    Duet 3 MH6HC with Duet expansion 1XD, configuration issue
    1.5k
    • JoergS5undefined
      JoergS5 @dkraja42
      @dkraja42
      M350 and M906 are not needed for the drives which use the external drivers, because microstepping and current setting are done in the external drivers (either by switches or by firmware setting of the external driver).
      You've defined 2 drivers (40.0, 41.0, missing 0.2 and 0.3), but using 4 (XYZE).
      dkraja42undefined 1 Reply Last reply Reply Quote 0
      • dkraja42undefined
        dkraja42 @JoergS5
        @JoergS5 can you modify code for our requirement is:
        1. X axis stepper-01 nos
        2. Y axis stepper-02 nos
        3. Z axis stepper-02 nos
        4. internal extruder
        • JoergS5undefined
          JoergS5 @dkraja42
          @dkraja42 said in Duet 3 MH6HC with Duet expansion 1XD, configuration issue:
          M569 P40.0 S1 R1 ; change enable polarity, active = disable drive
          M569 P41.0 S1 R1 ; change enable polarity, active = disable drive
          ;M569 P42.0 S1 R1 ; change enable polarity, active = disable drive
          M584 X40.0 Y41.0 Z0.2 E0.3
          ;M584 X40.0 Y41.0 Z42.0 E0.3 ; set X, Y, Z, Extruder drivers
          ;M569 P0.0 S1 ; physical drive 0.0 goes forwards
          ;M569 P0.1 S1 ; physical drive 0.1 goes forwards
          ;M569 P0.2 S1 ; physical drive 0.2 goes forwards
          ;M569 P0.3 S0 ; physical drive 0.3 goes backwards
          ;M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
          should be changed to
          and then in the M584:
          M584 X40.0 Y41.0 Z42.0 E0.0 ; set X, Y, Z, Extruder drivers
          so here you map your M569 P numbers to the letters of the drives.
          And remove X, Y and Z from M350 and M906.
          dkraja42undefined 2 Replies Last reply Reply Quote 0
          • dkraja42undefined
            dkraja42 @JoergS5
            @JoergS5 ok. thanks. i will try
            • dkraja42undefined
              dkraja42 @JoergS5
              @JoergS5
              M32 "0:/gcodes/config.g"
              File 0:/gcodes/config.g selected for printing
              Error: Bad command: 584 X40.0 Y41.0 Z42.0 E0.0
              Ethernet is enabled, configured IP address: 0.0.0.0, actual IP address: 192.168.0.120
              Finished printing file 0:/gcodes/config.g, print time was 0h 0m
              M92 X100.00 Y100.00 Z400.00 E90.00 ; set steps per mm
              M566 X900.00 Y900.00 Z60.00 E900.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X12000.00 Y12000.00 Z600.00 E6000.00 ; set maximum speeds (mm/min)
              M201 X500.00 Y500.00 Z20.00 E500.00 ; set accelerations (mm/s^2)
              M84 S0 ; Disable motor idle current reduction
              Axis Limits
              M208 X230 Y230 Z230 S0 ; set axis maxima
              M574 X1 S1 P"!^io3.in" ; configure active-high endstop for low end on X via pin !^io3.in
              M574 Y1 S1 P"!^io1.in" ; configure active-high endstop for low end on Y via pin !^io1.in
              M574 Z1 S1 P"!^io2.in" ; configure active-high endstop for low end on Z via pin !^io2.in
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M557 X15:220 Y15:220 S20 ; define mesh grid
              M308 S0 P"temp1" Y"thermistor" T100000 B5000 ; configure sensor 0 as thermistor on pin temp1
              M950 H0 C"out2" T0 ; create bed heater output on out2 and map it to sensor 0
              M308 S1 P"temp0" Y"thermistor" T100000 B5000 ; configure sensor 1 as thermistor on pin temp0
              M143 H1 S230 ; set temperature limit for heater 1 to 230C
              M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
              M106 P0 S0.8 H-1 ; set fan 0 value. Thermostatic control is turned off
              ; Custom settings
              M575 P1 S1 B57600
              M570 H0 P999 S240
              M552 S1
              M552 192.168.0.132
                You appear to have lost the M at the start of the M584 line.
                • dkraja42undefined
                  dkraja42 @dc42
                  @dc42 yes we corrected M584 command line. but not able to move any axis.
                  30/11/2020, 13:04:11 M32 "0:/gcodes/homex.g"
                  File 0:/gcodes/homex.g selected for printing
                  30/11/2020, 13:04:10 Upload of homex.g successful after 0s
                  30/11/2020, 13:03:59 M32 "0:/gcodes/config.g"
                  30/11/2020, 13:03:58 Upload of config.g successful after 0s
                  jay_s_ukundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                    1. Are the red status LEDs on the expansion boards all blinking in sync with the one on the main board?
                    2. Have you tested the axis motors individually, using G91 followed by G1 H2 moves, e.g. G91 G1 H2 X10 ?
                      jay_s_uk @dkraja42
                      @dkraja42 all your config files are in the folder gcodes rather than the folder sys.
                      until you move them, they won't work correctly
                      • dkraja42undefined
                        dkraja42 @dc42
                        @dc42 said in Duet 3 MH6HC with Duet expansion 1XD, configuration issue:
                        ed stat
                        We have check all the manually G91 code but not able to move.
                        We have attached Video link and some images. please check ..
                        https://drive.google.com/file/d/1bjjLoMsEUapcxTMKrXVd_gO4B-17KvXU/view?usp=sharingWhatsApp Image 2020-11-30 at 1.15.21 PM.jpeg WhatsApp Image 2020-11-30 at 1.15.21 PM (1).jpeg
                        • JoergS5undefined
                          JoergS5 @dkraja42
                          @dkraja42 and you removed M350 and M906 completely. Please remove XYZ values for it only, not the command completely. For E you still need the settings:
                          M350 E16 I1 ; configure microstepping with interpolation
                          M906 E2000 ; set motor currents (mA)
                          • dkraja42undefined
                            dkraja42 @JoergS5
                            @JoergS5 PLEASE CHECK THE MAPPING OF 1XD BOARD:
                            M122 B42
                            Diagnostics for board 42:
                            Duet EXP1XD firmware version 3.2-beta4 (2020-11-26)
                            Bootloader ID: SAMC21 bootloader version 2.0 (2020-10-15b1)
                            Never used RAM 6140, free system stack 51 words
                            HEAT 42 CanAsync 88 CanRecv 82 MAIN 398 AIN 64
                            Last reset 00:13:27 ago, cause: power up
                            Last software reset at 2020-11-30 14:02, reason: HardFault, available RAM 6188, slot 1
                            Software reset code 0x0060 ICSR 0x00000003 SP 0x20002928 Task MAIN
                            Stack: ffffffff 00000002 00000007 00000001 41000000 000185d3 a5a5a5a4 81000200 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 2000142c 00000000 200041a0 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 20001a28 200041a0 a5a5a5a5 a5a5a5a5 0000fa91 a5a5a5a5
                            Driver 0: position 20000, 4000.0 steps/mm
                            Moves scheduled 1, completed 1, in progress 0, hiccups 0
                            No step interrupt scheduled
                            VIN: 12.8V
                            MCU temperature: min 24.7C, current 27.0C, max 27.2C
                            Ticks since heat task active 155, ADC conversions started 403949, completed 403949, timed out 0
                            Last sensors broadcast 0x00000000 found 0 158 ticks ago, loop time 0
                            CAN messages queued 27, send timeouts 0, received 7285, lost 0, free buffers 36
                            30/11/2020, 14:43:19 M122 B41
                            Diagnostics for board 41:
                            Never used RAM 6140, free system stack 49 words
                            Last reset 00:12:32 ago, cause: power up
                            Last software reset at 2106-02-07 06:28, reason: HardFault, available RAM 6188, slot 0
                            Software reset code 0x0060 ICSR 0xffffffff SP 0xffffffff Task ����
                            Driver 0: position -465000, 1000.0 steps/mm
                            Moves scheduled 3, completed 3, in progress 0, hiccups 1
                            VIN: 12.9V
                            MCU temperature: min 25.2C, current 27.8C, max 28.0C
                            Ticks since heat task active 199, ADC conversions started 376096, completed 376095, timed out 0
                            Last sensors broadcast 0x00000000 found 0 202 ticks ago, loop time 0
                            CAN messages queued 24, send timeouts 0, received 6785, lost 0, free buffers 36
                            30/11/2020, 14:42:58 M122 B40
                            Diagnostics for board 40:
                            Never used RAM 6140, free system stack 50 words
                            HEAT 42 CanAsync 88 CanRecv 82 MAIN 328 AIN 64
                            Last reset 00:12:11 ago, cause: power up
                            Last software reset time unknown, reason: HardFault, available RAM 6188, slot 1
                            Software reset code 0x0060 ICSR 0x00000003 SP 0x20002950 Task MAIN
                            Stack: 20004258 000007d0 20002d08 4b05fc5f 41000000 0000e37f 0000e380 01000000 200041a0 0000608f a5a5a5a5 20001a28 20001a28 200041a0 a5a5a5a5 0000fa9f a5a5a5a5 a5a5a5a5 a5a5a5a5 00014f35 a5a5a5a5 a5a5a5a5 00000000 0000e925 20001914 00000000 00000000
                            Driver 0: position -700000, 1000.0 steps/mm
                            Moves scheduled 4, completed 4, in progress 0, hiccups 0
                            VIN: 13.0V
                            MCU temperature: min 27.3C, current 29.1C, max 29.4C
                            Ticks since heat task active 14, ADC conversions started 365628, completed 365628, timed out 0
                            Last sensors broadcast 0x00000000 found 0 17 ticks ago, loop time 0
                            CAN messages queued 25, send timeouts 0, received 5038, lost 0, free buffers 36
                            • JoergS5undefined
                              JoergS5 @dkraja42
                              @dkraja42 I don't have a 1XD, so I have no experience with the M122 statistics, but they look ok for me. No hiccups and no errors reported, and CAN seems to work ok also.
                              Board 41 had a hiccup, I would check it again when you made bigger, faster, more moves.
                              • dkraja42undefined
                                dkraja42 @JoergS5
                                @JoergS5 Please see the config.g file:
                                Configuration file for Duet 3 (firmware version 3)
                                ; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 11:43:55 GMT+0530 (India Standard Time)
                                M550 P"Duet 3" ; set printer name
                                ; Custom settings
                                M575 P1 S1 B57600
                                M570 H0 P999 S240
                                M552 S1
                                M552 192.168.0.132
                                • JoergS5undefined
                                  JoergS5 @dkraja42
                                  @dkraja42 this looks ok also. But please run the code
                                  M98 P"0:/sys/config.g"
                                  to check the config.g,.
                                  If you run and one or more of the motors are turning in the wrong direction, this can be corrected in the M569 by changing from S1 to S0.
                                  • dkraja42undefined
                                    dkraja42 @dc42
                                    @dc42 Dear sir,
                                    Can you setup and check the configuration via Remote Access. After 2 days we need to start the production. so we need help to run the my 3d printer.
                                      Have you checked what step pulse timings are required for your drivers, and used M569 to increase them from the defaults if necessary? As a quick test, you could try M569 P40.0 T20:20:20:20 and see if that gets driver 40.0 moving.
                                      Also, try both R0 and R1 in the M569 commands for those drivers. Some external drivers have an Enable input, for others it is marked Enable but is really a Disable input.
                                        Phaedrux Moderator @dkraja42
                                        All of your config files are in the wrong folder.
                                        The gcodes folders is for the sliced gcode files to print.
                                        All the config files and homing files must be in the /sys folder.
                                        Nothing will work until you move your config files into the sys folder.
                                        See here for what the SD card file structure should look like.
                                        https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
