    Duet 2 inconsistent extrusions at slow speeds
    1.4k
    • natty15dundefined
      natty15d
      I've just converted my Eniac40 Corexy printer, its a direct drive & using all the same parts, from a ramps board to the Duet2 wifi, but my print quality is terrible just now.
      I use simplify3d 4.1.2 and have been printing a 20mm single wall cube so i can start to calibrate the printer.
      I have, as standard, a speed override set up for layers below 15 secs, allowing a speed reduction down to 20%.
      When i use this setting i get an inconsistent extrusion, i can see it leaving gaps of approx 3mm at 2 different points per layer. The extruder doesn't seem to be skipping & isnt making any clicking noises.
      When i switch off the speed override, so it prints at full speed, there are no extrusion issues.
      Have I messed up a setting that is causing the extruder to perform poorly at slow extrusion speeds?
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Nov 04 2020 17:51:25 GMT+0000 (Greenwich Mean Time)
      M550 P"Eniac40" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P2 S0 ; physical drive 2 goes backwards
      M350 Z16 E16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 I1 ; configure microstepping with interpolation
      M92 X80.24 Y80.24 Z398.00 E412.00 ; set steps per mm
      M566 X480.00 Y480.00 Z18.00 E480.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X15000.00 Y15000.00 Z720.00 E1800.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X1700 Y1700 Z1700 E680 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X390 Y425 Z405 S0 ; set axis maxima
      M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
      M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
      M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
      M558 P0 H2 F120 T15000 ; disable Z probe but set dive height, probe speed and travel speed
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 A84.5 C94.6 D0.7 S1.00 V11.9 B0 ; PID heated bed
      M143 H0 S80 ; set temperature limit for heater 0 to 80C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M307 H1 A298.1 C175.7 D3.8 S1.00 V11.8 B0 ; PID hotend heater
      M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1 T180 ; set fan 2 value. Thermostatic control is turned on
      T0 ; select first tool
      20mmbox test.gcode 20mmbox test slow.gcode
      slow speed on the left, regular speed on the right, gives a consistent 0.65mm line width using a 0.6mm nozzle
        Perhaps at such a slow speed the plastic is cooking and bubbling?
        natty15dundefined 1 Reply Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt
          I use S3D and run my first layer at 15mm/s. I have both Mosquito and Dragon hot ends. They both works fine at those slow speed.
          Something in your hardware perhaps?
          Try enabling interpolation for all axes.
          natty15dundefined 1 Reply Last reply Reply Quote 1
          • Vetiundefined
            Veti @natty15d
            @natty15d said in Duet 2 inconsistent extrusions at slow speeds:
            B4725 C7.06e-8
            how sure are you that this is correct for your thermistor? is it a genuine e3d hotend?
            • natty15dundefined
              natty15d @Phaedrux
              @Phaedrux Its the same hardware i've been using for the last 6 months with no issues using the same settings
              • natty15dundefined
                natty15d @fcwilt
                @fcwilt just changed the settings to
                still has the same issue 😞
                • natty15dundefined
                  natty15d @Veti
                  @Veti It's not a genuine E3d hotend, its a Trianglelabs clone with a 104GT-2 Thermistor Cartridge and Heater Cartridge 12V 40W 6mmx20mm
                  • natty15dundefined
                    natty15d
                    The extruder stepper motor is a Nema 17 Bipolar Stepper 1.8deg 0.8A 120mN.m 42x42x22mm Nema17 Titan Pancake
                    And the new settings are
                    • fcwiltundefined
                      fcwilt @natty15d
                      Hmm..
                      Are you by chance using a different brand or kind of filament?
                      • Vetiundefined
                        Veti
                        just to rule out slicer, can you do this test with a different slicer?
                          Firmware version 3.1.1?
                          Have you PID tuned the hotend recently? Is your temp graph stable?
                          The gcode is basically identical other than the feed rate, but trying another slicer couldn't hurt for confirmation.
                          • natty15dundefined
                            natty15d @fcwilt
                            @fcwilt I'm using the filament I was using before installing the duet
                            • fcwiltundefined
                              fcwilt @natty15d
                              Hmm...
                              Have you verified that the steps/mm setting for the extruder is correct?
                              • natty15dundefined
                                natty15d @Phaedrux
                                @Phaedrux PID tuned last week and very stable temps.
                                I've been 3d printing for years but I've only ever used simplify3d, are there any other slicers you'd recommend
                                Recalibrated my wanhao i3 last week with the same slicer and didn't have any issues
                                • natty15dundefined
                                  natty15d @fcwilt
                                  @fcwilt double checked that, 100mm is extruded
                                  • natty15dundefined
                                    natty15d
                                    i also changed to "relative extrusion distances" in simplify3d for the Duet, never needed that for the wanhao i3
                                    • fcwiltundefined
                                      fcwilt @natty15d
                                      And again, hmm...
                                      What filament are you using and what at what temp?
                                      It has to be your hardware or configuration as I have five different Duet WiFi setups and they all work fine at the slow speeds I mentioned.
                                      We just have to figure out what is different about your setup.
                                      • natty15dundefined
                                        natty15d
                                        PLA printing at 215, its all the same hardware, temps & pla that i used prior to changing to Duet, so i know its tested and works.
                                        Like you say i also think its a setting ive not set properly thats throwing the slow speed printing out
                                        OwenDundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                                        • OwenDundefined
                                          OwenD @natty15d
                                          @natty15d
                                          Is your slicer using volumetric extrusion?
                                          Have you checked part fan speeds?
                                          • fcwiltundefined
                                            fcwilt @natty15d
                                            I'm having to say "hmm..." a lot on this one.
                                            Have you watched the status of the print on the DWC (Duet Web Control) and verified the speeds are what they should be - taking into account the various settings of S3D?
