Controlled arc problem
Hi there, trying to finish commissioning a duet2 wifi and the G2 command is producing weird results. Has anyone experienced this or know how to troubleshoot?
With the machine set at X25 Y0 (S in the picture)
I'm instructing a G2 X0 Y-25 I-25 J0. The result is the pink line in the attached picture.
Help would be gratefully received!! -
Is it possible you hit the allowed maximum coordinate there? If a circle goes off the allowed bed boundaries, this can happen.
Hi Mendenmh, I re-checked the limits:
M208 X-100 Y-100 Z-20 S1 ; set axis minima
M208 X745 Y760 Z30 S0 ; set axis maximaSo I'm trying to draw a 25mm radius arc around the origin - I might be blind to something limiting it here?
Neil -
@neilo I ran your GCODE in this simulator (The only one I know that simulates arcs correctly) and it looks right.
https://nraynaud.github.io/webgcode/
G0 x25 y0
G2 X0 Y-25 I-25 J0Try smaller arcs, a complete circle, some G1 moves etc, or first move the head to a different position to get some more information.
Which firmware version are you using?
I have nothing to contribute to this discussion, except that the title makes me think of my many feeble attempts at welding...
@dc42 Hi there I'm using RRF 3.1.1. Is it worth giving the latest version a go? (3.2)
@alankilian I'll try some other moves in the meantime today
Cheers
Yes, please try firmware 3.2RC2.
@dc42 sorry it's not clear to me whether I can go direct from 3.1.1 to 3.2 RC2? The RC2 release notes say the iap files have not changed since RC1 but cannot see them in the RC1 area to copy across.
Also RC1 notes state: "Users of Duet + Single Board Computer should upgrade from the packager server as usual." Not clear to me where/what the package server is!
Thanks,
Neil -
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2RC1
There are 4 files with SDiap32 in their names.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
You can find the instructions for adding the unstable branch package server here.
Thanks very much for your assistance, the good news is that the firmware upload (RRF3.2RC2)went fine, the bad news is that the mis-behaviour is still present.
For example a simple square is not completing (fig 1)
or a sequence of simple moves (fig 2) .
This time I've uploaded the config and gcode files for the above if someone could please spot the deliberate mistake
arc.g
squaretest.g -
Your 'squaretest' file has only G1 moves, right? Are you sure you aren't missing steps due to a mechanical or electrical problem?
I've used a Duet 2 board running RepRapFirmware for Duet 2 WiFi/Ethernet 3.2-beta1 (2020-09-15b1) with a homebrew CNC to machine a test piece containing diamond, circle and square sections:
The g-code for this with a 5mm diameter end mill is as follows and contains both G2 and G3 commands that the Duet appears to have executed correctly:
The finishing passes for the circular section are complete circles so one assumes should have shown up the same sort of error you're seeing if this was intrinsic to the Duet hardware/firmware?
Perhaps trying this g-code file might help diagnose the problem?
@whopping-pochard that's right just trying to keep it simple with G1 commands in one file. I've added another test (fig 3)
and it appears to act erratically. Mechanically it looks fine, it's belt drive on X and Y NEMA 23 FYI .
steps.g -
@cjm just seen your post - many thanks I will try it out tomorrow.
@cjm here is the result: Still looks weird and clearly incorrect. I used a 1/4 inch bit so slight dimensional difference but does not explain for me the strange behaviour.
Would you mind sharing your config.g file with me please?
Thanks,
Neil -
@neilo I think this is a mechanically issue. My best guess is that the X pulley is slipping on the motor shaft, because the first move of any change in direction in X causes the movement error, but subsequent ones do not. Probably the grub screw on the pulley is loose, allowing a limited range of movement.
I second @droftarts opinion; circles with horizontal and vertical flat spots (i.e. corresponding to the direction change of the x respectively the y axis) indicate mechanical backlash, quite noticable in your case.
One way to test this theory is to make a square, but rotated 90-degrees.
That way, you get two reversals of each axis while the other axis is moving continuously in the same direction.
You'll see the vertices get messed up if you've got a lot of backlash.
AND you can do it with just G1 moves.
@alankilian said in Controlled arc problem:
Don't you mean 45 degrees?!
