Z height always not respected
Hello guys, I'm still here
well, the problem is that the height is not respected when I launch a print. The nozzle is always too high from the bed.
Could you suggest to me what I have to take a look?
Thank you guyshomeall.g:
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:18 GMT+0200 (Ora legale dell’Europa centrale) ;M400 ;M913 X50 Y50 ;M915 X F0 H400 S3 R0 ;M915 Y F0 H400 S2 R0 ;G91 ; relative positioning ;G1 H2 Z5 F7200 ; lift Z relative to current position ;G1 H1 X5 F5000 ;G1 H1 X-305 F5000 S1 ; move quickly to X or Y endstop and stop there (first pass) ;G1 H1 X10 M98 P"homex.g" ;G1 H1 Y5 F5000 ;G1 H1 Y-305 F5000 S1 ; move quickly to X or Y endstop and stop there (first pass) ;M913 X100 Y100 ; X motors to 100% current ;G90 ;G1 X120 Y170 F7000 ; go to first bed probe point and home Z ;G91 ; relative positioning ;G1 H2 Z5 F7200 ; lift Z relative to current position ;G90 ; absolute positioning ;G1 X110 Y210 F7000 ; go to first bed probe point and home Z ;G4 P750 ; pause ;G91 M98 P"homey.g" ;BLTouch Z ;G30 ;G90 ;G1 Z10 F500 M98 P"homez.g"
bed.g:
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 11:59:18 GMT+0200 (Ora legale dell’Europa centrale) G29 S2 ; M561 ; clear any bed transform M98 P"homeall.g" ; home all axes while iterations <= 3 ; perform 4 passes G30 P0 X280 Y145 Z-99999 P8 ; probe near a leadscrew, half way along Y axis G30 P1 X40 Y145 Z-99999 S2 P8 ; probe near a leadscrew and calibrate 2 motors G1 Z3 F3000 ; raise head 3mm to ensure it is above the Z probe trigger height G90 ; back to absolute mode G29 S1
homez.g:
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:19 GMT+0200 (Ora legale dell’Europa centrale) G91 ; relative positioning ;G1 H2 Z5 F7200 ; lift Z relative to current position G90 ; absolute positioning G1 X130 Y170 F7000 ; go to first bed probe point and home Z G4 P750 ; pause G91 ;BLTouch Z G30 G90 G1 Z10 F500
start gcode:
G90 ; use absolute coordinates M83 ; extruder relative mode M190 S[first_layer_bed_temperature] ; wait for bed temp M109 S[first_layer_temperature] ; wait for extruder temp G32; home all without mesh bed level G1 X5 Y5 Z0.1 F5000.0 ; go outside print area G92 E0.0 G1 X60.0 E9.0 F1000.0 ; intro line G1 X100.0 E20 F1000.0 ; intro line G92 E0.0
Firmware:
Board: Duet 2 WiFi (2WiFi) Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2) Duet WiFi Server Version: 1.23```
config.g would help here also
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 20:14:09 GMT+0100 (Ora standard dell’Europa centrale) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Hypercube Evolution" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S0 ; physical drive 4 goes forwards M584 X0 Y1 Z2:4 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X161.12 Y160.37 Z393.18:393.18 E830.00 ; set steps per mm M566 X1000.00 Y1000.00 Z15.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z600.00 E1800.00 ; set maximum speeds (mm/min) M201 X1800.00 Y1800.00 Z30.00 E300.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1500:Z1500 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X0:300 Y-45:300 Z285 S0 ; set axis maxima ; Endstops M574 X1 S3 ; configure sensorless endstop for low end on X M574 Y1 S3 ; configure sensorless endstop for low end on Y M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H3 F420 T9000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X22 Y-37 Z3.070 ; set Z probe trigger value, offset and trigger height M557 X0:250 Y25:230 S40:40 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs2 M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S290 ; set temperature limit for heater 1 to 290C ; Fans M950 F0 C"Mat Fan1" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"Hotend Fan" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"Mat Fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off ; Tools M563 P0 S"hotend 0" D0 H1 F0:2 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings M404 N1.75 D0.4 ; Nozzle and filament diameter for monitor M200 D1.75 ; set all extruder filament diameters to 1.75mm M671 X40:280 Y145:145 S10 ; Define positions of Z leadscrews or bed levelling screws M376 H10 ; Set bed compensation taper ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
@Ducati87 said in Z height always not respected:
multiple values for z are not valid
this is incorrect x and y here should only have one value
This is messed up...
- No G28 in start code, so no proper homing
- M98 P"homeall.g" should not be in bed.g
For start code basic sequence should be something like:
G28 ; home all without mesh bed level
G32 ; gantry leveling
G29 ; mesh bed compensationthat's for start.
Also. If You just execute G28, is the nozzle on the right height - Z trigger height is correct? And by "nozzle is too high" - by how much?
@BoA said in Z height always not respected:
I call only G32 in the start gcode because I have the G28 and G29 S1 in the bed.g
@Ducati87 Well... I do not see any G28
I know what You have in bed.g
What I wrote is that You should not have it there -
What I wrote is that You should not have it thereok I will try as you suggested.
When I call G28 the value is about 6.00. If I use the babystep I have to go over the 1.4mm....
@Ducati87 Ok then, so assuming this is bltouch
F420 - too fast for bltouch, I would use F120
If nozzle if 1.4mm too high - I would adjust Z trigger heightG31 P500 X22 Y-37 Z4.470 ; 3.070 + 1.4
for too high I mean too FAR.
That is what I assumed
ok I said just to clarify.
@Ducati87 Just one question - is that a new setup, or it was working, and is not working correctly now?
it worked until I had to redo the procedure following the hotend change.
@Ducati87 And let me guess... new hotend is about 1.4mm shorter/higher
or... bltouch 1.4mm lower
You can get more precise results by setting:
G31 P500 X22 Y-37 Z0.0
homing using G28
going to Z0.0 (indicated) and measuring actual nozzle tip height. Then put this measurement value as Z trigger height in G31
or after homing disable limits by M564 S0
and move head down just to touch the bed by nozzle tip, and use indicated Z value a trigger height (remove the minus obviously) -
homing using G28
and move head down just to touch the bed by nozzle tip, and use indicated Z value a trigger height (remove the minus obviously)I did it a couple of times but with same results. the value detected by the procedure is not accurate.
@Ducati87 Well... that mostly depends on probe and Your measurements accuracy. Did You slow down probing speed to 120 ?
it's an original BLtouch 3.1...I cannot understand where the problem is.
@Ducati87 You can try to add A parameter to M558, for example A4. And slow down probing speed to 120
