    Z height always not respected
    1.1k
    • Ducati87undefined
      Ducati87 @BoA
      @BoA said in Z height always not respected:
      @Ducati87 said in Z height always not respected:
      for too high I mean too FAR.
      That is what I assumed
      ok I said just to clarify. 😊 😊
      BoAundefined 1 Reply Last reply Reply Quote 0
      • BoAundefined
        BoA @Ducati87
        @Ducati87 Just one question - is that a new setup, or it was working, and is not working correctly now?
        Ducati87undefined 1 Reply Last reply Reply Quote 0
        • Ducati87undefined
          Ducati87 @BoA
          it worked until I had to redo the procedure following the hotend change.
          • BoAundefined
            BoA @Ducati87
            @Ducati87 And let me guess... new hotend is about 1.4mm shorter/higher 😉 or... bltouch 1.4mm lower
            You can get more precise results by setting:
            G31 P500 X22 Y-37 Z0.0
            homing using G28
            going to Z0.0 (indicated) and measuring actual nozzle tip height. Then put this measurement value as Z trigger height in G31
            or after homing disable limits by M564 S0
            and move head down just to touch the bed by nozzle tip, and use indicated Z value a trigger height (remove the minus obviously)
            • Ducati87undefined
              Ducati87 @BoA
              homing using G28
              I did it a couple of times but with same results. the value detected by the procedure is not accurate.
              • BoAundefined
                BoA @Ducati87
                @Ducati87 Well... that mostly depends on probe and Your measurements accuracy. Did You slow down probing speed to 120 ?
                • Ducati87undefined
                  Ducati87 @BoA
                  it's an original BLtouch 3.1...I cannot understand where the problem is.
                  • BoAundefined
                    BoA @Ducati87
                    @Ducati87 You can try to add A parameter to M558, for example A4. And slow down probing speed to 120
                    • Ducati87undefined
                      Ducati87 @BoA
                      ok I will try. Thank you BoA!
                        After you changed the hotend did you remeasure your trigger height?
                        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                        • Ducati87undefined
                          Ducati87 @Phaedrux
                          @Phaedrux said in Z height always not respected:
                          Yes of course but every time I have to adjust the height with babystep.
                            Could you share your current config.g, homeall/homez, bed.g, and your slicer start gcode all together in a single post? That way I can see what's going on more clearly.
                            If the amount of baby stepping required is consistent, you can modify the G31 and it should take effect. If it's not taking effect than something in the gcode order is not right.
                            • Ducati87undefined
                              Ducati87
                              config.g:
                              ; generated by RepRapFirmware Configuration Tool v3.1.8 on Fri Nov 20 2020 20:14:09 GMT+0100 (Ora standard dell’Europa centrale)
                              G90                                                ; send absolute coordinates...
                              M83                                                ; ...but relative extruder moves
                              M550 P"Hypercube Evolution"                        ; set printer name
                              M669 K1                                            ; select CoreXY mode
                              M552 S1                                            ; enable network
                              M586 P0 S1                                         ; enable HTTP
                              M586 P1 S0                                         ; disable FTP
                              M586 P2 S0                                         ; disable Telnet
                              M569 P0 S1                                         ; physical drive 0 goes forwards
                              M569 P1 S1                                         ; physical drive 1 goes forwards
                              M569 P2 S0                                         ; physical drive 2 goes forwards
                              M569 P3 S1                                         ; physical drive 3 goes forwards
                              M569 P4 S0                                         ; physical drive 4 goes forwards
                              M584 X0 Y1 Z2:4 E3                                 ; set drive mapping
                              M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                              M92 X161.12 Y160.37 Z393.18 E830.00         ; set steps per mm
                              M566 X1000.00 Y1000.00 Z70.00 E2000.00                ; set maximum instantaneous speed changes (mm/min)
                              M203 X15000.00 Y15000.00 Z1000.00 E2000.00            ; set maximum speeds (mm/min)
                              M201 X3000.00 Y3000.00 Z40.00 E6000.00              ; set accelerations (mm/s^2)
                              M906 X1000 Y1000 Z1500:Z1500 E1000 I30                    ; set motor currents (mA) and motor idle factor in per cent
                              M84 S30                                            ; Set idle timeout
                              ;M208 X0 Y0 Z0 S1                                   ; set axis minima
                              M208 X0:300 Y-35:300 Z285 S0                     ; set axis maxima
                              M574 X1 S3                                         ; configure sensorless endstop for low end on X
                              M574 Y1 S3                                         ; configure sensorless endstop for low end on Y
                              M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
                              M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
                              M558 P9 C"^zprobe.in" H3 F250 T9000 A2 B1               ; set Z probe type to bltouch and the dive height + speeds
                              G31 P500 X22 Y-37 Z3.50                             ; set Z probe trigger value, offset and trigger height
                              M557 X0:280 Y25:230 S40:40                         ; define mesh grid
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin bedtemp
                              M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                              M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
                              M140 H0                                            ; map heated bed to heater 0
                              M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                              ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                              M308 S1 P"spi.cs2" Y"rtd-max31865"                 ; configure sensor 1 as thermocouple via CS pin spi.cs2
                              M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                              M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                              M143 H1 S290                                       ; set temperature limit for heater 1 to 290C
                              M950 F0 C"Mat Fan1" Q500                           ; create fan 0 on pin fan0 and set its frequency
                              M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                              M950 F1 C"Hotend Fan" Q500                           ; create fan 1 on pin fan1 and set its frequency
                              M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                              M950 F2 C"Mat Fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
                              M106 P2 S1 H-1                                 ; set fan 2 value. Thermostatic control is turned off
                              M563 P0 S"hotend 0" D0 H1 F0:2                     ; define tool 0
                              G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                              G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                              ; Custom settings
                              M404 N1.75 D0.4								        ; Nozzle and filament diameter for monitor
                              M200 D1.75 									        ; set all extruder filament diameters to 1.75mm
                              M671 X40:280 Y145:145 S10							; Define positions of Z leadscrews or bed levelling screws
                              M376 H10											; Set bed compensation taper
                              M575 P1 S1 B57600                                  ; enable support for PanelDue
                              M501                                               ; load saved parameters from non-volatile memory
                              T0                                                 ; select first tool
                              homeall.g:
                              ; homeall.g
                              ; called to home all axes
                              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:18 GMT+0200 (Ora legale dell’Europa centrale)
                              ;M400
                              ;M913 X50 Y50
                              ;M915 X F0 H400 S3 R0
                              ;M915 Y F0 H400 S2 R0
                              ;G91               		; relative positioning
                              ;G1 H2 Z5 F7200          ; lift Z relative to current position
                              ;G1 H1 X5 F5000
                              ;G1 H1 X-305 F5000 S1		; move quickly to X or Y endstop and stop there (first pass)
                              ;G1 H1 X10
                              M98 P"homex.g"
                              ;G1 H1 Y5 F5000
                              ;G1 H1 Y-305 F5000 S1		; move quickly to X or Y endstop and stop there (first pass)
                              ;M913 X100 Y100			     ; X motors to 100% current
                              ;G90
                              ;G1 X120 Y170 F7000           ; go to first bed probe point and home Z
                              ;G90                ; absolute positioning
                              ;G1 X110 Y210 F7000           ; go to first bed probe point and home Z
                              ;G4 P750             ; pause
                              ;G91
                              M98 P"homey.g"
                              ;BLTouch Z
                              ;G30
                              ;G90
                              ;G1 Z10 F500
                              M98 P"homez.g"
                              bed.g:
                              ; bed.g
                              ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 11:59:18 GMT+0200 (Ora legale dell’Europa centrale)
                              G29 S2                  ;
                              M561                   ; clear any bed transform
                              ;M98 P"homeall.g"                    ; home all axes
                              while iterations <= 3               ; perform 4 passes
                                  G30 P0 X280 Y145 Z-99999 P8    ; probe near a leadscrew, half way along Y axis
                                  G30 P1 X40 Y145 Z-99999 S2 P8   ; probe near a leadscrew and calibrate 2 motors
                              G1 Z3 F3000                             ; raise head 3mm to ensure it is above the Z probe trigger height
                              G90                                     ; back to absolute mode
                              ;G29 S1
                              homez.g:
                              ; homez.g
                              ; called to home the Z axis
                              ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Jul 27 2020 14:28:19 GMT+0200 (Ora legale dell’Europa centrale)
                              G1 X130 Y170 F7000           ; go to first bed probe point and home Z
                              G4 P750             ; pause
                              G91
                              ;BLTouch Z
                              G30
                              G90
                              ;G1 Z10 F500
                              start gcode:
                              G90 ; use absolute coordinates
                              M83  ; extruder relative mode
                              M190 S[first_layer_bed_temperature] ; wait for bed temp
                              M109 S[first_layer_temperature] ; wait for extruder temp
                              G28; homing
                              G32; home all without mesh bed level
                              G29 S1; mesh bed load
                              G1 X5 Y5 Z0.1 F5000.0 ; go outside print area
                              G92 E0.0
                              G1 X60.0 E9.0 F1000.0 ; intro line
                              G1 X100.0 E20 F1000.0 ; intro line
                              G92 E0.0
                                Phaedrux Moderator @Ducati87
                                What's with the P8s?
                                G28; homing
                                When is the last time you created a fresh heightmap?
                                • Ducati87undefined
                                  Ducati87 @Phaedrux
                                  G28; homing
                                  the P8 is an error, I deleted them. I created the mesh yesterday in the morning.
                                    Phaedrux Moderator @Phaedrux
                                    How much baby stepping are you applying and is it consistent?
                                    • Ducati87undefined
                                      Ducati87 @Phaedrux
                                      almost 0.160.
                                        And if you modify G31 to account for the 0.16? (add it to get it closer, subtract to get it further)
                                        • Ducati87undefined
                                          Ducati87 @Phaedrux
                                          I've just done it, I'm going to try.
