    Duet 3 Mini 5+ sensorless homing configuration
    solved
    8
    42
    4.2k
      Please post your config.g file again, because the M569 commands in the one you posted earlier do not maintain stealthChop mode up to 120mm/sec.
      floblerundefined 1 Reply Last reply Reply Quote 0
        jay_s_uk
        we've had good success with sensorless homing on the LPC port using D3 V40 after each M569 for the axis being homed.
        we typically suggest running
        M915 P0 S-63 H10 R1 ; Set very sensitive stall detect
        M574 X1 S3 ; configure endstop for stall detection
        G1 X200 H1 ; Should stall pretty much immediately
        to ensure that everything is working correctly. You can then tweak as required to work on your system
        • floblerundefined
          flobler @dc42
          @dc42 that was me who posted the config 🙂
          I can confirm that I am running 3.2RC2. I will reduce the V parameter and try again. I will report back.
          Thanks for the help!
          • Vetiundefined
            Veti @jay_s_uk
            @jay_s_uk said in Duet 3 Mini 5+ sensorless homing configuration:
            tried it again with your settings and the motors keep grinding away
              jay_s_uk @Veti
              @Veti even with setting S to -63?
              If it doesn't immediately trigger that means there's something not right somewhere.
              I can maybe have a go with it this morning with mine.
              Will report back
              • Vetiundefined
                Veti
                i even tried with -64
                  jay_s_uk
                  I can also confirm that sensorless homing does not appear to be working on the mini5+ with RC2.
                    dc42 administrators @jay_s_uk
                    It worked for me during testing. I will try to find the configuration that I used.
                    • gregsaunundefined
                      gregsaun
                      Thanks everyone for helping @flobler , he is working on an official Bear config for the Mini 5+ 🙂
                      github.com/gregsaun - Papa Bear
                      • floblerundefined
                        flobler
                        Yeah, thanks for the help everyone, really appreciated!
                        I just wanted to add that I am using version 0.4 of the Mini 5+. I also tried all the above and sensorless homing did not work for me. Motor was operating in stealthChop.
                        • floblerundefined
                          flobler
                          Actually, that combo got it to stall the first time I tried homing X. It stalled immediately when trying to move.
                          homex.g config.g
                          What is weird though is that it did not work afterwards again. I need to power cycle the printer (emergency stop did not do it) for it to work again and then again it only works on the first try. This worked 5/5 times so far.
                            Bear in mind that you need to execute a tuning procedure when using stealthChop mode.
                            • floblerundefined
                              flobler
                              Thanks! Just found the docs on that. Will apply and report back.
                              • floblerundefined
                                flobler @dc42
                                @dc42 I think I made progress.
                                I am still only trying to home X for testing purposes. Here is the config: homex.g
                                config.g
                                Initially when first I power on the printer and then try to home X, it does result in a crash. But if I then press the emergency stop to end the crash and tell X to home again, X homes successfully (not elegant yet but it homes).
                                Homing then works until I power cycle the printer or use the emergency stop. Once I do that I am back at the start. Homing X results in a crash, then I use the emergency stop and after that I can repeatedly home X successfully until I power cycle the printer or use the emergency stop again.
                                I suspect this must have something to to with how I configured homex.g...
                                  You need to run the stealthChop tuning procedure first. You can do this is the homing files.This is what I suggest:
                                  1. Execute a tiny move (1 or 2 microsteps) away from the homing direction.
                                  2. Pause for 100ms using G4.
                                  3. Execute a small move away from the homing direction, e.g. 10mm.
                                  4. Execute the homing move.
                                  Don't forget to reduce current for the homing move (M913).
                                  floblerundefined 1 Reply Last reply Reply Quote 1
                                  • floblerundefined
                                    flobler @dc42
                                    @dc42 thanks, I am not sure if I am doing this correct though. So far I am still getting quite mixed results (stalling after power cycle before home point is reached and after that only homing correctly when the extruder is within 10mm of the homing location, and then also not all the time).
                                    I am trying the following (again only trying X for now):
                                    1. Set stall detection sensitivity and reduce V+H+T parameter
                                    2. Run tuning procedure and reduce motor current
                                    3. Homing move
                                    4. Reset sensitivity, V+H+T and return current to 100%
                                    The above is all my homex.g contains... Is there still something I am doing obviously wrong?
                                    • Sindariusundefined
                                      Sindarius
                                      I have been running sensorless homing on my Bear using the Mini5 since it was implemented a few weeks back.
                                      These are my settings in my config.g for the x axis
                                      M569 P0.0 S0 D3 V100                                         ; physical drive 0.0 goes forwards (x)
                                      M574 X1 S3 												; configure sensorless endstop for low end on X  (Sensorless)
                                      My homex.g
                                      M400 						; wait til stuff stops
                                      M574 X1 S3 			  ; use stall guard for endstops
                                      M913 X60 Y60  		; drop motor currents to 50%
                                      M201 X1000 Y1000	 ; reduce acceleration on X/Y to stop false triggers
                                      M915 X S0 R0 F0 H200	;  Sensitivity 4, don’t take action, don’t filter, 400steps/sec
                                      G91 											; set relative
                                      G1 H2 Z5 F1200
                                      G1 H1 X-250 F3000			 ; move left 250mm, stopping at the endstop
                                      G1 X10 F1200							; move away from end
                                      G1 H2 Z-5 F1200
                                      G90 												; back to absolute positioning
                                      M400										 ; wait again
                                      M913 X100 Y100 					 ; motor currents back to 100%
                                      M201 X500 Y500			 ; accel back to original
                                      M915 S63 X Y R0					 ; Disable Logging and lower stall detection
                                      Feel free to give it a shot and tweak it as needed. I have not spent a lot of time trying to fine tune it but it works well.
                                      • floblerundefined
                                        flobler @Sindarius
                                        @Sindarius thank you, I will try that! Are you using Pruse MK3 LDO motors?
                                        What part in your homex.g is covering the tuning procedure that David described above?
                                        Sindariusundefined 1 Reply Last reply Reply Quote 0
                                        • floblerundefined
                                          flobler
                                          Ok, so I tried this @Sindarius. It definitely works the best it has so far, thanks for sharing!
                                          A couple of things are not working yet though:
                                          1. After a power cycle, when I try to home the axis, it detects a home instantly, before the actual home position and then moves away 10mm. Each homing command moves the axis therefore 10mm further away from its homing position.
                                          2. After an emergency stop, I can get it to home correctly, that works as many times I want as long as I do not make any other moves in between and as long as I am within 10mm of the actual homing position. As soon as I move e.g. 100mm away from the homing position and I try to re-home then, I get a crash.
                                            Sindarius @flobler
                                            @flobler I am using a different set of motors for my bear build. Mine was done with some trial and error and tweaking settings I used on my Duet 2 wifi. I would only use what I have as a start point and incorporate dc42’s recommendations. Don’t trust my comments since the numbers won’t match everywhere.
