    Trianglelab Matrix Extruder somebody?
    3D Printing General Chat
    10
    66
    8.0k
    • Vetiundefined
      Veti @DaBit
      @DaBit said in Trianglelab Matrix Extruder somebody?:
      It is fairly soft and it tends to deform slightly when used above a 100-110C bed in an enclosed chamber which also heats up to 60C or so in those conditions. Internal stresses I suppose.
      just wait a few months, someone in china is gonna do a water cooled version of it 🙂
      • Vetiundefined
        Veti @Chriss
        @Chriss said in Trianglelab Matrix Extruder somebody?:
        On the other hand seams the copperhead with a bondtech extruder a very promising concept as well.
        well you can use the copperhead with the hermera as well.
        see toms review of it
        https://www.youtube.com/watch?v=1YU6Ehwiu4A
        • Vetiundefined
          Veti
          thinking about the bondtech lgx a bit more.
          the weight should be comparable with this
          https://de.aliexpress.com/item/4000983379658.html
          slap a copperhead on it and you can buy it today.
          • PCRundefined
            PCR
            Came today! Quality wise its seems very good. Mostly Metal. Only the Lever is out of Plastic.
            I would order a spare heatbreak. Looks very delicate. But its nice to see that its not hold by only a grub screw. They machined a extra inlay for it!
            WhatsApp Image 2020-12-14 at 11.31.44.jpeg WhatsApp Image 2020-12-14 at 11.d31.44.jpeg WhatsApp Image 2020-12-d14 at 11.31.44.jpeg WhatsApp Image 2020-12-14 at d11.31.44.jpeg WhatsApp Image 202d0-12-14 at 11.31.44.jpeg WhatsApp Image 2020-12-14 at 11.36.00.jpeg
            Chrissundefined 1 Reply Last reply Reply Quote 0
            • DaBitundefined
              DaBit
              By using the surgical stainless tubing at least they have a heatbreak with a very smooth inner wall and low heat transmission. Works very well. I did the same on my homebrewn hotend (but I used some RVS304 M2 threaded rod to support that thin tube), and that one performed better than the Chimera I am running now, especially with flexibles.
              That lever looks like it is prone to deform in slightly higher ambient temperatures, but judging based on the pictures it is fairly easy to replicate in metal.
              Thanks for the pictures!
              (my LC one has not shipped yet)
              • Chrissundefined
                Chriss @PCR
                @PCR
                Does not look bad, thanks for the pictures. Let's we how the pair I will get look like. 😉
                • PCRundefined
                  PCR
                  @Chriss
                  nice review i found
                  https://3dprintbeginner.com/trianglelab-matrix-extruder-review-hemera-alternative/
                  • hackinistratorundefined
                    hackinistrator
                    i dont like how the heater block is held only by the tiny surgical tube .
                    this tube is press fit bi metal . i have this kind of tube on v6 , also made by trianglelab and i can spin the heater block while holding the cold side .
                    • DaBitundefined
                      DaBit
                      In case that's really an issue it is quite easy to add a small bit of silver braze. That's how I connected surgical tubing directly to brass nozzles in my DIY hotend (heatbreak and nozzle were one part in that design).
                      • Chrissundefined
                        Chriss
                        My pair of matrix came yesterday evening. They look like a okish deal to me. The surface of the milled parts do not look very bad but not as good as it could, well the price is the point here.
                        Funny to see the CN fluctuation here, my pair did not came with nozzles. That is a nobrainer, I have enough of them here but funny to see. 😉
                        I'm surprised how heavy the complete tool is. I have the feeling that my bondtech head on my corexy is a lot lighter. But I may be wrong, that is just my impression.
                        • Vetiundefined
                          Veti @Chriss
                          my bmg wind arrived, and it is very light, as you can use a pancake motor with it.
                          so far the print results are very good.
                          • DaBitundefined
                            DaBit
                            My LC has arrived too.
                            Package is complete; all cables and things are in:
                            Looks OK on the outside:
                            Screw thread for the pillars is M6.
                            Heatbreak is a one-piece thing, or so it seems (did not pull it out).
                            3 of the 4 screws hold the aluminium cooling block in place. Guess which one does not 😀
                            The inside:
                            Slave drivewheel runs directly in the plastic lever, I don't like that. Bearings are the cheap ones that go crunchy quickly. Oh well, it is built for a price.
                            Gears are metal, well formed teeth, with neither too little or too much grease applied:
                            Heatbreak could have been extended a bit more towards the drive wheel:
                            But oh well, this probably works OK too.
                            It will take a while before I can actually test it, but the first impression is quite positive.
                              A Former User
                              👍 detailed review! Surprisingly well built, but it's still a fair bit of change. Not sure what I'd choose today, but thanks for sharing.
                              Edit: throw it on a scale when you find the time?
                              • DaBitundefined
                                DaBit
                                I am still designing for 150C chamber temperature, and with a bit of extra cooling this thing might be able to handle that just fine. Except for the plastic lever probably.
                                If it does, it is still a fairly cheap device for such a hostile environment.
                                I will throw it on a scale tomorrow.
                                • DaBitundefined
                                  DaBit
                                  Totally forgot to put it on the scale, sorry.
                                  Here is the weight:
                                  • arhiundefined
                                    arhi
                                    One thing I'd love for you to test, use a metal file and try to file a teet grabbing filament (somewhere on the side, not in the middle where is important. If the teeth are hardened (like on bondtech and some PRC clones) that's awesome and file will not bite and will just slide over them, if the file bites than it's not good for "complex" materials... not a big deal but would be good to know
                                    • DaBitundefined
                                      DaBit
                                      Good test indeed. I will do that when I have it apart again.
                                      (Which I probably will; that plastic handle certainly cannot handle the 150C environment I plan to test, so I want to measure and CADify it.)
                                      I do print carbon-filled filaments from time to time, so if they are not hardened I probably want a set of spare drive gears.
                                      • arhiundefined
                                        arhi @DaBit
                                        yup, they grind the teeth flat rather quickly if not hardened ... or tbh, they grind the brass teeth quickly, I never tried untreated steel teeth (both original and prc clone bondtech I have are with hardened teeth)
                                        • DaBitundefined
                                          DaBit
                                          Well, those gears are produced from some sort of tool steel anyway since it machines so much better than low-carbon unalloyed steel.
                                          These shaft holders are made from 1.2510 tool steel (with aluminium the shafts would be loose in the holders at 150C, hence steel), hardness as delivered around HRC23. Bores and other features are nice and smooth after machining, even with a simple helical toolpath:
                                          And this is simple hot-rolled steel, same machine, same endmill:
                                          Difference in finish is well visible. Compare that to the picture of the drive gear, so they use at least something similar. Brass would be 1/2 the hardness.
                                          On the other hand I hope they did not make the teeth too hard. That would fracture them over time.
                                          • Chrissundefined
                                            Chriss
                                            Hi *,
                                            Let me come back to the topic. 😉
                                            Does anybody have some infos about the shipped thermistor? (24V)
                                            I have the golden (brass) tube and a spring at the end of the cable. It looks like :
                                            https://de.aliexpress.com/item/33029709571.html?spm=a2g0x.12010612.8148356.14.2b3743aavUups2 but with a spring like https://de.aliexpress.com/item/4000907614466.html?spm=a2g0x.12010612.8148356.2.2b3743aavUups2
                                            I'm totally confused now.
                                            Does anybody have some settings which work fine? Is anybody willing to share them and ideally the "M307" for the hotend. I have them connected to a toolboard which can not auto tune the pid. 😞
                                            Cheers, Chriss
