    Z height always not respected
    1.1k
    • Ducati87undefined
      Ducati87
      Hello guys, I'm still here 🤠 😵 well, the problem is that the height is not respected when I launch a print. The nozzle is always too high from the bed.
      Could you suggest to me what I have to take a look?
      Thank you guys
      homeall.g:
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:18 GMT+0200 (Ora legale dell’Europa centrale)
      ;M400
      ;M913 X50 Y50
      ;M915 X F0 H400 S3 R0
      ;M915 Y F0 H400 S2 R0
      ;G91               		; relative positioning
      ;G1 H2 Z5 F7200          ; lift Z relative to current position
      ;G1 H1 X5 F5000
      ;G1 H1 X-305 F5000 S1		; move quickly to X or Y endstop and stop there (first pass)
      ;G1 H1 X10
      M98 P"homex.g"
      ;G1 H1 Y5 F5000
      ;G1 H1 Y-305 F5000 S1		; move quickly to X or Y endstop and stop there (first pass)
      ;M913 X100 Y100			     ; X motors to 100% current
      ;G90
      ;G1 X120 Y170 F7000           ; go to first bed probe point and home Z
      ;G90                ; absolute positioning
      ;G1 X110 Y210 F7000           ; go to first bed probe point and home Z
      ;G4 P750             ; pause
      ;G91
      M98 P"homey.g"
      ;BLTouch Z
      ;G30
      ;G90
      ;G1 Z10 F500
      M98 P"homez.g"
      bed.g:
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 11:59:18 GMT+0200 (Ora legale dell’Europa centrale)
      G29 S2                  ;
      M561                   ; clear any bed transform
      M98 P"homeall.g"                    ; home all axes
      while iterations <= 3               ; perform 4 passes
          G30 P0 X280 Y145 Z-99999 P8    ; probe near a leadscrew, half way along Y axis
          G30 P1 X40 Y145 Z-99999 S2 P8   ; probe near a leadscrew and calibrate 2 motors
      G1 Z3 F3000                             ; raise head 3mm to ensure it is above the Z probe trigger height
      G90                                     ; back to absolute mode
      G29 S1
      homez.g:
      ; homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:19 GMT+0200 (Ora legale dell’Europa centrale)
      G1 X130 Y170 F7000           ; go to first bed probe point and home Z
      G4 P750             ; pause
      G91
      ;BLTouch Z
      G30
      G90
      G1 Z10 F500
      start gcode:
      G90 ; use absolute coordinates
      M83  ; extruder relative mode
      M190 S[first_layer_bed_temperature] ; wait for bed temp
      M109 S[first_layer_temperature] ; wait for extruder temp
      G32; home all without mesh bed level
      G1 X5 Y5 Z0.1 F5000.0 ; go outside print area
      G92 E0.0
      G1 X60.0 E9.0 F1000.0 ; intro line
      G1 X100.0 E20 F1000.0 ; intro line
      G92 E0.0
      Firmware:
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
      Duet WiFi Server Version: 1.23```
      • BoAundefined
        BoA
        config.g would help here also
        • Ducati87undefined
          Ducati87
          ; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 20:14:09 GMT+0100 (Ora standard dell’Europa centrale)
          G90                                                ; send absolute coordinates...
          M83                                                ; ...but relative extruder moves
          M550 P"Hypercube Evolution"                        ; set printer name
          M669 K1                                            ; select CoreXY mode
          M552 S1                                            ; enable network
          M586 P0 S1                                         ; enable HTTP
          M586 P1 S0                                         ; disable FTP
          M586 P2 S0                                         ; disable Telnet
          M569 P0 S1                                         ; physical drive 0 goes forwards
          M569 P1 S1                                         ; physical drive 1 goes forwards
          M569 P2 S0                                         ; physical drive 2 goes forwards
          M569 P3 S1                                         ; physical drive 3 goes forwards
          M569 P4 S0                                         ; physical drive 4 goes forwards
          M584 X0 Y1 Z2:4 E3                                 ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
          M92 X161.12 Y160.37 Z393.18:393.18 E830.00         ; set steps per mm
          M566 X1000.00 Y1000.00 Z15.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z600.00 E1800.00            ; set maximum speeds (mm/min)
          M201 X1800.00 Y1800.00 Z30.00 E300.00              ; set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1500:Z1500 E1000 I30                    ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                            ; Set idle timeout
          M208 X0 Y0 Z0 S1                                   ; set axis minima
          M208 X0:300 Y-45:300 Z285 S0                     ; set axis maxima
          M574 X1 S3                                         ; configure sensorless endstop for low end on X
          M574 Y1 S3                                         ; configure sensorless endstop for low end on Y
          M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
          M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H3 F420 T9000                ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X22 Y-37 Z3.070                             ; set Z probe trigger value, offset and trigger height
          M557 X0:250 Y25:230 S40:40                         ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                            ; map heated bed to heater 0
          M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
          ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          M308 S1 P"spi.cs2" Y"rtd-max31865"                 ; configure sensor 1 as thermocouple via CS pin spi.cs2
          M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S290                                       ; set temperature limit for heater 1 to 290C
          M950 F0 C"Mat Fan1" Q500                           ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"Hotend Fan" Q500                           ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"Mat Fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H-1                                 ; set fan 2 value. Thermostatic control is turned off
          M563 P0 S"hotend 0" D0 H1 F0:2                     ; define tool 0
          G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
          G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
          ; Custom settings
          M404 N1.75 D0.4								        ; Nozzle and filament diameter for monitor
          M200 D1.75 									        ; set all extruder filament diameters to 1.75mm
          M671 X40:280 Y145:145 S10							; Define positions of Z leadscrews or bed levelling screws
          M376 H10											; Set bed compensation taper
          M575 P1 S1 B57600                                  ; enable support for PanelDue
          M501                                               ; load saved parameters from non-volatile memory
          T0                                                 ; select first tool
          • Vetiundefined
            Veti
            @Ducati87 said in Z height always not respected:
            multiple values for z are not valid
            this is incorrect x and y here should only have one value
            • BoAundefined
              BoA
              This is messed up...
              1. No G28 in start code, so no proper homing
              2. M98 P"homeall.g" should not be in bed.g
              For start code basic sequence should be something like:
              G28 ; home all without mesh bed level
              G32 ; gantry leveling
              G29 ; mesh bed compensation
              that's for start.
              Also. If You just execute G28, is the nozzle on the right height - Z trigger height is correct? And by "nozzle is too high" - by how much?
              Ducati87undefined 2 Replies Last reply Reply Quote 0
              • Ducati87undefined
                Ducati87 @BoA
                @BoA said in Z height always not respected:
                that's for start.
                I call only G32 in the start gcode because I have the G28 and G29 S1 in the bed.g
                BoAundefined 1 Reply Last reply Reply Quote 0
                • BoAundefined
                  BoA @Ducati87
                  @Ducati87 Well... I do not see any G28
                  I know what You have in bed.g
                  What I wrote is that You should not have it there
                  Ducati87undefined 1 Reply Last reply Reply Quote 0
                  • Ducati87undefined
                    Ducati87 @BoA
                    ok I will try as you suggested.
                    • Ducati87undefined
                      Ducati87 @BoA
                      that's for start.
                      When I call G28 the value is about 6.00. If I use the babystep I have to go over the 1.4mm....
                      • BoAundefined
                        BoA @Ducati87
                        @Ducati87 Ok then, so assuming this is bltouch
                        F420 - too fast for bltouch, I would use F120
                        If nozzle if 1.4mm too high - I would adjust Z trigger height
                        G31 P500 X22 Y-37 Z4.470 ; 3.070 + 1.4
                        • Ducati87undefined
                          Ducati87 @BoA
                          for too high I mean too FAR.
                          • BoAundefined
                            BoA @Ducati87
                            That is what I assumed
                            • Ducati87undefined
                              Ducati87 @BoA
                              ok I said just to clarify. 😊 😊
                              • BoAundefined
                                BoA @Ducati87
                                @Ducati87 Just one question - is that a new setup, or it was working, and is not working correctly now?
                                • Ducati87undefined
                                  Ducati87 @BoA
                                  it worked until I had to redo the procedure following the hotend change.
                                  • BoAundefined
                                    BoA @Ducati87
                                    @Ducati87 And let me guess... new hotend is about 1.4mm shorter/higher 😉 or... bltouch 1.4mm lower
                                    You can get more precise results by setting:
                                    G31 P500 X22 Y-37 Z0.0
                                    homing using G28
                                    going to Z0.0 (indicated) and measuring actual nozzle tip height. Then put this measurement value as Z trigger height in G31
                                    or after homing disable limits by M564 S0
                                    and move head down just to touch the bed by nozzle tip, and use indicated Z value a trigger height (remove the minus obviously)
                                    • Ducati87undefined
                                      Ducati87 @BoA
                                      homing using G28
                                      I did it a couple of times but with same results. the value detected by the procedure is not accurate.
                                      • BoAundefined
                                        BoA @Ducati87
                                        @Ducati87 Well... that mostly depends on probe and Your measurements accuracy. Did You slow down probing speed to 120 ?
                                        • Ducati87undefined
                                          Ducati87 @BoA
                                          it's an original BLtouch 3.1...I cannot understand where the problem is.
                                          • BoAundefined
                                            BoA @Ducati87
                                            @Ducati87 You can try to add A parameter to M558, for example A4. And slow down probing speed to 120
