    Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
    7.4k
    • Vetiundefined
      Veti @shatty
      @shatty
      which part did you not understand? please be specific, then we can further elaborate.
      None of these values will autopopulate after I turn it on and auto homes itself and tests itself out?
      no.
      shattyundefined 1 Reply Last reply Reply Quote 0
        A Former User @shatty
        @shatty
        Did you ever learn how to ride a bicycle?
        If so do you remember the leap of faith you had to make without the safety net of training wheels?
        Follow the steps to get the printer running, check your wiring multiple times, and trust yourself and take the leap, and flip the switch.
        shattyundefined 1 Reply Last reply Reply Quote 2
        • shattyundefined
          shatty @A Former User
          @CaLviNx said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
          @shatty
          LOL. I didnt think it would be this complicated before I installed it. I thought it would be a quick swap. Anyways theres no turning back now.
          • shattyundefined
            shatty @Veti
            @Veti Hows this?
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time)
            M550 P"E5Plus" ; set printer name
            M551 P"xxxxx" ; set password
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P2 S0 ; physical drive 2 goes backwards
            M92 X80.00 Y80.00 Z400.00 E412.60 ; set steps per mm
            M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X350 Y350 Z400 S0 ; set axis maxima
            M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
            G31 P500 X16.3 Y14 Z1.7 ; set Z probe trigger value, offset and trigger height
            M557 X15:190 Y15:190 S20 ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 0 as thermistor on pin bedtemp
            M143 H0 S110 ; set temperature limit for heater 0 to 110C
            M308 S1 P"e0temp" Y"thermistor" T100000 B4092 C4700 ; configure sensor 1 as thermistor on pin e0temp
            M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
            I dont see where the Heater for the hot end should max at 280. Also there are 2 fans on the hot end. Shouldnt the values be identical? I got a lot of the fixes from someones 5 Pro config
              Phaedrux Moderator @shatty
              @shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
              Add M143 H1 S280 at the end of the heater block under the M307.
              Otherwise I don't see any obvious issues.
              You can send M98 P"config.g" in the console to see if there are any syntax errors.
              Otherwise it's time to do some testing.
              • Vetiundefined
                Veti
                as i posted earlier the Z steps according to marlin are Z800
                delete the C4700 thats not the resistance. you can leave R empty and the correct default is choosen.
                • shattyundefined
                  shatty
                  @Phaedrux said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                  M143 H1 S280
                  OK so I edited and turned on.
                  Seems ok. Temps are hovering at 22 deg C with heaters off.
                  Motors are F'ed up. Z looks good. Its the X and Y. I got some error codes.
                  11/16/2020, 1:18:45 AM M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                  Board ID: 08DLM-996RU-N8PS0-6J1DJ-3SD6K-KSSHN
                  Used output buffers: 3 of 24 (11 max)
                  Static ram: 27980
                  Dynamic ram: 93672 of which 44 recycled
                  Exception stack ram used: 264
                  Never used ram: 9112
                  Tasks: NETWORK(ready,384) HEAT(blocked,1224) MAIN(running,1880) IDLE(ready,80)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:04:52 ago, cause: software
                  Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8240 bytes (slot 1)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                  Error status: 0
                  MCU temperature: min 24.7, current 25.6, max 26.1
                  Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                  Date/time: 2020-11-16 01:18:41
                  Cache data hit count 507426640
                  Slowest loop: 6.91ms; fastest: 0.12ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 3.8ms, write time 0.0ms, max retries 0
                  Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                  === MainDDARing ===
                  Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 15.88ms; fastest: 0.00ms
                  Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                  HTTP sessions: 1 of 8
                  • WiFi -
                    Network state is active
                    WiFi firmware version 1.23
                    WiFi MAC address f4:cf:a2:66:99:4f
                    WiFi Vcc 3.38, reset reason Unknown
                    WiFi flash size 4194304, free heap 23640
                    WiFi IP address 192.168.2.8
                    WiFi signal strength -43dBm, reconnections 0, sleep mode modem
                    11/16/2020, 1:17:30 AM M120 G91 G1 X-1 F6000 G90 M121
                    Error: G0/G1: insufficient axes homed
                    11/16/2020, 1:14:17 AM Connection established
                    11/16/2020, 1:13:42 AM Connection interrupted, attempting to reconnect...
                    11/16/2020, 1:13:32 AM Emergency Stop! Reset the controller to continue.
                    11/16/2020, 1:13:32 AM Emergency stop, attemping to reconnect...
                    11/16/2020, 1:13:31 AM Warning: motor phase B may be disconnected reported by driver(s) 2
                    11/16/2020, 1:13:26 AM Warning: motor phase B may be disconnected reported by driver(s) 2
                    11/16/2020, 1:13:22 AM Warning: motor phase B may be disconnected reported by driver(s) 2
                    11/16/2020, 1:13:17 AM Warning: motor phase B may be disconnected reported by driver(s) 0 1 2
                    11/16/2020, 1:13:16 AM Warning: Obsolete use of S parameter on G1 command. Use H parameter instead.
                    11/16/2020, 1:13:07 AM Connection established
                    11/16/2020, 1:12:52 AM Connection interrupted, attempting to reconnect...
                    HTTP request timed out
                    11/16/2020, 1:12:40 AM Upload of config.g successful after 0s
                    11/16/2020, 1:07:50 AM Connected to 192.168.2.8
                  Vetiundefined 2 Replies Last reply Reply Quote 0
                  • shattyundefined
                    shatty
                    M92 X80.00 Y80.00 Z800.00 E412.60 ; set steps per mm
                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
                    M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
                    M143 H1 S280 ; 280 deg max on hot end
                    • shattyundefined
                      shatty
                      M98 P"config.g"
                      11/16/2020, 1:23:54 AM M98 P"config.g"
                      HTTP is enabled on port 80
                      FTP is disabled
                      TELNET is disabled
                      Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                      I have that little daughter board connected for the bed heat. Looks like a relay board. Bed heat output on D3D connects to smaller board. Looks like the bed heat output triggers that smaller board. But if you think I should connect the bed straight to bed out on D3D I will
                      • Vetiundefined
                        Veti @shatty
                        this indicates that your wiring of the phases are incorrect.
                        see
                        https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Connecting_stepper_motors
                        shattyundefined 2 Replies Last reply Reply Quote 0
                        • shattyundefined
                          shatty @Veti
                          @Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
                          see
                          I triple checked them. I compared from the stock board to the D3D. I will check again
                          • shattyundefined
                            shatty @Veti
                            @Veti
                            so just Extruder,x and y? And just the B phase?
                              As it's only one phase of each driver that's reported as disconnected, a likely cause is a bad crimp connection.
                              • Vetiundefined
                                Veti @shatty
                                @shatty
                                M584 X0 Y1 Z2
                                x y z, presumably you have not moved the extruder.
                                the stock board config does not matter, as each board has different layouts.
                                did you follow the guide to find the phases of the motors?
                                • shattyundefined
                                  shatty @Veti
                                  @Veti The stock board has the terminals labeled for the ab and 12. I compared them to D3D and it was good.
                                  shattyundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                  • shattyundefined
                                    shatty @shatty
                                    @shatty Motors are 6 pin. The 2 inner and 2 outer are used. Dunno if that matters
                                    • Vetiundefined
                                      Veti @shatty
                                      @shatty
                                      thats normal
                                      • shattyundefined
                                        shatty @Veti
                                        This post is deleted!
                                          dc42 administrators @shatty
                                          If you used the same wiring order for the stepper motor connectors on the Duet as they were on the old board, then it should be correct. All boards that I know of put the wires for one phase at one end of the connector, and the other phase at the other end.
                                          If you did have the phases incorrectly wired, the error messages would be different.
                                          So IMO the most likely cause is a bad crimp connection. I suggest you use a multimeter to measure the resistance of each phase from the connector on the Duet.
                                          • shattyundefined
                                            shatty @dc42
                                            OK what about homing? It keeps trying to go past the limits. Every direction. Where do i move manually the axis?
