Z height always not respected
1.1k
    BoA
    This is messed up...
    1. No G28 in start code, so no proper homing
    2. M98 P"homeall.g" should not be in bed.g
    For start code basic sequence should be something like:
    G28 ; home all without mesh bed level
    G32 ; gantry leveling
    G29 ; mesh bed compensation
    that's for start.
    Also. If You just execute G28, is the nozzle on the right height - Z trigger height is correct? And by "nozzle is too high" - by how much?
    undefined 2 Replies Last reply 3 Dec 2020, 10:06 Reply Quote 0
      Ducati87 @BoA
      @BoA said in Z height always not respected:
      that's for start.
      I call only G32 in the start gcode because I have the G28 and G29 S1 in the bed.g
      undefined 1 Reply Last reply 3 Dec 2020, 10:11 Reply Quote 0
        BoA @Ducati87
        @Ducati87 Well... I do not see any G28
        I know what You have in bed.g
        What I wrote is that You should not have it there
        undefined 1 Reply Last reply 3 Dec 2020, 10:12 Reply Quote 0
          Ducati87 @BoA
          ok I will try as you suggested.
            Ducati87 @BoA
            that's for start.
            When I call G28 the value is about 6.00. If I use the babystep I have to go over the 1.4mm....
            undefined 1 Reply Last reply 3 Dec 2020, 10:19 Reply Quote 0
              BoA @Ducati87
              @Ducati87 Ok then, so assuming this is bltouch
              M558 P9 C"^zprobe.in" H3 F420 T9000
              F420 - too fast for bltouch, I would use F120
              If nozzle if 1.4mm too high - I would adjust Z trigger height
              G31 P500 X22 Y-37 Z4.470 ; 3.070 + 1.4
              undefined 1 Reply Last reply 3 Dec 2020, 10:21 Reply Quote 0
                Ducati87 @BoA
                for too high I mean too FAR.
                undefined 1 Reply Last reply 3 Dec 2020, 10:23 Reply Quote 0
                  BoA @Ducati87
                  @Ducati87 said in Z height always not respected:
                  That is what I assumed
                  undefined 1 Reply Last reply 3 Dec 2020, 10:24 Reply Quote 0
                    Ducati87 @BoA
                    ok I said just to clarify. 😊 😊
                    undefined 1 Reply Last reply 3 Dec 2020, 10:26 Reply Quote 0
                      BoA @Ducati87
                      @Ducati87 Just one question - is that a new setup, or it was working, and is not working correctly now?
                      undefined 1 Reply Last reply 3 Dec 2020, 10:30 Reply Quote 0
                        Ducati87 @BoA
                        it worked until I had to redo the procedure following the hotend change.
                        undefined 1 Reply Last reply 3 Dec 2020, 10:31 Reply Quote 0
                          BoA @Ducati87
                          @Ducati87 And let me guess... new hotend is about 1.4mm shorter/higher 😉 or... bltouch 1.4mm lower
                          You can get more precise results by setting:
                          G31 P500 X22 Y-37 Z0.0
                          homing using G28
                          going to Z0.0 (indicated) and measuring actual nozzle tip height. Then put this measurement value as Z trigger height in G31
                          or after homing disable limits by M564 S0
                          and move head down just to touch the bed by nozzle tip, and use indicated Z value a trigger height (remove the minus obviously)
                          undefined 1 Reply Last reply 3 Dec 2020, 10:49 Reply Quote 0
                            Ducati87 @BoA
                            homing using G28
                            I did it a couple of times but with same results. the value detected by the procedure is not accurate.
                            undefined 1 Reply Last reply 3 Dec 2020, 10:52 Reply Quote 0
                              BoA @Ducati87
                              @Ducati87 Well... that mostly depends on probe and Your measurements accuracy. Did You slow down probing speed to 120 ?
                                Ducati87 @BoA
                                it's an original BLtouch 3.1...I cannot understand where the problem is.
                                undefined 1 Reply Last reply 3 Dec 2020, 10:58 Reply Quote 0
                                  BoA @Ducati87
                                  @Ducati87 You can try to add A parameter to M558, for example A4. And slow down probing speed to 120
                                  undefined 1 Reply Last reply 3 Dec 2020, 12:51 Reply Quote 0
                                    Ducati87 @BoA
                                    ok I will try. Thank you BoA!
                                      After you changed the hotend did you remeasure your trigger height?
                                      https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                      undefined 1 Reply Last reply 4 Dec 2020, 06:23 Reply Quote 0
                                        Ducati87 @Phaedrux
                                        @Phaedrux said in Z height always not respected:
                                        Yes of course but every time I have to adjust the height with babystep.
                                          Could you share your current config.g, homeall/homez, bed.g, and your slicer start gcode all together in a single post? That way I can see what's going on more clearly.
                                          If the amount of baby stepping required is consistent, you can modify the G31 and it should take effect. If it's not taking effect than something in the gcode order is not right.
                                          undefined 1 Reply Last reply 6 Dec 2020, 19:53 Reply Quote 0
                                          14 out of 31
