    Preview version of CNC optimized DWC.
    CNC
    40
    191
    22.1k
    • R4ffersundefined
      R4ffers @Sindarius
      @Sindarius, wow excellent
      Mb6hc + 3hc + 1lc on Voron V2.4, Mini 5+ exp 2+ on Vzbot 235 AWD, Duet 2 wifi on Ox CNC and Mini 5+ on Millennium Milo v1.5 mini mill.
      • cjmundefined
        cjm @Sindarius
        @Sindarius Really great update, thank you!
        • Shanian79undefined
          Shanian79
          This is great! Thank you! Will this CNC screen format work on a 7i Panel Due?
          Sindariusundefined 1 Reply Last reply Reply Quote 0
          • weed2allundefined
            weed2all @Sindarius
            @Sindarius neat!
            https://www.thingiverse.com/weed2all/designs
            • Sindariusundefined
              Sindarius @Shanian79
              @Shanian79 This is just on the DWC
              • tierodundefined
                tierod
                Very exciting !!! Perfect timing for me as I’m moving my duet2 from my old 3d printer to a new diy cnc!
                Many,many thanks!
                Rod
                  Sindarius
                  If any of you happen to be using my Gamepad Jogger plugin with the CNC build I have a new version which allows you to bind keyboard keys to commands as well.
                  https://github.com/Sindarius/DWC_GamepadJogger_Plugin/releases/tag/0.2.0
                  markzundefined 1 Reply Last reply Reply Quote 3
                  • whopping pochardundefined
                    whopping pochard
                    Ooh, nice! I've been itching to put together a CNC pendant design that could take advantage of this.
                    • markzundefined
                      markz @Sindarius
                      @Sindarius These changes/plugins are just great.
                      I've got a request for the Jog page plugin.
                      Having home buttons imho makes little sense there. I maybe home once per day and in normal use if I hit home it's an at-best time-wasting mistake. Plus, I can already do it in the dashboard.
                      Instead, I'd love it if we had a speed readout/control. Maybe it could have options like Travel, Feed, 20, 40, 60, 80 (mm/sec)?
                      For the dashboard: I like to go to work 0,0 a lot, but rarely 0,0,0 - for whatever that's worth. My work Z=0 is usually the top of the workpiece, sometimes the top of the bed.
                      Thanks again for all the work.
                      Sindariusundefined 1 Reply Last reply Reply Quote 1
                        Sindarius @markz
                        @markz Appreciate the feedback!
                        On the jog control plugin I can look at adding a "go to work 0" button. I'll look into adding travel speed as a set of buttons like the distance that is on there. I have a couple ideas I plan to play with on the jog control but was looking forward to some feedback and ideas.
                        • tntjetundefined
                          tntjet
                          @Sindarius how do I install your plugin for keyboard control?
                            Sindarius @tntjet
                            @tntjet You can download the plugin from my GitHub page
                            To install it take the zip file from the release and upload it using Files > System.
                            Once the plugin is installed activate it by going to the "Machine Specific" page Plugins tab and start it.
                            The latest version has the keyboard jogging setup.
                            tntjetundefined 1 Reply Last reply Reply Quote 0
                              A Former User @Sindarius
                              @Sindarius said in Preview version of CNC optimized DWC.:
                              -> ideas:
                              Which protocol/standards are you planning to support -> USB and or D-Sub-9 ?
                                Sindarius @A Former User
                                @LB the gamepad jogger just picks up whatever gamepads it sees. Usb and bluetooth if available.
                                markzundefined 1 Reply Last reply Reply Quote 0
                                • tntjetundefined
                                  tntjet @Sindarius
                                  @Sindarius thankyou , great work!
                                  • markzundefined
                                    markz @Sindarius
                                    @Sindarius Some more spontaneous feedback... since I'm just starting to use this.
                                    1. The g-code viewer is just the coolest feature ever on my CNC.
                                    2. I really like the gamepad jogger but
                                      a) I had a small panic attack when I mapped Z today. My normal Z movement is much much smaller than X,Y and the auto-queued 'down' push at 50mm was scary - luckily I had no bit in the head. Having a separate Z distance would be very nice.
                                      b) The feel when holding down a move key is great (the cnc just starts moving at speed) but because it's queueing up keystrokes when I release the button it keeps moving for some indeterminate number of steps.
                                    by the way - I hacked the plugin to add a 25.4 distance option for something I needed to do in inches and it saved me hours of typing g codes and manually adding 3 digit numbers. Sweet!
                                    1. The most important statistic in the G-code for a job for me is the surround box. It tells me if I did something stupid in the modeler like set the wrong origin for the material. Since you're already scanning the gcode is there some way in the viewer to quick-see the box values?
                                    Thanks again. This stuff rocks.
                                      Sindarius @markz
                                      @markz glad you are enjoying the viewer!
                                      It is funny you mention independent Z movement values, I had a similar experience with Openbuilds Control on my cnc some time back. I modded that software to add an independent z step because I managed to drive a v bit into my workpiece. I’ll look at making that an optional z step toggle in my gamepad jogger.
                                      Because it is queueing gcode it does sometimes overshoot a step or two if you hold the stick down. I need to play with the timing more to avoid stuttering and not overshoot too much.
                                      I can certainly look at adding some simple metrics to the 3D viewer in 3.3 or later. The first priority was getting all the gcode to render properly.
                                      • zendesignerundefined
                                        zendesigner
                                        wow Great,
                                        I just bought a WMD30LV mill and planning on converting it to CNC. i have some duet wifi boards lying around and would like to use them as i have them in all of my 3d printers.
                                        This certainly would make the special zero requirements and the jogwheel possible in a really nice way.
                                        Cool dude, really thanks.
                                        Zen
                                        tenajaundefined 1 Reply Last reply Reply Quote 0
                                        • tenajaundefined
                                          tenaja @zendesigner
                                          @zendesigner , until Duets get backlash compensation, it's not suitable for real (i.e. accurate) cnc work. If you want accurate work, you will want LinuxCNC. I think Marlin perhaps has backlash comp, but I've not verified or used it.
                                          I use Duet on a few desktop applications, but until it gets backlash comp, I won't put it on my mills.
                                          Once it does get it, I've got a couple machines that might benefit from it.
                                          • PCRundefined
                                            PCR
                                            @tenaja See this Thread
                                            Re: Backlash compensation
