Duet 2 inconsistent extrusions at slow speeds
@Veti It's not a genuine E3d hotend, its a Trianglelabs clone with a 104GT-2 Thermistor Cartridge and Heater Cartridge 12V 40W 6mmx20mm
The extruder stepper motor is a Nema 17 Bipolar Stepper 1.8deg 0.8A 120mN.m 42x42x22mm Nema17 Titan Pancake
And the new settings are
; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Nov 04 2020 17:51:25 GMT+0000 (Greenwich Mean Time); General preferences
M550 P"Eniac40" ; set printer name
M669 K1 ; select CoreXY mode; Network
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.24 Y80.24 Z398.00 E412.00 ; set steps per mm
M566 X480.00 Y480.00 Z18.00 E480.00 ; set maximum instantaneous speed changes (mm/min)
M203 X15000.00 Y15000.00 Z720.00 E1800.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X1700 Y1700 Z1700 E680 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X390 Y425 Z405 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop; Z-Probe
M558 P0 H2 F120 T15000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 A84.5 C94.6 D0.7 S1.00 V11.9 B0 ; PID heated bed
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 A298.1 C175.7 D3.8 S1.00 V11.8 B0 ; PID hotend heater; Fans
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H1 T180 ; set fan 2 value. Thermostatic control is turned on; Tools
T0 ; select first tool -
@natty15d said in Duet 2 inconsistent extrusions at slow speeds:
@fcwilt just changed the settings to
M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolationstill has the same issue
Hmm..
Are you by chance using a different brand or kind of filament?
just to rule out slicer, can you do this test with a different slicer?
Firmware version 3.1.1?
Have you PID tuned the hotend recently? Is your temp graph stable?
The gcode is basically identical other than the feed rate, but trying another slicer couldn't hurt for confirmation.
@fcwilt I'm using the filament I was using before installing the duet
Hmm...
Have you verified that the steps/mm setting for the extruder is correct?
@Phaedrux PID tuned last week and very stable temps.
I've been 3d printing for years but I've only ever used simplify3d, are there any other slicers you'd recommendRecalibrated my wanhao i3 last week with the same slicer and didn't have any issues
@fcwilt double checked that, 100mm is extruded
i also changed to "relative extrusion distances" in simplify3d for the Duet, never needed that for the wanhao i3
And again, hmm...
What filament are you using and what at what temp?
It has to be your hardware or configuration as I have five different Duet WiFi setups and they all work fine at the slow speeds I mentioned.
We just have to figure out what is different about your setup.
PLA printing at 215, its all the same hardware, temps & pla that i used prior to changing to Duet, so i know its tested and works.
Like you say i also think its a setting ive not set properly thats throwing the slow speed printing out -
@natty15d
Is your slicer using volumetric extrusion?
Have you checked part fan speeds? -
Like you say i also think its a setting ive not set properly thats throwing the slow speed printing outI'm having to say "hmm..." a lot on this one.
Have you watched the status of the print on the DWC (Duet Web Control) and verified the speeds are what they should be - taking into account the various settings of S3D?
@OwenD not sure on the volumetric slicing, will look into that, Fan speed is 100% after layer 1
@fcwilt No i havent, will try that tomorrow
prusaslicers standard profile is quite good and easy to setup
Resliced the file, a single wall cube, at full speed 60mms, and a version with a reduced speed down to 20%. The slow file had the same poor extrusion, the fast file prints perfectly.
I then printed another full speed version but this time used the control panel to reduce the print speed to 20% part way through the print.
Once the speed was reduced the poor extrusion started again, increased to 50% and it was still bad, back to 100% and it prints beautifully. That must prove the slicer is okay as the full speed file prints perfectly but shows poor extrusion when slowed down in the printer
It must be a setting I've messed up in the config but I've no idea what it is? -
can you post a picture of your printer?
Try reducing the extruder temps by 5 degree steps and printing again at each temp.
It's possible that you are running hotter than you think and cooking the filament.
