    Turn your printer into a Juke Box.
    3D Printing General Chat
    3.5k
    • evomotorsundefined
      evomotors @Phaedrux
      @Phaedrux Too bad I don't have panel due.
        A Former User @evomotors
        @evomotors said in Turn your printer into a Juke Box.:
        as it uses the standard M300 code it should could work with 12864 based displays that are cheap as chips; and as of 3.2 should be supported for Duet 2 Wifi as wella s Duet 2 Maestro. (just make sure to get the correct chipset for your board)
        evomotorsundefined 1 Reply Last reply Reply Quote 0
        • oliofundefined
          oliof
          The 12864s I tried had simple buzzers without tone modulation ... Caveat emptor
            evomotors @A Former User
            @bearer said in Turn your printer into a Juke Box.:
            I'm on Duet 3 with SBC. I wonder if one of the spear connectors on Duet 3 can be used for this
            A Former User? oliofundefined 2 Replies Last reply Reply Quote 0
              Duet 3 with SBC
              suspect you'd need to tinker with the firmware to pull that off, and then it might be easier to try to deal with it on the SBC - or let DWC take care of it, however i've not found DWC to 100% flawless with playback of M300 sequences.
                Duet 3 with SBC
                I tried with DWC, doesn't sounds right.
                • oliofundefined
                  oliof @evomotors
                  @evomotors if you're not using an 12864 you can still enable it and then use the buzzer pin to drive whatever you want. It'll silence DWC as well.
                    A Former User
                    Afaik Duet3 6HC isnt built with support for that? So hacking something in the pi might be easier than maintaining a fork.
                    • oliofundefined
                      oliof
                      I missed the duet3 mention (-;
                      • mhundefined
                        mh
                        Hmm... The PanelDue 3.0 buzzer seems to be a DC version that has a built-in frequency generator and a little "+" on the housing indicating its polarity?
                        Was that different in earlier versions?
                          Phaedrux Moderator @mh
                          @mh said in Turn your printer into a Juke Box.:
                          This post might better belong as a new thread in the paneldue forum for better visibility.
                          • droftartsundefined droftarts referenced this topic
                          • o_lampeundefined o_lampe referenced this topic
                          • hareshPrajapatiundefined hareshPrajapati referenced this topic
                          • jumpedwithbothfeetundefined jumpedwithbothfeet referenced this topic
                          • Phaedruxundefined Phaedrux referenced this topic
                          • Exerqtorundefined Exerqtor referenced this topic
