    3D GCode Viewer integrated with DWC
    Duet Web Control wishlist
    42
    284
    29.8k
    • buttonundefined
      button @A Former User
      I'm really impressed. Will test when 3.2 be official release.
      With things like that duet ecosystem winnings!!
        Phaedrux Moderator @A Former User
        @CaLviNx said in 3D GCode Viewer integrated with DWC:
        Seeing as we are now off on a tangent, what would be really useful is if there was a way to
        have a camera integrated into the "cancel object" software/plugin or what ever you want to call, that could monitor when a segment has failed and automatically modify the g-code on the fly to stop the printer from extruding plastic for that segment.
        You may not like this, but there's also an octoprint plugin that does this. And yes it could become a plugin here as well.
        https://www.thespaghettidetective.com/
        The object cancelation functions already right now so that if you had a camera and you yourself saw an object fail, you could send the manual command to cancel that object.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M486_Object_cancellation
        The gcode viewer functionality could enable a useful GUI for many features.
        A Former User? 1 Reply Last reply Reply Quote 2
        • Sindariusundefined
          Sindarius
          https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases/tag/0.6.5
          Posted a new update. Cleaned up the side menu a bit.
          5fc99fd3-4706-40c9-96b6-841002959809-image.png https://user-images.githubusercontent.com/12520045/99151632-3acb8900-2662-11eb-920a-216d9a346b23.png
            A Former User @Phaedrux
            @Phaedrux said in 3D GCode Viewer integrated with DWC:
            Why would I not like it?
            And I reiterate, it would be useful if :
            that plugin could monitor when a segment has failed and automatically modify the g-code on the fly to stop the printer from extruding plastic for that segment.
            And still this does not explain the reason why someone would even mention a feature that occurs in octoprint, and what relationship that feature has to do with the Author's gcode viewer,
              Because he posted a photo showing a canceled object. (The one with the Xs over it) and you asked what the real world use was and veti told you what the use of cancelling an object is and posted a link to the origin of the feature in the form of the octoprint plugin. For such a big brain I'm surprised you're not following along here.
                A Former User @Sindarius
                @Sindarius said in 3D GCode Viewer integrated with DWC:
                Hey I clicked on your link, could you help me where to find in the forum or duet-wiki a reference how to implement this plugin? 🤓
                jay_s_ukundefined Sindariusundefined 2 Replies Last reply Reply Quote 0
                  jay_s_uk @A Former User
                  @LB upload the zip file via the systems tab.
                  There will be a pop up asking if you want to install the plugin.
                  It can then be activated under the plugins tab on the machine specific settings tab
                    Sindarius @A Former User
                    @LB I just posted a 0.7.0 with async loading 🙂 Download the zip from the release page and with the latest DWC 3.2 beta you can simply go to the system tab and upload the file to install the plugin.
                    @jay_s_uk beat me to it 🙂
                    • Thaliosundefined
                      Thalios
                      weird bug, it seems the bed rendered is too small. (see pic)
                      any idea?
                      same on safari and firefox. Mac os big sur.
                      Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                      Heavily modified Ender 3 Pro (Duet 3 6HC)
                      Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                      CR-10S Pro V2 (Duet 3 Mini 5+)
                      and a bunch of SLA printers..
                      Sindariusundefined 1 Reply Last reply Reply Quote 0
                        Sindarius @Thalios
                        @Thalios I have not yet implemented reading the axis limit so the bed size is fixed @ 235,235 at the moment.
                        • Thaliosundefined
                          Thalios
                          I understand! I like it still! 🙂
                            Sindarius @Thalios
                            @Thalios It's one of the next items on my list. I need to start refactoring some of the structure out into their own classes. Bed is one of my first ones. I plan to hopefully support bed texturing soon-ish and I have had requests to show a volume cube as well. So this will be a part of that. Glad you like 👍
                              Sindarius
                              @Thalios Give 0.7.6 a shot. I have reworked a chunk of the bed logic so it should pick up the axes limits from the object model now.
                              https://github.com/Sindarius/DWC_GCodeViewer_Plugin/releases/tag/0.7.6
                              Also added build volume. It's a little odd for deltas but it you look top down it works well enough for now.
                              JoergS5undefined 1 Reply Last reply Reply Quote 3
                              • JoergS5undefined
                                JoergS5 @Sindarius
                                @Sindarius your print area would be useful for other kinematics like scara, polar ... also.
                                • Thaliosundefined
                                  Thalios
                                  works perfectly so far!
                                    Sindarius
                                    Implemented billboarded labels over each of the objects. Can be toggled on and off.
                                    • OwenDundefined
                                      OwenD
                                      Should this be working with RRF 3.2b3?
                                      I got an error saying the plugin couldn't be installed because DWC version wasn't correct
                                        Sindarius @OwenD
                                        @OwenD this depends on DWC 3.2 beta 3 which I do not believe is released at this point. You have to pull it down and build it then install it.
                                        OwenDundefined 1 Reply Last reply Reply Quote 0
                                        • OwenDundefined
                                          OwenD @Sindarius
                                          @Sindarius
                                          This is the bundle I used.
                                          https://forum.duet3d.com/topic/19623/firmware-bundle-3-2beta3-now-available
                                          Bugger,
                                          Just noticed there's a DWC package further down the list.... I thought it was all in teh bundle.
                                          Will try that tonight.
                                          • Thaliosundefined
                                            Thalios
                                            Make sure you update the DWC to 3.2b3 as well or it won't work. Not just the firmware.
