    D-Bot/CrusaXY mash up (CoreXY iDEX)
    My Duet controlled machine
    8
    40
    2.7k
    • Vetiundefined
      Veti
      a duet 3 toolboard would be a good fit for that setup i think
      Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @Veti
        @Veti
        It would but for the cost of the PCB's and connectors this is far far cheaper and simpler to setup.
        I'm thinking about adding an extra stepper motor for dual Z motor control, that would be via a duet expansion board.
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        • Vetiundefined
          Veti @Rushmere3D
          @Rushmere3D said in D-Bot/CrusaXY mash up (CoreXY iDEX):
          thats twice the price of a Duet 3 Toolboard 1LC (which contains 1 stepper driver)
            Rushmere3D @Veti
            @Veti
            I can use a Tool board for a Z stepper driver?
            • Vetiundefined
              Veti @Rushmere3D
              @Rushmere3D
              you could, but it makes more sense to drive the stepper motor on the extruder with it and free up the driver on the duet 3 board for the second z
                Rushmere3D @Veti
                @Veti
                Oh right I see now, yeah that's a good idea. Thanks I'll consider it.
                • Vetiundefined
                  Veti
                  it has the same mounting option as your board.
                  https://www.duet3d.com/Duet3Toolboard1LC
                  and you only need 4 wires.
                  2 wires for data and 2 for power.
                    Good to see a dbot get some love.
                      Rushmere3D
                      First few prints off the printer.
                      • matt3oundefined
                        matt3o
                        great work. you guys are all better than me at producing great printers 👅
                          Rushmere3D
                          Hey all,
                          Thought I'd post some more pictures of the extruder setup I'm currently using, just to have a complete record on this thread.
                          First up in the PINDA probe mount
                          And here the magnetic extruder mounts
                          And a better view of the extruder board, this is the second tool, so the bed leveling headers aren't soldered in
                            T3P3Tony administrators
                            Nice work @Rushmere3D I will move this post to the "may duet controlled machine" category so its easier to find for people wanting to do something similar.
                              Rushmere3D @T3P3Tony
                              @T3P3Tony
                              Thank you, it wasn't until after I made the thread I realised there was a better category but couldn't change it myself?
                                Rushmere3D
                                Hi all,
                                So I'm finally getting around to adding the second extruder to my iDEX printer and I was wondering if someone knowledgeable would be kind enough to take a look at my config I've made? I'm waiting on a few connectors and tool so the printer isn't currently moving so I've take a guess on some of the offsets but some advice with that would also be appreciated but it's more the setup and naming of things I'm unsure of.
                                Edit to remove config files, as I'm making changes to my config. Will request help again soon 😜
                                Thanks in advance, James.
                                  Rushmere3D
                                  Quick question, am I right in thinking if I want to run two Toolboards on a duet3 I also need a Distribution Board?
                                  Thanks,
                                  J.
                                  jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                    Rushmere3D
                                    Another question while I think of it. Can you modify macros on the paneldue?
                                      Rushmere3D
                                      Anyone able to answer my two questions?
                                        jay_s_uk @Rushmere3D
                                        @Rushmere3D
                                        Thanks,
                                        J.
                                        Yes, you'll need a distribution board
                                        no, you can't
                                        Rushmere3Dundefined 1 Reply Last reply Reply Quote 1
                                          Rushmere3D @jay_s_uk
                                          @jay_s_uk
                                          Thank you.
                                            Rushmere3D
                                            Hi all,
                                            OK a bit of progress, the printer now has the second tool fitting and everything is wired up including now physical end stops rather than sensor-less.
                                            Here a picture of it right now:
                                            Thanks,
                                            James.
