Duet2 Wifi Update worked - for a short while
@peterfrosta said in Duet2 Wifi Update worked - for a short while:
i saw your link. since i got no reaction on pc site when plugging in the duet2wifi via usb, i stop very early in this documentation.
try a different usb cable. a lot of cables will not work.
@Veti said in Duet2 Wifi Update worked - for a short while:
with this commented out you disabled networking
this was certainly not generated by the configurator.i explained in the post with the config why i have add this.
you are overloding the cpu.
its advised to stay with x16 and interpolationi didnt understand what u explain. i thought the M308 parameter ist default.
but the sd card reader works with this cable?! i give it a try.i tried to reset the hole firmware (https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3)
I placed the Erase Jumper but the Diag LED keeps shining -
this is the config that runs until i updated yesterday
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 17 2020 14:46:51 GMT+0100 (Mitteleuropäische Normalzeit) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Tronxy" ; set printer name M667 S1 ; select CoreXY mode ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S1 ; enable FTP M586 P2 S1 ; enable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards Z1 M569 P3 S0 ; physical drive 3 goes backwards M569 P4 S1 ; physical drive 3 goes forwards Z2 ; DUAL Z M584 X0 Y1 Z2:4 E3 ; set drive mapping ;M584 X0 Y1 Z2 E3 M671 X-90:490 Y200:200 S4 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis M350 X64 Y64 Z64 E64 I1 ; configure microstepping with interpolation ;M92 X323.835 Y320 Z1606.522 E1582 ; set steps per mm M92 X322.381 Y320.320 Z1606.522 E1582 ; set steps per mm ;M566 X1500.00 Y1500.00 Z180.00 E348.00 ; set maximum instantaneous speed changes (mm/min) ;M203 X24000.00 Y24000.00 Z1980.00 E9000.00 ; set maximum speeds (mm/min) ;M201 X1500.00 Y1500.00 Z200.00 E1000.00 ; set accelerations (mm/s^2) ;M566 X1200.00 Y1200.00 Z50.00 E200.00 ; set maximum instantaneous speed changes (mm/min) ;M203 X18000.00 Y18000.00 Z1980.00 E9000.00 ; set maximum speeds (mm/min) ;M201 X1500.00 Y1500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2) M201 X2500 Y2500 Z800 E3000 ; set accelerations (mm/s^2) M203 X24000 Y24000 Z2500 E6000 ; set maximum speeds (mm/min) M566 X650 Y550 Z200 E1000 ; Jerk (mm/min) M572 D0 S0.1 M906 X1100 Y1100 Z1000 E1200 I35 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-7 Y-14 Z0 S1 ; set axis minima M208 X400 Y360 Z390 S0 ; set axis maxima ; Endstops M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Filament sensor M591 P1 C"e0_stop" S1 ; ; Z-Probe M558 P8 C"zprobe.in+zprobe.mod" H2 F2000 T12000 S0.04 I1 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X-30 Y5 ; set Z probe trigger value, offset and trigger height Z WERT in homeZ.conf ;M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters ;M557 X52:350 Y30:350 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T102400 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M307 H0 A106.4 C953.3 D2.2 V24.1 M140 S65 R40; M140 H0 ; map heated bed to heater 0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M143 H1 S280 ; set temperature limit for heater 1 to 280C M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M307 H1 A1170.9 C396.6 D5.8 V24.1 ; Fans M950 F0 C"fan0" Q400 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0:1 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R180 S200 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings ;Tappering M376 H10 ; Bettkompensation läuft über 10mm Linear aus M501; -
I placed the Erase Jumper but the Diag LED keeps shiningthat erased the firmware. no config will bring back the duet.
you need to flash it via bossa. that is now the only wayM350 X64 Y64 Z64 E64 I1 ; configure microstepping with interpolation
the duet wifi can not do interpolation at x64 only x16
default does not mean its correct
You'll need to follow this to flash the 3.1.1 firmware on the board again.
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.1
On your SD card you'll need the folder structure described here: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
For the /www folder use the contents of the DuetWebControl zip file from the 3.1.1 release.
For the /sys folder use the config files you got from the config tool.
For future reference, to update the firmware to a major version all you need to do is upload a single zip file in the web interface. Don't extract it first. Just upload it to the system tab in DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip -
good to know!
that'S right but why default value do overload my machine? why do you know that happend?
@Phaedrux said in Duet2 Wifi Update worked - for a short while:
I placed the Erase Jumper but the Diag LED keeps shiningi get no usb connection and eraseing firmware seems not working (Diag LED stay on)
you jumped the comments. the overloading is in regards to the microstepping.
a wrong beta value for the thermistor will result in an incorrect temperature reported.
@Veti ok thx.
Any idea how to get a connection between duet and pc or how i got the firmware deleted??
try different usb cables and different usb ports until you get a connection
One thing i noticed in your picture is the connector for the paneldue on the Duet wifi On my board the green cable is nearest the wifi module. of course this also depends how the plug is populated at the panel due end as well. It may be worth investigating to double check the connections are correct.
Good luck
Does anything show up in device manager? Does the computer make a new device connected chime?
@Phaedrux no, nothing. no sound, no icon in the device manager.
in former times it worked well.in the meanwhile i could borrow one new duet2wifi from a friend. this connect immediately by usb.
i am allowed to use it for the next weeks.
I think my duet is broken but maybe still in warrenty.
I will contect duet3d. -
i did. tried different usb cables and different usb ports until you get a connection
i tried a lot cable and all cable worked with USB-Stick and with the new (borrowed) Duet2Wifi.
In former times some of this cable worked with my "broken" Duet2Wifi. -
@Phil-Maddox sharp view
the panel has always worked well and i cant plug it the wrong way.
When and where did you purchase the Duet?
@Phaedrux directly from duet3d on 5th November 2019
In former times some of this cable worked with my "broken" Duet2Wifi.aargh.. cant edit this.. the first line after "id did." should be deleted... embarrassing
Well the fact that the diag LED stays lit and nothing shows up over USB at all isn't a great sign. Swapping in a known good board proves that your wiring and setup is fine.
I suppose it's possible that the USB port is damaged and the firmware has been erased. So nothing will work until firmware has been flashed but the firmware can't be flashed without a working USB port. Do you see any damage to the USB port?
Or something else like the CPU has fried.
Do you see any other damaged chips on the board? Can you post some clear well lit close up photos of the top side of the board?
You're out of the official 6 month warranty, but you can try contacting roland@duet3d.com and inquiring about obtaining a refurbished board on exchange at a reduced cost.
Refurbished is definitively safer; if we can with some degree of confidence tell from pictures what the problem is https://forum.duet3d.com/topic/13875/community-repairs/ might be a cheaper option if you happen to be near one of the users on that list (but without know what's wrong, the part cost might be substantial)
