Turn your printer into a Juke Box.
uh, no thanks!
@Phaedrux Too bad I don't have panel due.
@evomotors said in Turn your printer into a Juke Box.:
as it uses the standard M300 code it
shouldcould work with 12864 based displays that are cheap as chips; and as of 3.2 should be supported for Duet 2 Wifi as wella s Duet 2 Maestro. (just make sure to get the correct chipset for your board) -
The 12864s I tried had simple buzzers without tone modulation ... Caveat emptor
@bearer said in Turn your printer into a Juke Box.:
shouldcould work with 12864 based displays that are cheap as chips; and as of 3.2 should be supported for Duet 2 Wifi as wella s Duet 2 Maestro. (just make sure to get the correct chipset for your board)I'm on Duet 3 with SBC. I wonder if one of the spear connectors on Duet 3 can be used for this
Duet 3 with SBC
suspect you'd need to tinker with the firmware to pull that off, and then it might be easier to try to deal with it on the SBC - or let DWC take care of it, however i've not found DWC to 100% flawless with playback of M300 sequences.
Duet 3 with SBC
I tried with DWC, doesn't sounds right.
@evomotors if you're not using an 12864 you can still enable it and then use the buzzer pin to drive whatever you want. It'll silence DWC as well.
Afaik Duet3 6HC isnt built with support for that? So hacking something in the pi might be easier than maintaining a fork.
I missed the duet3 mention (-;
Hmm... The PanelDue 3.0 buzzer seems to be a DC version that has a built-in frequency generator and a little "+" on the housing indicating its polarity?
Was that different in earlier versions? -
@mh said in Turn your printer into a Juke Box.:
Was that different in earlier versions?This post might better belong as a new thread in the paneldue forum for better visibility.
undefined droftarts referenced this topic
undefined o_lampe referenced this topic
undefined hareshPrajapati referenced this topic
undefined jumpedwithbothfeet referenced this topic
undefined Phaedrux referenced this topic
undefined Exerqtor referenced this topic
