running?
              If you're completely back on 3.1.1 right now, are you on the unstable branch for apt-update? How did you originally try to update to the beta?
              • dhusoloundefined
                dhusolo @Phaedrux
                @Phaedrux I think I got it back to 3.1.1.
                What's the command to verify version info including DWS and DWC?
                  From the gcode console send M122 and post the results please.
                  Additionally send M122 "DSF"
                  • dhusoloundefined
                    dhusolo
                    I haven't loaded my config file but I flashed Duet3Firmware_MB6HC.bin through Bossa. It looks like it's communicating with the RPI again.
                    M122
                    m122
                    RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                    Board ID: 08DJM-956L2-G43S8-6J9D0-3S46T-9U2LF
                    Used output buffers: 1 of 40 (10 max)
                    Static ram: 154604
                    Dynamic ram: 161360 of which 20 recycled
                    Exception stack ram used: 236
                    Never used ram: 76996
                    Tasks: NETWORK(ready,1980) HEAT(blocked,1452) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(suspended,252) MAIN(running,5184) IDLE(ready,76)
                    Owned mutexes:
                    Last reset 00:09:59 ago, cause: power up
                    Last software reset at 2020-11-05 20:48, reason: User, spinning module LinuxInterface, available RAM 74612 bytes (slot 3)
                    Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                    Error status: 0
                    MCU temperature: min 15.0, current 25.8, max 25.9
                    Supply voltage: min 0.2, current 0.3, max 0.3, under voltage events: 0, over voltage events: 0, power good: no
                    12V rail voltage: min 0.1, current 0.1, max 0.2, under voltage events: 0
                    Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                    Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                    Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                    Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                    Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                    Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                    Date/time: 2020-11-08 14:26:06
                    Slowest loop: 2.36ms; fastest: 0.13ms
                    === Storage ===
                    Free file entries: 10
                    === MainDDARing ===
                    === AuxDDARing ===
                    Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                    Segments left: 0
                    Movement lock held by null
                    HTTP* is ready with "M122" in state(s) 0
                    Telnet is idle in state(s) 0
                    File is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon* is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 1.03ms; fastest: 0.01ms
                    HTTP sessions: 0 of 8
                    - Ethernet -
                    State: disabled
                    Error counts: 0 0 0 0 0
                    === CAN ===
                    Messages sent 0, longest wait 0ms for type 0
                    === Linux interface ===
                    State: 0, failed transfers: 0
                    Last transfer: 12ms ago
                    RX/TX seq numbers: 19460/19461
                    SPI underruns 0, overruns 0
                    Number of disconnects: 0
                    Buffer RX/TX: 0/0-0
                    === Duet Control Server ===
                    Duet Control Server v3.1.1
                    Code buffer space: 4096
                    Full transfers per second: 5.64
                    M122 DSF
                    m122 DSF
                    Used output buffers: 1 of 40 (12 max)
                    Static ram: 154604
                    Tasks: NETWORK(ready,1980) HEAT(blocked,1452) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(suspended,252) MAIN(running,4512) IDLE(ready,76)
                    Owned mutexes:
                    Last reset 00:12:41 ago, cause: power up
                    Error status: 0
                    MCU temperature: min 25.6, current 25.8, max 26.0
                    Supply voltage: min 0.3, current 0.3, max 0.3, under voltage events: 0, over voltage events: 0, power good: no
                    12V rail voltage: min 0.1, current 0.2, max 0.2, under voltage events: 0
                    Driver 0: ok, reads 0, writes 0 timeouts 0, SG min/max not available
                    Driver 1: ok, reads 0, writes 0 timeouts 0, SG min/max not available
                    Driver 2: ok, reads 0, writes 0 timeouts 0, SG min/max not available
                    Driver 3: ok, reads 0, writes 0 timeouts 0, SG min/max not available
                    Driver 4: ok, reads 0, writes 0 timeouts 0, SG min/max not available
                    Driver 5: ok, reads 0, writes 0 timeouts 0, SG min/max not available
                    Date/time: 2020-11-08 14:28:49
                    Slowest loop: 1.97ms; fastest: 0.13ms
                    === Storage ===
                    === MainDDARing ===
                    === AuxDDARing ===
                    Segments left: 0
                    HTTP* is ready with "M122 D0 S0 F0" in state(s) 0
                    === Network ===
                    - Ethernet -
                    State: disabled
                    === CAN ===
                    RX/TX seq numbers: 24793/24794
                    Buffer RX/TX: 0/0-0
                    Full transfers per second: 32.80
                    Phaedruxundefined 2 Replies Last reply Reply Quote 1
                      Phaedrux Moderator @dhusolo
                      @dhusolo said in Duet 3 SBC DCS has stopped:
                      M122 DSF
                      I think the quotes around DSF are required. I'll admit I haven't used that command yet.
                      • dhusoloundefined
                        dhusolo @Phaedrux
                        @Phaedrux
                        m122 "DSF"
                        Daemon:
                        Finishing macro daemon.g, started by system
                        > Next stack level
                        Full transfers per second: 32.83
                          === Duet Control Server === Duet Control Server v3.1.1
                          Regardless, I think you're on 3.1.1 across the board now.
                          • dhusoloundefined
                            dhusolo
                            but to your earlier question I tried updating to the beta following this and updating the source list to use unstable version
                              Would you be willing to test beta 3 once again?
                              • dhusoloundefined
                                dhusolo
                                Sure. Should I use the getting started link or manually flash? I've tried compiling the firmware myself but with no success which is why I used the instructions in the link
                                  jay_s_uk @dhusolo
                                  @dhusolo that should be all you need to follow to move over to the unstable branch.
                                  There's no need to use the erase button to load the firmware as it will be updated as part of the upgrade process
                                  • dhusoloundefined
                                    dhusolo
                                    I thought i did it correct but I got this error
                                    pi@duet3:~ $ sudo apt-get install duetsoftwareframework
                                    Reading package lists... Done
                                    Building dependency tree
                                    Reading state information... Done
                                    The following additional packages will be installed:
                                      duetcontrolserver duetruntime duetsd duettools duetwebcontrol duetwebserver
                                      reprapfirmware
                                    The following packages will be upgraded:
                                      duetcontrolserver duetruntime duetsd duetsoftwareframework duettools
                                      duetwebcontrol duetwebserver reprapfirmware
                                    8 upgraded, 0 newly installed, 0 to remove and 118 not upgraded.
                                    Need to get 34.0 MB of archives.
                                    After this operation, 0 B of additional disk space will be used.
                                    Do you want to continue? [Y/n] y
                                    Get:1 https://pkg.duet3d.com unstable/armv7 armhf duetsoftwareframework armhf 3.2.0-beta3 [2,034 B]
                                    Get:2 https://pkg.duet3d.com unstable/armv7 armhf duetsd all 1.1.0 [2,102 B]
                                    Get:3 https://pkg.duet3d.com unstable/armv7 armhf duettools armhf 3.2.0-beta3 [62.2 kB]
                                    Get:4 https://pkg.duet3d.com unstable/armv7 armhf duetcontrolserver armhf 3.2.0-beta3 [226 kB]
                                    Get:5 https://pkg.duet3d.com unstable/armv7 armhf duetruntime armhf 3.2.0-beta3 [28.9 MB]
                                    Get:6 https://pkg.duet3d.com unstable/armv7 armhf duetwebserver armhf 3.2.0-beta3 [83.9 kB]
                                    Get:7 https://pkg.duet3d.com unstable/armv7 armhf duetwebcontrol all 3.2.0-beta3 [3,507 kB]
                                    Get:8 https://pkg.duet3d.com unstable/armv7 armhf reprapfirmware all 3.2.0-beta3-1 [1,260 kB]
                                    Fetched 34.0 MB in 19s (1,813 kB/s)
                                    Reading changelogs... Done
                                    (Reading database ... 79179 files and directories currently installed.)
                                    Preparing to unpack .../0-duetsoftwareframework_3.2.0-beta3_armhf.deb ...
                                    Unpacking duetsoftwareframework (3.2.0-beta3) over (3.1.1) ...
                                    Preparing to unpack .../1-duetsd_1.1.0_all.deb ...
                                    Unpacking duetsd (1.1.0) over (1.0.6) ...
                                    Preparing to unpack .../2-duettools_3.2.0-beta3_armhf.deb ...
                                    Unpacking duettools (3.2.0-beta3) over (3.1.1) ...
                                    Preparing to unpack .../3-duetcontrolserver_3.2.0-beta3_armhf.deb ...
                                    Unpacking duetcontrolserver (3.2.0-beta3) over (3.1.1) ...
                                    Preparing to unpack .../4-duetruntime_3.2.0-beta3_armhf.deb ...
                                    Unpacking duetruntime (3.2.0-beta3) over (3.1.1) ...
                                    Preparing to unpack .../5-duetwebserver_3.2.0-beta3_armhf.deb ...
                                    Unpacking duetwebserver (3.2.0-beta3) over (3.1.0) ...
                                    Preparing to unpack .../6-duetwebcontrol_3.2.0-beta3_all.deb ...
                                    Unpacking duetwebcontrol (3.2.0-beta3) over (3.1.1) ...
                                    Preparing to unpack .../7-reprapfirmware_3.2.0-beta3-1_all.deb ...
                                    Unpacking reprapfirmware (3.2.0-beta3-1) over (3.1.1-1) ...
                                    Setting up duetruntime (3.2.0-beta3) ...
                                    Setting up duetcontrolserver (3.2.0-beta3) ...
                                    Installing new version of config file /opt/dsf/conf/config.json ...
                                    Creating group dsf with gid 995.
                                    Creating user dsf (n/a) with uid 995 and gid 995.
                                    Setting up duettools (3.2.0-beta3) ...
                                    Setting up duetwebserver (3.2.0-beta3) ...
                                    Setting up duetsoftwareframework (3.2.0-beta3) ...
                                    To modify config files consider adding yourself to the dsf groupd: # usermod -a -G dsf <username>
                                    Setting up duetwebcontrol (3.2.0-beta3) ...
                                    Setting up duetsd (1.1.0) ...
                                    Setting up reprapfirmware (3.2.0-beta3-1) ...
                                    Sending update request to DCS... Error: Failed to send update request
                                    Unhandled exception. System.Threading.Tasks.TaskCanceledException: A task was canceled.
                                       at DuetAPIClient.BaseConnection.PerformCommand[T](BaseCommand command, CancellationToken cancellationToken) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPIClient/BaseConnection.cs:line 188
                                       at DuetControlServer.Program.CheckForAnotherInstance() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 305
                                       at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 84
                                       at DuetControlServer.Program.<Main>(String[] args)
                                      jay_s_uk @dhusolo
                                      @dhusolo
                                      Are you still able to connect to the board via DWC?
                                      If you can confirm the firmware version using 3.1.1
                                      If it's still 3.1.1, send M997 B0
                                      I would be interested to see if you get any errors reported
                                      • dhusoloundefined
                                        dhusolo @jay_s_uk
                                        @jay_s_uk
                                        I had to start DCS and DWS manually but I was able to get to the web interface.
                                        M122 "DSF"
                                        Duet Control Server v3.2.0-beta3
                                        Full transfers per second: 32.68
                                        11/8/2020, 2:58:59 PM```
                                        M122
                                        RepRapFirmware for Duet 3 MB6HC version 3.2-beta3 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                        Static ram: 122124
                                        Dynamic ram: 137508 of which 0 recycled
                                        Never used RAM 132560, free system stack 185 words
                                        Tasks: Linux(ready,131) HEAT(blocked,362) CanReceiv(blocked,948) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,66) MAIN(running,1300) IDLE(ready,19)
                                        Owned mutexes: HTTP(MAIN)
                                        Last reset 00:09:17 ago, cause: software
                                        Last software reset details not available
                                        Error status: 0x00
                                        MCU temperature: min 25.3, current 26.2, max 26.4
                                        Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                        Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                        Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                        Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                        Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                        Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
                                        Date/time: 2020-11-08 14:58:59
                                        Slowest loop: 743.08ms; fastest: 0.16ms
                                        === Storage ===
                                        === MainDDARing ===
                                        Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                        === AuxDDARing ===
                                        Segments left: 0
                                        Daemon is idle in state(s) 0
                                        === CAN ===
                                        Messages sent 0, send timeouts 0, longest wait 0ms for type 0, free CAN buffers 47
                                        === SBC interface ===
                                        State: 0, failed transfers: 1
                                        Last transfer: 14ms ago
                                        RX/TX seq numbers: 17902/17903
                                        Number of disconnects: 0, IAP RAM available 0x20aa0
                                        Buffer RX/TX: 0/0-0
                                        Full transfers per second: 32.56
                                          jay_s_uk @dhusolo
                                          @dhusolo well at least you're back on the latest firmware.
                                          @chrishamm any comments on the error above whilst updating?
                                          • dhusoloundefined
                                            dhusolo
                                            More of a status update: I've started the same print again but I don't load any filament. I didn't want to waste the filament if it's going to cancel on me again.
                                            However I can now hear some strange jerky movements. I have a coreXY so it's hard to narrow down what stepper it's coming from especially since there's no filament going through it.
