    PanelDueFirmware 3.2.4 released
    PanelDue
    14
    64
    4.4k
    • oozeBotundefined
      oozeBot
      Has it been reported that the PanelDue appears to be refreshing (blinking) much more often with this release? I’ve not been able to put my finger on what’s triggering it, but it’s new to 3.2.4 or maybe 3.2.3..
      A Former User? Exerqtorundefined wilrikerundefined 3 Replies Last reply Reply Quote 1
        A Former User @oozeBot
        @oozeBot said in PanelDueFirmware 3.2.4 released:
        yes, i think i share that sentiment
        • Exerqtorundefined
          Exerqtor @oozeBot
          I secound that, started happening with 3.2.3 at least.
          • wilrikerundefined
            wilriker @A Former User
            @bearer said in PanelDueFirmware 3.2.4 released:
            so when using the default 57600 M997 S4 should switch both the Duet and the PanelDue to 115200, and erase/reset as needed? (it didn't, but when set to 115200 it did (erase and reset automagically))
            The flashing procedure will
            • send the command to erase-and-reset with the currently configured baud rate (this only has effect if PanelDueFirmware is already 3.2.2 or newer)
            • It waits one second for the PanelDue to comply - this will then start the Bootloader which is hard-coded to 115200 baud
            • If Duet board is currently set to something other than 115200 it will change that
            • bossa code is executed on Duet to flash the PanelDue
            • After the reset at the end PanelDue will boot and restore the previously configured baud rate
            • If the Duet baud rate was changed above this will be undone at the end before handing control back to the user
            Manuel
            My Tool Collection
            • wilrikerundefined
              wilriker @oozeBot
              Yes, that was a change introduced in 3.2.3. It will update twice as often than before. If it encounters too many errors related to too frequent status requests it will dynamically slow down request rate until it sees stable responses again.
              Also changed in that version was a significant speed up of the initialization phase.
              Also @bearer and @Exerqtor
              Manuel
              My Tool Collection
              BoAundefined oozeBotundefined 2 Replies Last reply Reply Quote 0
                A Former User @wilriker
                @wilriker said in PanelDueFirmware 3.2.4 released:
                send the command to erase-and-reset with the currently configured baud rate (this only has effect of PanelDueFirmware is already 3.2.2 or newer)
                On the 7i i have here this is not the case; or it might well send the command but the only way I could update was to either press erase myself or set the baud rate to 115200 for both the Duet and the PanelDue before issuing M997 S4. Both with the previous beta, and again with 3.2.4 trying to reflash itself to 3.2.4.
                Update: Just tried a (less than genuine) v3 4.3" and it does erase but not reset with 57600 baud, however with 115200 baud it erases and resets. Will try the (genuine) 7i again later and report back.
                • BoAundefined
                  BoA @wilriker
                  @wilriker I thing that @bearer ment display elements re-drawing, not refreshing the values. Something like during initialization phase, but also later.
                  https://www.youtube.com/watch?v=gs-aTMfqvMY
                  • wilrikerundefined
                    I don't understand why that would be related to baud rate since RRF just sends a specific text and PanelDueFirmware reacts to that in its own application logic.
                    Nevertheless I will investigate.
                    Manuel
                    My Tool Collection
                      @wilriker did another 5 flashes at each baud rate; 7i seems to only occasionally not erase; but consistently does not reset when on 57600. 115200 is all good. I can try to dig out logic analyzer to log the serial traffic later if of interest.
                      But as long as its not the intended behaviour I'm less confused:)
                      • gloomyandyundefined
                        gloomyandy
                        My (genuine) 7i also does not seem to reset after a flash (it always seems to erase and program ok). I'm running the 7i at 57600 and have not (yet) tried changing that to 115200 (will do so later if it helps). FYI I'm running this on the LPC version of RRF and had assumed the lack of reset was down to some problem with my port of the code, but perhaps that is not the case?
                          My v3 non-integrated PanelDue configured for 57600 baud does erase and then flash successfully, but never resets after flashing.
                          • wilrikerundefined
                            wilriker
                            I think I found the reason why it did not Erase-and-Reset in the beginning and/or reset at the end for some users. Currently testing.
                            Manuel
                            My Tool Collection
                              @wilriker poke me if you want me to test on my troublesome hardware, genuine and not so genuine (don't think that makes a difference in this case?)
                              edit: wilriker seems to have fixed in latest rrf 3.02-dev on git 🙌
                              • SputnikOC3dundefined
                                SputnikOC3d @Karabox
                                @Karabox said in PanelDueFirmware 3.2.4 released:
                                You could try to use the PanelDue-v3-5.0.bin instead. It might work since it uses a slightly different display driver.
                                But note that for clones there is no support.
                                You were right, the firmware came up, the red color is in place. Thank you very much!
                                I cannot get my fysetc unit to connect now thative upgraded the duet rrf3 fw...
                                tried the v3-5.0 bin but to no avail ... jsut sits there "connecting" no use ... not communicating with the duet. cant see the files or move the axis ...
                                was working pretty well before....
                                  @Karabox
                                  Did u actually get your fysetc paneldue workign with the other variant of fw - and comunicating the the duet - or just the color changes work? I got hte different colors and the lcd functions on the usb - but it cant seem to connect to the duet on rrf 3.2-beta4
                                    A Former User @SputnikOC3d
                                    @SputnikOC3d said in PanelDueFirmware 3.2.4 released:
                                    if you upgraded from before 3.1 check out the release notes https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-310
                                    SputnikOC3dundefined 2 Replies Last reply Reply Quote 0
                                      SputnikOC3d @A Former User
                                      @bearer
                                      TY - I was on 3.1.1 RRF for the duet but had not updated the paneldue fw for quite a while
                                        Found another thread / post where you identified the issue :
                                        Ive got no M575 P1 S1 B57600
                                        Think thats the issue ?
                                        TY ...
                                        SputnikOC3dundefined 1 Reply Last reply Reply Quote 1
                                          SputnikOC3d @SputnikOC3d
                                          @SputnikOC3d
                                          Solved it - missing vital COM line in config.g
                                          M575 P1 S1 B57600
                                          Release notes people ... READ them 😉
                                          • BoAundefined
                                            BoA
                                            Did anyone notice small dot's in corners, when screen saver is active? Are they suppose to be there?f5113763-88b3-4458-a262-737b5f749c4e-obraz.png
