    Trianglelab Matrix Extruder somebody?
    3D Printing General Chat
    10
    66
    7.8k
    • DaBitundefined
      DaBit
      I like the Bondtech stuff. Was running the QR, now I am running the BMG-X2. Exactly zero issues with those.
      The only thing I don't like about them is the plastic they use (lasersintered nylon?). It is fairly soft and it tends to deform slightly when used above a 100-110C bed in an enclosed chamber which also heats up to 60C or so in those conditions. Internal stresses I suppose.
      That is why I am interested in the Hemera above Bondtech; housing is made of metal, gears are made of metal.
      Chrissundefined Vetiundefined 2 Replies Last reply Reply Quote 0
      • Chrissundefined
        Chriss @DaBit
        The new bondtech looks promising too. But I guess that the availability will be limited for a long time. 😉
        I have a bontech at the moment and I'm very happy with it. So I want to give E3D a try, I think it is worth the time to play with one of there products.
        On the other hand seams the copperhead with a bondtech extruder a very promising concept as well. ❓
        • Vetiundefined
          Veti @DaBit
          @DaBit said in Trianglelab Matrix Extruder somebody?:
          just wait a few months, someone in china is gonna do a water cooled version of it 🙂
          • Vetiundefined
            Veti @Chriss
            @Chriss said in Trianglelab Matrix Extruder somebody?:
            well you can use the copperhead with the hermera as well.
            see toms review of it
            https://www.youtube.com/watch?v=1YU6Ehwiu4A
            • Vetiundefined
              Veti
              thinking about the bondtech lgx a bit more.
              the weight should be comparable with this
              https://de.aliexpress.com/item/4000983379658.html
              slap a copperhead on it and you can buy it today.
              • PCRundefined
                PCR
                Came today! Quality wise its seems very good. Mostly Metal. Only the Lever is out of Plastic.
                I would order a spare heatbreak. Looks very delicate. But its nice to see that its not hold by only a grub screw. They machined a extra inlay for it!
                WhatsApp Image 2020-12-14 at 11.31.44.jpeg WhatsApp Image 2020-12-14 at 11.d31.44.jpeg WhatsApp Image 2020-12-d14 at 11.31.44.jpeg WhatsApp Image 2020-12-14 at d11.31.44.jpeg WhatsApp Image 202d0-12-14 at 11.31.44.jpeg WhatsApp Image 2020-12-14 at 11.36.00.jpeg
                Chrissundefined 1 Reply Last reply Reply Quote 0
                • DaBitundefined
                  DaBit
                  By using the surgical stainless tubing at least they have a heatbreak with a very smooth inner wall and low heat transmission. Works very well. I did the same on my homebrewn hotend (but I used some RVS304 M2 threaded rod to support that thin tube), and that one performed better than the Chimera I am running now, especially with flexibles.
                  That lever looks like it is prone to deform in slightly higher ambient temperatures, but judging based on the pictures it is fairly easy to replicate in metal.
                  Thanks for the pictures!
                  (my LC one has not shipped yet)
                  • Chrissundefined
                    Chriss @PCR
                    @PCR
                    Does not look bad, thanks for the pictures. Let's we how the pair I will get look like. 😉
                    • PCRundefined
                      PCR
                      @Chriss
                      nice review i found
                      https://3dprintbeginner.com/trianglelab-matrix-extruder-review-hemera-alternative/
                      • hackinistratorundefined
                        hackinistrator
                        i dont like how the heater block is held only by the tiny surgical tube .
                        this tube is press fit bi metal . i have this kind of tube on v6 , also made by trianglelab and i can spin the heater block while holding the cold side .
                        • DaBitundefined
                          DaBit
                          In case that's really an issue it is quite easy to add a small bit of silver braze. That's how I connected surgical tubing directly to brass nozzles in my DIY hotend (heatbreak and nozzle were one part in that design).
                          • Chrissundefined
                            Chriss
                            My pair of matrix came yesterday evening. They look like a okish deal to me. The surface of the milled parts do not look very bad but not as good as it could, well the price is the point here.
                            Funny to see the CN fluctuation here, my pair did not came with nozzles. That is a nobrainer, I have enough of them here but funny to see. 😉
                            I'm surprised how heavy the complete tool is. I have the feeling that my bondtech head on my corexy is a lot lighter. But I may be wrong, that is just my impression.
                            • Vetiundefined
                              Veti @Chriss
                              my bmg wind arrived, and it is very light, as you can use a pancake motor with it.
                              so far the print results are very good.
                              • DaBitundefined
                                DaBit
                                My LC has arrived too.
                                Package is complete; all cables and things are in:
                                Looks OK on the outside:
                                Screw thread for the pillars is M6.
                                Heatbreak is a one-piece thing, or so it seems (did not pull it out).
                                3 of the 4 screws hold the aluminium cooling block in place. Guess which one does not 😀
                                The inside:
                                Slave drivewheel runs directly in the plastic lever, I don't like that. Bearings are the cheap ones that go crunchy quickly. Oh well, it is built for a price.
                                Gears are metal, well formed teeth, with neither too little or too much grease applied:
                                Heatbreak could have been extended a bit more towards the drive wheel:
                                But oh well, this probably works OK too.
                                It will take a while before I can actually test it, but the first impression is quite positive.
                                  A Former User
                                  👍 detailed review! Surprisingly well built, but it's still a fair bit of change. Not sure what I'd choose today, but thanks for sharing.
                                  Edit: throw it on a scale when you find the time?
                                  • DaBitundefined
                                    DaBit
                                    I am still designing for 150C chamber temperature, and with a bit of extra cooling this thing might be able to handle that just fine. Except for the plastic lever probably.
                                    If it does, it is still a fairly cheap device for such a hostile environment.
                                    I will throw it on a scale tomorrow.
                                    • DaBitundefined
                                      DaBit
                                      Totally forgot to put it on the scale, sorry.
                                      Here is the weight:
                                      • arhiundefined
                                        arhi
                                        One thing I'd love for you to test, use a metal file and try to file a teet grabbing filament (somewhere on the side, not in the middle where is important. If the teeth are hardened (like on bondtech and some PRC clones) that's awesome and file will not bite and will just slide over them, if the file bites than it's not good for "complex" materials... not a big deal but would be good to know
                                        • DaBitundefined
                                          DaBit
                                          Good test indeed. I will do that when I have it apart again.
                                          (Which I probably will; that plastic handle certainly cannot handle the 150C environment I plan to test, so I want to measure and CADify it.)
                                          I do print carbon-filled filaments from time to time, so if they are not hardened I probably want a set of spare drive gears.
                                          • arhiundefined
                                            arhi @DaBit
                                            yup, they grind the teeth flat rather quickly if not hardened ... or tbh, they grind the brass teeth quickly, I never tried untreated steel teeth (both original and prc clone bondtech I have are with hardened teeth)
