    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.3k
    • shattyundefined
      shatty @Veti
      @Veti Hows this?
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
      M550 P"E5Plus" ; set printer name
      M551 P"xxxxx" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S0 ; physical drive 2 goes backwards
      M92 X80.00 Y80.00 Z400.00 E412.60 ; set steps per mm
      M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X350 Y350 Z400 S0 ; set axis maxima
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
      M557 X15:190 Y15:190 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 0 as thermistor on pin bedtemp
      M143 H0 S110 ; set temperature limit for heater 0 to 110C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 1 as thermistor on pin e0temp
      M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
      I dont see where the Heater for the hot end should max at 280. Also there are 2 fans on the hot end. Shouldnt the values be identical? I got a lot of the fixes from someones 5 Pro config
        Phaedrux Moderator @shatty
        @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
        Add M143 H1 S280 at the end of the heater block under the M307.
        Otherwise I don't see any obvious issues.
        You can send M98 P"config.g" in the console to see if there are any syntax errors.
        Otherwise it's time to do some testing.
        • Vetiundefined
          Veti
          as i posted earlier the Z steps according to marlin are Z800
          delete the C4700 thats not the resistance. you can leave R empty and the correct default is choosen.
          • shattyundefined
            shatty
            @Phaedrux said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
            M143 H1 S280
            OK so I edited and turned on.
            Seems ok. Temps are hovering at 22 deg C with heaters off.
            Motors are F'ed up. Z looks good. Its the X and Y. I got some error codes.
            11/16/2020, 1:18:45 AM M122
            RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
            Board ID: 08DLM-996RU-N8PS0-6J1DJ-3SD6K-KSSHN
            Used output buffers: 3 of 24 (11 max)
            Static ram: 27980
            Dynamic ram: 93672 of which 44 recycled
            Exception stack ram used: 264
            Never used ram: 9112
            Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:04:52 ago, cause: software
            Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8240 bytes (slot 1)
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
            Error status: 0
            MCU temperature: min 24.7, current 25.6, max 26.1
            Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
            Date/time: 2020-11-16 01:18:41
            Cache data hit count 507426640
            Slowest loop: 6.91ms; fastest: 0.12ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 3.8ms, write time 0.0ms, max retries 0
            Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
            === MainDDARing ===
            Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 15.88ms; fastest: 0.00ms
            Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is active
              WiFi firmware version 1.23
              WiFi MAC address f4:cf:a2:66:99:4f
              WiFi Vcc 3.38, reset reason Unknown
              WiFi flash size 4194304, free heap 23640
              WiFi IP address 192.168.2.8
              WiFi signal strength -43dBm, reconnections 0, sleep mode modem
              11/16/2020, 1:17:30 AM M120 G91 G1 X-1 F6000 G90 M121
              Error: G0/G1: insufficient axes homed
              11/16/2020, 1:14:17 AM Connection established
              11/16/2020, 1:13:42 AM Connection interrupted, attempting to reconnect...
              11/16/2020, 1:13:32 AM Emergency Stop! Reset the controller to continue.
              11/16/2020, 1:13:32 AM Emergency stop, attemping to reconnect...
              11/16/2020, 1:13:31 AM Warning: motor phase B may be disconnected reported by driver(s) 2
              11/16/2020, 1:13:26 AM Warning: motor phase B may be disconnected reported by driver(s) 2
              11/16/2020, 1:13:22 AM Warning: motor phase B may be disconnected reported by driver(s) 2
              11/16/2020, 1:13:17 AM Warning: motor phase B may be disconnected reported by driver(s) 0 1 2
              11/16/2020, 1:13:16 AM Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
              11/16/2020, 1:13:07 AM Connection established
              11/16/2020, 1:12:52 AM Connection interrupted, attempting to reconnect...
              HTTP request timed out
              11/16/2020, 1:12:40 AM Upload of config.g successful after 0s
              11/16/2020, 1:07:50 AM Connected to 192.168.2.8
            Vetiundefined 2 Replies Last reply Reply Quote 0
            • shattyundefined
              shatty
              M92 X80.00 Y80.00 Z800.00 E412.60 ; set steps per mm
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
              M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
              M143 H1 S280 ; 280 deg max on hot end
              • shattyundefined
                shatty
                M98 P"config.g"
                11/16/2020, 1:23:54 AM M98 P"config.g"
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                I have that little daughter board connected for the bed heat. Looks like a relay board. Bed heat output on D3D connects to smaller board. Looks like the bed heat output triggers that smaller board. But if you think I should connect the bed straight to bed out on D3D I will
                • Vetiundefined
                  Veti @shatty
                  this indicates that your wiring of the phases are incorrect.
                  see
                  https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors
                  shattyundefined 2 Replies Last reply Reply Quote 0
                  • shattyundefined
                    shatty @Veti
                    @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                    see
                    I triple checked them. I compared from the stock board to the D3D. I will check again
                    • shattyundefined
                      shatty @Veti
                      @Veti
                      so just Extruder,x and y? And just the B phase?
                        As it's only one phase of each driver that's reported as disconnected, a likely cause is a bad crimp connection.
                        • Vetiundefined
                          Veti @shatty
                          @shatty
                          M584 X0 Y1 Z2
                          x y z, presumably you have not moved the extruder.
                          the stock board config does not matter, as each board has different layouts.
                          did you follow the guide to find the phases of the motors?
                          shattyundefined 1 Reply Last reply Reply Quote 0
                          • shattyundefined
                            shatty @Veti
                            @Veti The stock board has the terminals labeled for the ab and 12. I compared them to D3D and it was good.
                            shattyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                            • shattyundefined
                              shatty @shatty
                              @shatty Motors are 6 pin. The 2 inner and 2 outer are used. Dunno if that matters
                              • Vetiundefined
                                Veti @shatty
                                @shatty
                                thats normal
                                • shattyundefined
                                  shatty @Veti
                                  This post is deleted!
                                    dc42 administrators @shatty
                                    If you used the same wiring order for the stepper motor connectors on the Duet as they were on the old board, then it should be correct. All boards that I know of put the wires for one phase at one end of the connector, and the other phase at the other end.
                                    If you did have the phases incorrectly wired, the error messages would be different.
                                    So IMO the most likely cause is a bad crimp connection. I suggest you use a multimeter to measure the resistance of each phase from the connector on the Duet.
                                    • shattyundefined
                                      shatty @dc42
                                      OK what about homing? It keeps trying to go past the limits. Every direction. Where do i move manually the axis?
                                      • shattyundefined
                                        shatty
                                        I havent received any errors for the phases lately
                                        • shattyundefined
                                          shatty
                                          M98 P"0:/macros/01-Test_IR_PD_Homing"
                                          Error: in file macro line 12 column 30: M906: array too long, max length = 1
                                          • shattyundefined
                                            shatty
                                            The endstops are not telling the unit to stop moving. It hits the endstop switch and it still tries to move in that direction. But the endstops are functioning because I went to settings and machine specific and when i press them, the value changes
