    After Micro swiss DD upgrade,Extruder skips steps
    164
    12.7k
    • Vetiundefined
      Veti @lui2004
      @lui2004
      is it heating up fast enough? then you dont need to change it.
      i use these.
      https://de.aliexpress.com/item/32857783159.html
      lui2004undefined 1 Reply Last reply Reply Quote 0
      • lui2004undefined
        lui2004 @Veti
        @Veti
        i have strange temperature printing pla with 250°C or is it the thermistor that make problems ?
        • Vetiundefined
          Veti
          what do you mean strange temperature.
          pla does not normally need 250c to print
          • lui2004undefined
            lui2004
            i know, usually i print with 200-205°C
            you think is a thermistor problem or i need a new heater cartridge ?
            i have remake pid tuning ,still the same i can print pla only with min. 250°C
            • Vetiundefined
              Veti @lui2004
              @lui2004 said in After Micro swiss DD upgrade,Extruder skips steps:
              pid tuning does not change the reported temperature.
              this is an indication of a wrong configuration.
              which thermistor are you using at the moment and what is your config line for it?
              • lui2004undefined
                lui2004 @Veti
                @Veti
                I have this :
                M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
                M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                M143 H1 S300 								   ; set temperature limit for heater 1 to 300C
                M307 H1 B0 S1.00
                NTC-Thermistor 100 K 3950
                Thermistor Cartridge:
                Size: 1.25mmx2.0mm glass bead
                High accuracy: 1%
                Resistance value at 25°C=100K
                Wiring length: 1m / 39.3"
                Operating temperature range: -40 ° C + 300 ° C
                Rated power: 45MW
                • Vetiundefined
                  Veti
                  yeah that is why i dont like B3950 thermistors. the reported temperature can be way off.
                  • lui2004undefined
                    lui2004 @Veti
                    @Veti so the Problem is the thermistor?
                    So i will wait the New one
                    • Vetiundefined
                      Veti
                      most likely yes.
                      • lui2004undefined
                        lui2004 @Veti
                        @Veti
                        i have installed the new thermistor but i can print pla with 235°C i dont now why
                        • Vetiundefined
                          Veti @lui2004
                          @lui2004
                          its not uncommon for the 3950 to be off by 20C
                          did you change the beta and C value?
                          lui2004undefined 2 Replies Last reply Reply Quote 0
                          • lui2004undefined
                            lui2004 @Veti
                            @Veti
                            i have installed the Semitec 104GT-2 today
                            my config for this :
                            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
                            M143 H1 S280 								   ; set temperature limit for heater 1 to 300C
                            M307 H1 B0 S1.00
                            • lui2004undefined
                              lui2004 @Veti
                              @Veti
                              thats the thermistor: 104NT-4-R025H42G Semitec Thermistor 100K - NTC
                              i checked the datasheet and the B Value seems to be: 4267 ?
                              datasheet:
                              https://reprapworld.de/datasheets/NTCThermistor_NT-461415.pdf
                              • Vetiundefined
                                Veti @lui2004
                                B and C change the algorithm to steinhart hart. its more accurate.
                                see the table
                                https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors#Section_Thermistor_parameters
                                • lui2004undefined
                                  lui2004 @Veti
                                  @Veti
                                  the config is also ok like that ?
                                  • Vetiundefined
                                    Veti
                                    yes, but its still strange that you need 235 to print pla.
                                    do you have a steel nozzle?
                                    • lui2004undefined
                                      lui2004 @Veti
                                      @Veti
                                      yes, hardened steel with Micro Swiss all metal hotend
                                      • Vetiundefined
                                        Veti @lui2004
                                        @lui2004 ]
                                        ok steel nozzle a very bad for printing pla. the thermal transfer is very low.
                                        unless you are printing abrasive materials, a brass nozzle is a lot better.
                                        or if you want a much better nozzle, there are copper plated nozzles
                                        https://de.aliexpress.com/item/4000007458595.html
                                        • lui2004undefined
                                          lui2004 @Veti
                                          @Veti
                                          i print only PLA and Petg
                                          • Vetiundefined
                                            Veti
                                            then there is no need for a steel nozzle
