Toolboard Heater Tuning and Fan Error
@Veti and when the error occurs, the bltouch is blinkin red and in the dwc i can read z-probe 1000
have you updated the bootloader?
https://forum.duet3d.com/topic/19211/bltouch-and-duet-3-tool-board/22
19.12.2020, 14:47:20 m122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.2-beta4.1 (2020-12-03) Bootloader ID: not available Never used RAM 4180, free system stack 84 words HEAT 50 CanAsync 89 CanRecv 83 TMC 54 MAIN 218 AIN 64 Last reset 00:24:45 ago, cause: VDD brownout Last software reset data not available Driver 0: position 0, 830.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 21603, writes 12, timeouts 0, DMA errors 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.1V MCU temperature: min 43.5C, current 43.6C, max 46.0C Ticks since heat task active 54, ADC conversions started 1479264, completed 1479263, timed out 0 Last sensors broadcast 0x00000002 found 1 58 ticks ago, loop time 0 CAN messages queued 18185, send timeouts 0, received 13832, lost 0, free buffers 36
the bootloader not the firmware. please read the thread.
Is it to do with the BLtouch being on the toolboard but the z drivers being on the main board?
I believe the restriction is still in place about the probe being in a different board -
@Veti yes , but it says bootloader not available, and i cant find the file. i Have to update via can, do i need the ToolLc1 firmware also or only the bootloader file ?
whats the error message when you issue the bootloader update?
the bootloader files are here as its written in the documentation.
https://github.com/Duet3D/Duet3Bootloader/releases -
@Veti bootloader not found
I looked again in the toolboard documentation, but i cant find the link to the bootloader, there is only a link to GitHub with the step files....
do i need only the samc21.bin or the .elf file also?
any additional files needed?
i added the 3 lines for the workaround also to the end of my config.g
i will test if now the mesh completes without errors
@Veti the samc21 from your link worked.
m997 b121 s3
Board 121 starting bootloader update
19.12.2020, 15:45:56 Datei Duet3Bootloader-SAMC21.bin erfolgreich nach 0s hochgeladen
now, iยดm really curious what the bltouch does
@Veti
after the update :m122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.2-beta4.1 (2020-12-03) Bootloader ID: SAMC21 bootloader version 2.1 (2020-11-03b2) Never used RAM 4668, free system stack 96 words HEAT 50 CanAsync 89 CanRecv 83 TMC 54 MAIN 338 AIN 64 Last reset 00:02:38 ago, cause: software Last software reset data not available Driver 0: position 0, 80.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 22, reads 13732, writes 9, timeouts 0, DMA errors 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.1V MCU temperature: min 42.0C, current 42.0C, max 42.3C Ticks since heat task active 85, ADC conversions started 158578, completed 158577, timed out 0 Last sensors broadcast 0x00000000 found 0 88 ticks ago, loop time 0 CAN messages queued 16, send timeouts 0, received 1436, lost 0, free buffers 36
Is that the right combination of firmwares ?
i am using DWC 3.2.0beta4m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 123292 Dynamic ram: 139216 of which 140 recycled Never used RAM 129544, free system stack 126 words Tasks: Linux(ready,101) HEAT(blocked,272) CanReceiv(blocked,829) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,20) MAIN(running,669) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:23:02 ago, cause: power up Last software reset at 2020-12-19 15:22, reason: User, none spinning, available RAM 129752, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xffffffff Task Linu Error status: 0x00 MCU temperature: min 27.7, current 31.2, max 42.6 Supply voltage: min 24.0, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 72800, standstill, reads 18438, writes 31 timeouts 0, SG min/max 0/248 Driver 1: position 4000, standstill, reads 18439, writes 31 timeouts 0, SG min/max 0/244 Driver 2: position 6400, standstill, reads 18440, writes 31 timeouts 0, SG min/max 0/246 Driver 3: position 0, standstill, reads 18440, writes 31 timeouts 0, SG min/max 0/245 Driver 4: position 0, standstill, reads 18441, writes 31 timeouts 0, SG min/max 0/244 Driver 5: position 0, standstill, reads 18459, writes 14 timeouts 0, SG min/max 0/0 Date/time: 2020-12-19 15:51:23 Slowest loop: 182.07ms; fastest: 0.09ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === FreeDm 375 (min 372), maxWait 436239ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 49, completed moves 49, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0: no data received === CAN === Messages queued 5738, send timeouts 0, received 12611, lost 0, longest wait 3ms for reply type 6049, free buffers 47 === SBC interface === State: 0, failed transfers: 0 Last transfer: 19ms ago RX/TX seq numbers: 47923/47924 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x209d8 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0-beta4 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 30.23
@Veti the bootloader doesent make a big difference
this time, it completes perhaps 40% of my build area bevor it stops and starts blinking.
the workaround lines of code are also in place....
@Frederik You could try a lower speed in M558. I use 6000.
@Stephen6309 i will try, moment
you could also try adjusting the grub screw on the top of the bltouch.
@Stephen6309 speed to 6000 - same error
@Veti one moment , i will try
@Veti i changed the mesh size from 20mm to 75mm and it completed the whole area without error.
@Veti how can i delete a used thermistor pin ?
since the last change of my config.g , i get a heater fault and open circuit, but the cables are ok
@Frederik said in Toolboard Heater Tuning and Fan Error:
dont define it the in the config.
@Veti i deleted it already, my heated bed is ok. the thermistor has 100.8k resistance , but i cant get them to wrok after the config change
post the changes you made
