    D-Bot/CrusaXY mash up (CoreXY iDEX)
    My Duet controlled machine
    8
    40
    2.6k
    • matt3oundefined
      matt3o
      great work. you guys are all better than me at producing great printers 👅
      • Rushmere3Dundefined
        Rushmere3D
        Hey all,
        Thought I'd post some more pictures of the extruder setup I'm currently using, just to have a complete record on this thread.
        First up in the PINDA probe mount
        And here the magnetic extruder mounts
        And a better view of the extruder board, this is the second tool, so the bed leveling headers aren't soldered in
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
          T3P3Tony administrators
          Nice work @Rushmere3D I will move this post to the "may duet controlled machine" category so its easier to find for people wanting to do something similar.
          Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
            Rushmere3D @T3P3Tony
            @T3P3Tony
            Thank you, it wasn't until after I made the thread I realised there was a better category but couldn't change it myself?
              Rushmere3D
              Hi all,
              So I'm finally getting around to adding the second extruder to my iDEX printer and I was wondering if someone knowledgeable would be kind enough to take a look at my config I've made? I'm waiting on a few connectors and tool so the printer isn't currently moving so I've take a guess on some of the offsets but some advice with that would also be appreciated but it's more the setup and naming of things I'm unsure of.
              Edit to remove config files, as I'm making changes to my config. Will request help again soon 😜
              Thanks in advance, James.
                Rushmere3D
                Quick question, am I right in thinking if I want to run two Toolboards on a duet3 I also need a Distribution Board?
                Thanks,
                J.
                jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
                  Rushmere3D
                  Another question while I think of it. Can you modify macros on the paneldue?
                    Rushmere3D
                    Anyone able to answer my two questions?
                      jay_s_uk @Rushmere3D
                      @Rushmere3D
                      @Rushmere3D said in D-Bot/CrusaXY mash up (CoreXY iDEX):
                      Thanks,
                      J.
                      Yes, you'll need a distribution board
                      no, you can't
                      Rushmere3Dundefined 1 Reply Last reply Reply Quote 1
                        Rushmere3D @jay_s_uk
                        @jay_s_uk
                        Thank you.
                          Rushmere3D
                          Hi all,
                          OK a bit of progress, the printer now has the second tool fitting and everything is wired up including now physical end stops rather than sensor-less.
                          Here a picture of it right now:
                          Thanks,
                          James.
                            Rushmere3D
                            Right so, I've been playing until someone can offer assistants.
                            I've got the printer to home each axis (via Home X, Y, U button) I added this line to the config.g under the M584 line.
                            M669 X1:1:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1
                            However homing Z cause issues, the U axis is told to home which is does but then when X and Y move to 0,0 it;s trying to also move U but just skips steps because it is up to it's end stop. Any suggestions?
                            Thanks,
                            James.
                              dc42 administrators @Rushmere3D
                              Thanks,
                              J.
                              It's not essential, but it makes the wiring simpler and provides fused power for each tool distribution board.
                                Please post a diagram that shows how the U carriage is controlled by the belts and motors.
                                  Rushmere3D @dc42
                                  Does this help.
                                    Rushmere3D
                                    Here's some actual printer pictures.
                                    IMG_20210206_145348.jpg IMG_20210206_145354.jpg IMG_20210206_145403.jpg IMG_20210206_145421.jpg
                                    • hackinistratorundefined
                                      hackinistrator
                                      if i'm not mistaken , if you want your bed center to be 0,0 then your y minima and maxima should not be 0 and 270 .
                                        Rushmere3D @hackinistrator
                                        @hackinistrator Yep, sorry already changed that. I'll update the code.
                                          hackinistrator
                                          also in homez and homeall you move x absolute position to 150 , which is not the center of the bed , this is the edge , right ?
                                            @hackinistrator Also already changed sorry, lol. I posted the configs and then was messing around trying to work it out myself.
                                            The issue right now, is the move to 0,0 with homing Z. It continues to try and move U past the end stop.
                                            Also during the Y home, it shifts the X and U axis by 2.5mm and that is reflected in the coordinates.
                                            Also the Y home doesn't do the double home move.
