    Duet 3 Mini 5+ sensorless homing configuration
    solved
    8
    42
    4.2k
    • Vetiundefined
      Veti
      i just tried with the highest sensitivity and could not get the sensorless homing to trigger.
      @dc42 any suggestions?
        dc42 administrators @Veti
        The critical point in the doc on stall detection for the Duet 3 Mini is this:
        Additionally, the TMC2209 stepper driver used in Duet 3 Mini 5+ (and Duet 3 Tool board TOOL1LC once stallGuard is implemented in firmware), features stallGuard 4. This is optimised for operation with stealthChop, while its predecessor stallGuard 2 (TMC5160 and TMC2260) works with spreadCycle. You will need to adjust the speed at which stealthChop changes over to spreadCycle. This is set by M569 V parameter. The default is 2000.
        You will need to reduce the V parameter (at least during homing) so that at the speed of the homing move, the driver is operating in stealthChop mode. By default it is only in stealthChop mode at very low speeds, too low for homing moves. See the M569 command.
        • Vetiundefined
          Veti @dc42
          my steppers are running in stealhchop with up to 120mm/sec, still it would not trigger
            Confirm you are using firmware 3.2RC2 ?
            What does M569 P# report, for values of # corresponding to the drivers for the axes you are trying to home?
            • Vetiundefined
              Veti @flobler
              @flobler
              can you also with stealthchop.
              @dc42 i configured back, and running a print, but these are the settings that i am running all the time
              30/12/2020, 20:19:44 M569 P0
              Drive 0 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 30 (125.0 mm/sec), pwmScaleSum 222, pwmScaleAuto 27, pwmOfsAuto 64, pwmGradAuto 22, pos 584
              Drive 1 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 30 (125.0 mm/sec), pwmScaleSum 73, pwmScaleAuto 0, pwmOfsAuto 57, pwmGradAuto 19, pos 611
                Please post your config.g file again, because the M569 commands in the one you posted earlier do not maintain stealthChop mode up to 120mm/sec.
                floblerundefined 1 Reply Last reply Reply Quote 0
                  jay_s_uk
                  we've had good success with sensorless homing on the LPC port using D3 V40 after each M569 for the axis being homed.
                  we typically suggest running
                  M915 P0 S-63 H10 R1 ; Set very sensitive stall detect
                  M574 X1 S3 ; configure endstop for stall detection
                  G1 X200 H1 ; Should stall pretty much immediately
                  to ensure that everything is working correctly. You can then tweak as required to work on your system
                  • floblerundefined
                    flobler @dc42
                    @dc42 that was me who posted the config ๐Ÿ™‚
                    I can confirm that I am running 3.2RC2. I will reduce the V parameter and try again. I will report back.
                    Thanks for the help!
                    • Vetiundefined
                      Veti @jay_s_uk
                      @jay_s_uk said in Duet 3 Mini 5+ sensorless homing configuration:
                      tried it again with your settings and the motors keep grinding away
                        jay_s_uk @Veti
                        @Veti even with setting S to -63?
                        If it doesn't immediately trigger that means there's something not right somewhere.
                        I can maybe have a go with it this morning with mine.
                        Will report back
                        • Vetiundefined
                          Veti
                          i even tried with -64
                            jay_s_uk
                            I can also confirm that sensorless homing does not appear to be working on the mini5+ with RC2.
                              dc42 administrators @jay_s_uk
                              It worked for me during testing. I will try to find the configuration that I used.
                              • gregsaunundefined
                                gregsaun
                                Thanks everyone for helping @flobler , he is working on an official Bear config for the Mini 5+ ๐Ÿ™‚
                                github.com/gregsaun - Papa Bear
                                • floblerundefined
                                  flobler
                                  Yeah, thanks for the help everyone, really appreciated!
                                  I just wanted to add that I am using version 0.4 of the Mini 5+. I also tried all the above and sensorless homing did not work for me. Motor was operating in stealthChop.
                                  • floblerundefined
                                    flobler
                                    Actually, that combo got it to stall the first time I tried homing X. It stalled immediately when trying to move.
                                    homex.g config.g
                                    What is weird though is that it did not work afterwards again. I need to power cycle the printer (emergency stop did not do it) for it to work again and then again it only works on the first try. This worked 5/5 times so far.
                                      Bear in mind that you need to execute a tuning procedure when using stealthChop mode.
                                      • floblerundefined
                                        flobler
                                        Thanks! Just found the docs on that. Will apply and report back.
                                        • floblerundefined
                                          flobler @dc42
                                          @dc42 I think I made progress.
                                          I am still only trying to home X for testing purposes. Here is the config: homex.g
                                          config.g
                                          Initially when first I power on the printer and then try to home X, it does result in a crash. But if I then press the emergency stop to end the crash and tell X to home again, X homes successfully (not elegant yet but it homes).
                                          Homing then works until I power cycle the printer or use the emergency stop. Once I do that I am back at the start. Homing X results in a crash, then I use the emergency stop and after that I can repeatedly home X successfully until I power cycle the printer or use the emergency stop again.
                                          I suspect this must have something to to with how I configured homex.g...
                                            You need to run the stealthChop tuning procedure first. You can do this is the homing files.This is what I suggest:
                                            1. Execute a tiny move (1 or 2 microsteps) away from the homing direction.
                                            2. Pause for 100ms using G4.
                                            3. Execute a small move away from the homing direction, e.g. 10mm.
                                            4. Execute the homing move.
                                            Don't forget to reduce current for the homing move (M913).
                                            floblerundefined 1 Reply Last reply Reply Quote 1
