    Duet2 Wifi Update worked - for a short while
    863
    • peterfrostaundefined
      peterfrosta @Veti
      @Veti
      @Veti said in Duet2 Wifi Update worked - for a short while:
      with this commented out you disabled networking
      this was certainly not generated by the configurator.
      i explained in the post with the config why i have add this.
      you are overloding the cpu.
      its advised to stay with x16 and interpolation
      i didnt understand what u explain. i thought the M308 parameter ist default.
      try a different usb cable. a lot of cables will not work.
      but the sd card reader works with this cable?! i give it a try.
      i tried to reset the hole firmware (https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3)
      I placed the Erase Jumper but the Diag LED keeps shining 😞
        peterfrosta
        this is the config that runs until i updated yesterday
        ; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Jan 17 2020 14:46:51 GMT+0100 (Mitteleuropäische Normalzeit)
        G90                                                    ; send absolute coordinates...
        M83                                                    ; ...but relative extruder moves
        M550 P"Tronxy"                                         ; set printer name
        M667 S1                                                ; select CoreXY mode
        M552 S1                                                ; enable network
        M586 P0 S1                                             ; enable HTTP
        M586 P1 S1                                             ; enable FTP
        M586 P2 S1                                             ; enable Telnet
        M569 P0 S0                                             ; physical drive 0 goes backwards
        M569 P1 S0                                             ; physical drive 1 goes backwards
        M569 P2 S1                                             ; physical drive 2 goes forwards	Z1
        M569 P3 S0                                             ; physical drive 3 goes backwards
        M569 P4 S1                                             ; physical drive 3 goes forwards	Z2
        ; DUAL Z
        M584 X0 Y1 Z2:4 E3                                       ; set drive mapping ;M584 X0 Y1 Z2 E3
        M671 X-90:490 Y200:200 S4 							; leadscrews at left (connected to Z) and right (connected to E1) of X axis
        M350 X64 Y64 Z64 E64 I1                                ; configure microstepping with interpolation
        ;M92 X323.835 Y320 Z1606.522 E1582      			; set steps per mm
        M92 X322.381 Y320.320 Z1606.522 E1582      			; set steps per mm
        ;M566 X1500.00 Y1500.00 Z180.00 E348.00                 ; set maximum instantaneous speed changes (mm/min)
        ;M203 X24000.00 Y24000.00 Z1980.00 E9000.00             ; set maximum speeds (mm/min)
        ;M201 X1500.00 Y1500.00 Z200.00 E1000.00                ; set accelerations (mm/s^2)
        ;M566 X1200.00 Y1200.00 Z50.00 E200.00                 ; set maximum instantaneous speed changes (mm/min)
        ;M203 X18000.00 Y18000.00 Z1980.00 E9000.00             ; set maximum speeds (mm/min)
        ;M201 X1500.00 Y1500.00 Z100.00 E5000.00                ; set accelerations (mm/s^2)
        M201 X2500 Y2500 Z800 E3000						; set accelerations (mm/s^2)
        M203 X24000 Y24000 Z2500 E6000						; set maximum speeds (mm/min)
        M566 X650 Y550 Z200 E1000							; Jerk (mm/min)
        M572 D0 S0.1
        M906 X1100 Y1100 Z1000 E1200 I35                       ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                                ; Set idle timeout
        M208 X-7 Y-14 Z0 S1                                       ; set axis minima
        M208 X400 Y360 Z390 S0                                 ; set axis maxima
        M574 X1 S1 P"!xstop"                                    ; configure active-low endstop for low end on X via pin xstop
        M574 Y1 S1 P"!ystop"                                    ; configure active-low endstop for low end on Y via pin ystop
        M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
        ; Filament sensor
        M591 P1 C"e0_stop" S1	;
        M558 P8 C"zprobe.in+zprobe.mod" H2 F2000 T12000 S0.04 I1         ; set Z probe type to unmodulated and the dive height + speeds
        G31 P500 X-30 Y5                                   ; set Z probe trigger value, offset and trigger height  Z WERT in homeZ.conf
        ;M556 S50 X0 Y0 Z0                                      ; set orthogonal axis compensation parameters
        ;M557 X52:350 Y30:350 S20                               ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T102400 B4138         ; configure sensor 0 as thermistor on pin bedtemp
        M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
        M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
        M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
        M307 H0 A106.4 C953.3 D2.2 V24.1
        M140 S65 R40;
        M140 H0						       ; map heated bed to heater 0
        M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
        M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
        M143 H1 S280                                           ; set temperature limit for heater 1 to 280C
        M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
        M307 H1 A1170.9 C396.6 D5.8 V24.1
        M950 F0 C"fan0" Q400                                   ; create fan 0 on pin fan0 and set its frequency
        M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
        M106 P1 S1 H1 T45                                      ; set fan 1 value. Thermostatic control is turned on
        M563 P0 D0 H1 F0:1                                     ; define tool 0
        G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
        G10 P0 R180 S200                                           ; set initial tool 0 active and standby temperatures to 0C
        ; Custom settings
        ;Tappering
        M376 H10			                                            ; Bettkompensation läuft über 10mm Linear aus
        M501;
        • Vetiundefined
          Veti @peterfrosta
          @peterfrosta said in Duet2 Wifi Update worked - for a short while:
          that erased the firmware. no config will bring back the duet.
          you need to flash it via bossa. that is now the only way
          the duet wifi can not do interpolation at x64 only x16
          default does not mean its correct
          peterfrostaundefined 1 Reply Last reply Reply Quote 0
            You'll need to follow this to flash the 3.1.1 firmware on the board again.
            https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.1
            On your SD card you'll need the folder structure described here: https://duet3d.dozuki.com/Wiki/SD_Card#Section_Creating_the_file_structure
            For the /www folder use the contents of the DuetWebControl zip file from the 3.1.1 release.
            For the /sys folder use the config files you got from the config tool.
            For future reference, to update the firmware to a major version all you need to do is upload a single zip file in the web interface. Don't extract it first. Just upload it to the system tab in DWC.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
              peterfrosta @Veti
              good to know!
              that'S right but why default value do overload my machine? why do you know that happend?
                peterfrosta @Phaedrux
                @Phaedrux said in Duet2 Wifi Update worked - for a short while:
                i get no usb connection and eraseing firmware seems not working (Diag LED stay on)
                • Vetiundefined
                  Veti @peterfrosta
                  you jumped the comments. the overloading is in regards to the microstepping.
                  a wrong beta value for the thermistor will result in an incorrect temperature reported.
                    peterfrosta @Veti
                    @Veti ok thx.
                    Any idea how to get a connection between duet and pc or how i got the firmware deleted??
                    • Vetiundefined
                      Veti
                      try different usb cables and different usb ports until you get a connection
                      • Phil Maddoxundefined
                        Phil Maddox
                        One thing i noticed in your picture is the connector for the paneldue on the Duet wifi On my board the green cable is nearest the wifi module. of course this also depends how the plug is populated at the panel due end as well. It may be worth investigating to double check the connections are correct.
                        Good luck
                          Phaedrux Moderator @peterfrosta
                          Does anything show up in device manager? Does the computer make a new device connected chime?
                            @Phaedrux no, nothing. no sound, no icon in the device manager.
                            in former times it worked well.
                            in the meanwhile i could borrow one new duet2wifi from a friend. this connect immediately by usb.
                            i am allowed to use it for the next weeks.
                            I think my duet is broken but maybe still in warrenty.
                            I will contect duet3d.
                              peterfrosta @Veti
                              i did. tried different usb cables and different usb ports until you get a connection
                              i tried a lot cable and all cable worked with USB-Stick and with the new (borrowed) Duet2Wifi.
                              In former times some of this cable worked with my "broken" Duet2Wifi.
                                peterfrosta @Phil Maddox
                                @Phil-Maddox sharp view 😉
                                the panel has always worked well and i cant plug it the wrong way.
                                  When and where did you purchase the Duet?
                                    @Phaedrux directly from duet3d on 5th November 2019
                                      peterfrosta @peterfrosta
                                      aargh.. cant edit this.. the first line after "id did." should be deleted... embarrassing
                                        Well the fact that the diag LED stays lit and nothing shows up over USB at all isn't a great sign. Swapping in a known good board proves that your wiring and setup is fine.
                                        I suppose it's possible that the USB port is damaged and the firmware has been erased. So nothing will work until firmware has been flashed but the firmware can't be flashed without a working USB port. Do you see any damage to the USB port?
                                        Or something else like the CPU has fried.
                                        Do you see any other damaged chips on the board? Can you post some clear well lit close up photos of the top side of the board?
                                        You're out of the official 6 month warranty, but you can try contacting roland@duet3d.com and inquiring about obtaining a refurbished board on exchange at a reduced cost.
                                          A Former User
                                          Refurbished is definitively safer; if we can with some degree of confidence tell from pictures what the problem is https://forum.duet3d.com/topic/13875/community-repairs/ might be a cheaper option if you happen to be near one of the users on that list (but without know what's wrong, the part cost might be substantial)
