    Duet 2 inconsistent extrusions at slow speeds
    1.4k
    • natty15dundefined
      natty15d @fcwilt
      @fcwilt just changed the settings to
      still has the same issue 😞
      • natty15dundefined
        natty15d @Veti
        @Veti It's not a genuine E3d hotend, its a Trianglelabs clone with a 104GT-2 Thermistor Cartridge and Heater Cartridge 12V 40W 6mmx20mm
        • natty15dundefined
          natty15d
          The extruder stepper motor is a Nema 17 Bipolar Stepper 1.8deg 0.8A 120mN.m 42x42x22mm Nema17 Titan Pancake
          And the new settings are
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Nov 04 2020 17:51:25 GMT+0000 (Greenwich Mean Time)
          M550 P"Eniac40" ; set printer name
          M669 K1 ; select CoreXY mode
          M569 P2 S0 ; physical drive 2 goes backwards
          M92 X80.24 Y80.24 Z398.00 E412.00 ; set steps per mm
          M566 X480.00 Y480.00 Z18.00 E480.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X15000.00 Y15000.00 Z720.00 E1800.00 ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
          M906 X1700 Y1700 Z1700 E680 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X390 Y425 Z405 S0 ; set axis maxima
          M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
          M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
          M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop
          M558 P0 H2 F120 T15000 ; disable Z probe but set dive height, probe speed and travel speed
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
          M307 H0 A84.5 C94.6 D0.7 S1.00 V11.9 B0 ; PID heated bed
          M143 H0 S80 ; set temperature limit for heater 0 to 80C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          M307 H1 A298.1 C175.7 D3.8 S1.00 V11.8 B0 ; PID hotend heater
          M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H1 T180 ; set fan 2 value. Thermostatic control is turned on
          T0 ; select first tool
          • fcwiltundefined
            fcwilt @natty15d
            @natty15d said in Duet 2 inconsistent extrusions at slow speeds:
            Hmm..
            Are you by chance using a different brand or kind of filament?
            natty15dundefined 1 Reply Last reply Reply Quote 0
            • Vetiundefined
              Veti
              just to rule out slicer, can you do this test with a different slicer?
                Firmware version 3.1.1?
                Have you PID tuned the hotend recently? Is your temp graph stable?
                The gcode is basically identical other than the feed rate, but trying another slicer couldn't hurt for confirmation.
                • natty15dundefined
                  natty15d @fcwilt
                  @fcwilt I'm using the filament I was using before installing the duet
                  • fcwiltundefined
                    fcwilt @natty15d
                    Hmm...
                    Have you verified that the steps/mm setting for the extruder is correct?
                    • natty15dundefined
                      natty15d @Phaedrux
                      @Phaedrux PID tuned last week and very stable temps.
                      I've been 3d printing for years but I've only ever used simplify3d, are there any other slicers you'd recommend
                      Recalibrated my wanhao i3 last week with the same slicer and didn't have any issues
                      • natty15dundefined
                        natty15d @fcwilt
                        @fcwilt double checked that, 100mm is extruded
                        • natty15dundefined
                          natty15d
                          i also changed to "relative extrusion distances" in simplify3d for the Duet, never needed that for the wanhao i3
                          • fcwiltundefined
                            fcwilt @natty15d
                            And again, hmm...
                            What filament are you using and what at what temp?
                            It has to be your hardware or configuration as I have five different Duet WiFi setups and they all work fine at the slow speeds I mentioned.
                            We just have to figure out what is different about your setup.
                            • natty15dundefined
                              natty15d
                              PLA printing at 215, its all the same hardware, temps & pla that i used prior to changing to Duet, so i know its tested and works.
                              Like you say i also think its a setting ive not set properly thats throwing the slow speed printing out
                              OwenDundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                              • OwenDundefined
                                OwenD @natty15d
                                @natty15d
                                Is your slicer using volumetric extrusion?
                                Have you checked part fan speeds?
                                • fcwiltundefined
                                  fcwilt @natty15d
                                  I'm having to say "hmm..." a lot on this one.
                                  Have you watched the status of the print on the DWC (Duet Web Control) and verified the speeds are what they should be - taking into account the various settings of S3D?
                                  • natty15dundefined
                                    natty15d @OwenD
                                    @OwenD not sure on the volumetric slicing, will look into that, Fan speed is 100% after layer 1
                                    • natty15dundefined
                                      natty15d @fcwilt
                                      @fcwilt No i havent, will try that tomorrow
                                      • Vetiundefined
                                        Veti @natty15d
                                        prusaslicers standard profile is quite good and easy to setup
                                        • natty15dundefined
                                          natty15d @Veti
                                          Resliced the file, a single wall cube, at full speed 60mms, and a version with a reduced speed down to 20%. The slow file had the same poor extrusion, the fast file prints perfectly.
                                          I then printed another full speed version but this time used the control panel to reduce the print speed to 20% part way through the print.
                                          Once the speed was reduced the poor extrusion started again, increased to 50% and it was still bad, back to 100% and it prints beautifully. That must prove the slicer is okay as the full speed file prints perfectly but shows poor extrusion when slowed down in the printer
                                          It must be a setting I've messed up in the config but I've no idea what it is?
                                          • Vetiundefined
                                            Veti
                                            can you post a picture of your printer?
