    PanelDueFirmware 3.2.4 released
    PanelDue
    14
    64
    4.4k
      A Former User @wilriker
      @wilriker poke me if you want me to test on my troublesome hardware, genuine and not so genuine (don't think that makes a difference in this case?)
      edit: wilriker seems to have fixed in latest rrf 3.02-dev on git 🙌
      • SputnikOC3dundefined
        SputnikOC3d @Karabox
        @Karabox said in PanelDueFirmware 3.2.4 released:
        @wilriker said in PanelDueFirmware 3.2.4 released:
        You could try to use the PanelDue-v3-5.0.bin instead. It might work since it uses a slightly different display driver.
        But note that for clones there is no support.
        You were right, the firmware came up, the red color is in place. Thank you very much!
        I cannot get my fysetc unit to connect now thative upgraded the duet rrf3 fw...
        tried the v3-5.0 bin but to no avail ... jsut sits there "connecting" no use ... not communicating with the duet. cant see the files or move the axis ...
        was working pretty well before....
          @Karabox
          Did u actually get your fysetc paneldue workign with the other variant of fw - and comunicating the the duet - or just the color changes work? I got hte different colors and the lcd functions on the usb - but it cant seem to connect to the duet on rrf 3.2-beta4
            A Former User @SputnikOC3d
            @SputnikOC3d said in PanelDueFirmware 3.2.4 released:
            if you upgraded from before 3.1 check out the release notes https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-310
            SputnikOC3dundefined 2 Replies Last reply Reply Quote 0
              SputnikOC3d @A Former User
              @bearer
              TY - I was on 3.1.1 RRF for the duet but had not updated the paneldue fw for quite a while
                @bearer said in PanelDueFirmware 3.2.4 released:
                Found another thread / post where you identified the issue :
                Ive got no M575 P1 S1 B57600
                Think thats the issue ?
                TY ...
                SputnikOC3dundefined 1 Reply Last reply Reply Quote 1
                  SputnikOC3d @SputnikOC3d
                  @SputnikOC3d
                  Solved it - missing vital COM line in config.g
                  M575 P1 S1 B57600
                  Release notes people ... READ them 😉
                  • BoAundefined
                    BoA
                    Did anyone notice small dot's in corners, when screen saver is active? Are they suppose to be there?f5113763-88b3-4458-a262-737b5f749c4e-obraz.png
                    • oozeBotundefined
                      oozeBot @wilriker
                      @wilriker back to the PanelDue refreshing the way it now does.. with all due respect, I don't like it.. maybe I don't understand the problem it is trying to solve though. However, it just seems to now refresh all the time. Where it really bugs me is on the Move screen - it seems to blink after every button press.. sometimes multiple times.
                      Nuramoriundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
                      • Nuramoriundefined
                        Nuramori @oozeBot
                        @oozeBot
                        @oozeBot said in PanelDueFirmware 3.2.4 released:
                        Yep. The lag on the refresh is not as pleasant.
                        • wilrikerundefined
                          wilriker @oozeBot
                          @oozeBot Either there is a bug I have missed it I just not get what you mean. Could perhaps make a video?
                          Only fields changing there values should see a refresh. Are you saying you see full refreshes all the time?
                          Manuel
                          My Tool Collection
                          oozeBotundefined 1 Reply Last reply Reply Quote 0
                          • oozeBotundefined
                            oozeBot @wilriker
                            @wilriker here you go: https://vimeo.com/490200847
                            • wilrikerundefined
                              wilriker @oozeBot
                              @oozeBot Thanks. This is definitely not intended behavior. I have a theory what is causing this and will investigate.
                              Manuel
                              My Tool Collection
                              oozeBotundefined 1 Reply Last reply Reply Quote 1
                              • oozeBotundefined
                                oozeBot @wilriker
                                @wilriker Glad to know this isn't intentional! Thanks for the hard work on this..
                                • wilrikerundefined
                                  wilriker @oozeBot
                                  @oozeBot I found it and have fixed it in the source code already. I will probably release a new version early next week.
                                  Manuel
                                  My Tool Collection
                                    A Former User
                                    (If you push the changes to git it might get tested, in a totally hypothetical scenario)
                                    ((in a less hypotetical scenario; kudos!))
                                    • wilrikerundefined
                                      wilriker @A Former User
                                      @bearer Usually I'd done that but I have too many incomplete changes that I'd like to finish first and I was too lazy for git add -p. 😉
                                      Maybe tonight.
                                      Manuel
                                      My Tool Collection
                                      • wilrikerundefined
                                        wilriker @BoA
                                        @BoA said in PanelDueFirmware 3.2.4 released:
                                        Did anyone notice small dot's in corners, when screen saver is active? Are they suppose to be there?!
                                        I guess you are using the light theme, aren't you? The reason for these dots is that I used a display element with rounded corners for the screensaver. I'll see if changing this to another display element will help.
                                        Manuel
                                        My Tool Collection
                                        BoAundefined A Former User? 2 Replies Last reply Reply Quote 0
                                        • BoAundefined
                                          BoA @wilriker
                                          @wilriker I am using dark theme 2 🙂
                                            @wilriker btw i'm seeing the same thing with a dark2 theme, and unrounding the corners will most likely resolve it indeed
