Toolboard Heater Tuning and Fan Error
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"vcore" ; set printer name M669 K1 ; select CoreXY mode ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S0 ; physical drive 0.2 goes forwards M569 P0.3 S0 ; physical drive 0.5 goes forwards M569 P0.4 S0 ; physical drive 0.5 goes forwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M569 P121.0 S1 ; physical drive 0.5 goes forwards M584 X0.1 Y0.0 Z0.2:0.3:0.4 E0.5:121.0 ; set drive mapping M350 E16 I0 ; configure microstepping without interpolation M350 X32 Y32 Z64 I1 ; configure microstepping with interpolation M92 X320.00 Y320.00 Z3200.00 E830.00 ; set steps per mm M566 X3000.00 Y3000.00 Z60.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z100.00 E250.00 ; set accelerations (mm/s^2) M906 X1900 Y1900 Z1900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M671 X0:200:400 Y50:400:50 S10 ; Position of Leadscrews ;Duet Laser Filament Monitor M591 D0 P5 C"io3.in" R30:130 E3.0 S0 ; tolerance 30 to 130%, 3mm comparison length, diabled ; Pressure Advance Tuning ;M572 D0 S0.1 ;Extruder pressure advance: 0.010 ; Cancel Ringing at the defined Freuquenzy ;M593 F40.5 ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X410 Y385 Z390 S0 ; set axis maxima ; Endstops M574 X1 S1 P"121.io2.in" ; configure active-high endstop for low end on X via pin 121.io2.in M574 Y1 S1 P"io0.in" ; configure active-high endstop for low end on Y via pin io1.in M574 Z2 S2 ; configure Z-probe endstop for high end on Z ; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"^121.io0.in" H8 F120 T9000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height M557 X0:400 Y0:400 S20 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B4100 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S150 ; set temperature limit for heater 0 to 150C M308 S1 P"121.temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S500 ; set temperature limit for heater 1 to 500C M308 S2 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp2 M950 H2 C"out2" T2 ; create chamber heater output on out1 and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit M141 H2 ; map chamber to heater 2 M143 H2 S200 ; set temperature limit for heater 2 to 200C ; Heater Model Parameters M307 H0 R0.641 C945.3 D3.18 S1.00 V24.1 ; PID Parameters Heated Bed ; PID Parameters BuildChamber ; PID Parameters E3D Volcano ; Fans M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 ; set fan 0 name and value. Thermostatic control is turned on M950 F1 C"121.out1" Q500 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off ; Tools M563 P0 S"Mosquito Magnum" D0 H1 F0:1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"E3D Volcano" D0 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined M912 P0 S-14.8 ; MCU Temperature Calibration ; Miscellaneous T0 ; select first tool -
@Frederik said in Toolboard Heater Tuning and Fan Error:
you are missing the config for the second extruder
what does the bltouch show in the ui when its not deployed?
@Veti the second extruder is for my "fast switching" bowden - direct drive setup.
I used the so-called EVA mod for my printhead, I only have to change 2 screws and 1 piece of plastic to convert my setup from direct to Bowden and vice versa. the Extruder is driven from the Toolboard stepper driver.
This Toolhead can be used for a Hemera, volcano, mosquito or dragon Hotend, standard or Idex, and with BMG or Titan extruders.
when in Bowden mode: the duet 3 mainboard drives it
but I don't want to switch config... only hardware changes
at the moment Iยดm looking for a solution on how to properly mount the tool board when I use the Bowden setup.
when in direct drive I've mounted it on the backside of the Nema with a printed holder.
its a really nice design,
@Veti Z-Probe 0
and the red and blue lights are constantly on.
when doing a standard homeZ. it works fine.
but when i try to do a mesh with 20mm spacing, it stops with the same error message after a random number of points.. sometimes 40 spots , sometimes only 15 spots
a lot of the bltouch problems come from bad wiring.
@Veti perhaps this one is software related.
when i restart the printer without touching the head, it works perfekt....sometimes up to 10 times in a row ..
@Veti and when the error occurs, the bltouch is blinkin red and in the dwc i can read z-probe 1000
have you updated the bootloader?
https://forum.duet3d.com/topic/19211/bltouch-and-duet-3-tool-board/22
19.12.2020, 14:47:20 m122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.2-beta4.1 (2020-12-03) Bootloader ID: not available Never used RAM 4180, free system stack 84 words HEAT 50 CanAsync 89 CanRecv 83 TMC 54 MAIN 218 AIN 64 Last reset 00:24:45 ago, cause: VDD brownout Last software reset data not available Driver 0: position 0, 830.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 21603, writes 12, timeouts 0, DMA errors 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.1V MCU temperature: min 43.5C, current 43.6C, max 46.0C Ticks since heat task active 54, ADC conversions started 1479264, completed 1479263, timed out 0 Last sensors broadcast 0x00000002 found 1 58 ticks ago, loop time 0 CAN messages queued 18185, send timeouts 0, received 13832, lost 0, free buffers 36 -
the bootloader not the firmware. please read the thread.
Is it to do with the BLtouch being on the toolboard but the z drivers being on the main board?
I believe the restriction is still in place about the probe being in a different board -
@Veti yes , but it says bootloader not available, and i cant find the file. i Have to update via can, do i need the ToolLc1 firmware also or only the bootloader file ?
whats the error message when you issue the bootloader update?
the bootloader files are here as its written in the documentation.
https://github.com/Duet3D/Duet3Bootloader/releases -
@Veti bootloader not found
I looked again in the toolboard documentation, but i cant find the link to the bootloader, there is only a link to GitHub with the step files....
do i need only the samc21.bin or the .elf file also?
any additional files needed?
i added the 3 lines for the workaround also to the end of my config.g
i will test if now the mesh completes without errors
@Veti the samc21 from your link worked.
m997 b121 s3
Board 121 starting bootloader update
19.12.2020, 15:45:56 Datei Duet3Bootloader-SAMC21.bin erfolgreich nach 0s hochgeladen
now, iยดm really curious what the bltouch does
@Veti
after the update :m122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.2-beta4.1 (2020-12-03) Bootloader ID: SAMC21 bootloader version 2.1 (2020-11-03b2) Never used RAM 4668, free system stack 96 words HEAT 50 CanAsync 89 CanRecv 83 TMC 54 MAIN 338 AIN 64 Last reset 00:02:38 ago, cause: software Last software reset data not available Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 22, reads 13732, writes 9, timeouts 0, DMA errors 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.1V MCU temperature: min 42.0C, current 42.0C, max 42.3C Ticks since heat task active 85, ADC conversions started 158578, completed 158577, timed out 0 Last sensors broadcast 0x00000000 found 0 88 ticks ago, loop time 0 CAN messages queued 16, send timeouts 0, received 1436, lost 0, free buffers 36 Is that the right combination of firmwares ?
i am using DWC 3.2.0beta4m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 123292 Dynamic ram: 139216 of which 140 recycled Never used RAM 129544, free system stack 126 words Tasks: Linux(ready,101) HEAT(blocked,272) CanReceiv(blocked,829) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,20) MAIN(running,669) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:23:02 ago, cause: power up Last software reset at 2020-12-19 15:22, reason: User, none spinning, available RAM 129752, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xffffffff Task Linu Error status: 0x00 MCU temperature: min 27.7, current 31.2, max 42.6 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 72800, standstill, reads 18438, writes 31 timeouts 0, SG min/max 0/248 Driver 1: position 4000, standstill, reads 18439, writes 31 timeouts 0, SG min/max 0/244 Driver 2: position 6400, standstill, reads 18440, writes 31 timeouts 0, SG min/max 0/246 Driver 3: position 0, standstill, reads 18440, writes 31 timeouts 0, SG min/max 0/245 Driver 4: position 0, standstill, reads 18441, writes 31 timeouts 0, SG min/max 0/244 Driver 5: position 0, standstill, reads 18459, writes 14 timeouts 0, SG min/max 0/0 Date/time: 2020-12-19 15:51:23 Slowest loop: 182.07ms; fastest: 0.09ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === FreeDm 375 (min 372), maxWait 436239ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 49, completed moves 49, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0: no data received === CAN === Messages queued 5738, send timeouts 0, received 12611, lost 0, longest wait 3ms for reply type 6049, free buffers 47 === SBC interface === State: 0, failed transfers: 0 Last transfer: 19ms ago RX/TX seq numbers: 47923/47924 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x209d8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0-beta4 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 30.23 -
@Veti the bootloader doesent make a big difference
this time, it completes perhaps 40% of my build area bevor it stops and starts blinking.
the workaround lines of code are also in place....
@Frederik You could try a lower speed in M558. I use 6000.
@Stephen6309 i will try, moment
you could also try adjusting the grub screw on the top of the bltouch.
