    Help me get connected to my Duet2Wifi
    6.0k
    • Kwad3dundefined
      Kwad3d @Phaedrux
      @Phaedrux Thanks. Yea I'm slowly getting it where I want by making those adjustments. Despite my negative opinion on senseless homing the BL touch setup it way simpler and easier than marlin which continuously tried to probe off the bed regardless of adjustments made.
      • Kwad3dundefined
        Kwad3d @Phaedrux
        @Phaedrux Seems I got the bed mesh dialed in pretty good. I used previous Hight maps to adjust the bed mounting points and this is my result. Sure its not %100 perfect but I will take it. Hopefully that is the last of the assistance I need. Thanks again for your patience and professionalism fd3ac3e7-943b-43c2-a46c-8292f02b86f9-image.png
        • Kwad3dundefined
          Kwad3d @Phaedrux
          @Phaedrux So I think Im done setting up the machine. I got a message when sending M500 so save my pid tune saying "Warning: M500: No M501 command was executed in config.g"
          Do I just add M501 after the last line in config.g or am I good to turn it off now?
            Phaedrux Moderator @Kwad3d
            @Kwad3d said in Help me get connected to my Duet2Wifi:
            Yeah you need to add M501 at the end of config.g to load the saved values at boot from config-override.g.
            The saved values are still there in config-override.g whether you turn it off or not.
            Kwad3dundefined 1 Reply Last reply Reply Quote 0
            • Kwad3dundefined
              Kwad3d @Phaedrux
              @Phaedrux Hi again. So I ran into a issue with my bed leveling. When I got the probe grid mapped out for my printer I used the hight map to manually level the bed. I did such a good job that I never noticed that the printer was not compensating for irregularities. I recently changed the build surface and now my mesh is no longer as flat as I posted in the pic. Now Im noticing that the printer is not adjusting the z axis for a good first layer. What to I need to do to turn on leveling based off the generated hight map?
                The heightmap is not loaded at startup automatically. You need to either use G29 to create a fresh map, or use G29 S1 to load the previously created heightmap. That would usually happen in your slicer start gcode after the axis have been homed (and Z has been homed with the probe).
                • Kwad3dundefined
                  Kwad3d @Phaedrux
                  @Phaedrux Yea I have G29 in my start G code but the Z axis makes no adjustments to follow the mesh. Here is my G code.
                  G28 ; home all axes
                  G29 S1
                  G1 Z5 F3000 ; lift
                  G1 X10 Y10 F1500 ; move to prime
                  G1 Z0.2 F3000 ; get ready to prime
                  G92 E0 ; reset extrusion distance
                  G1 X120 E15 F600 ; prime nozzle
                  G1 X140 F5000 ; quick wipe-
                    How are you determining that it's not compensating?
                    If you send M122 after the print is started, does it show "compensation: mesh"?
                    • Kwad3dundefined
                      Kwad3d
                      I marked my Z motor's 20T gear with a black line. There is no movement other than adjusting for a new layer. I entered M122 in the console and this is what came back
                      M122
                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                      Board ID: 08DJM-9178L-L4MSJ-6JTD8-3S86L-K826N
                      Used output buffers: 3 of 24 (21 max)
                      Static ram: 27980
                      Dynamic ram: 93912 of which 52 recycled
                      Exception stack ram used: 648
                      Never used ram: 8480
                      Tasks: NETWORK(ready,268) HEAT(blocked,1224) MAIN(running,1732) IDLE(ready,80)
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 105:28:54 ago, cause: software
                      Last software reset at 2020-12-31 07:13, reason: User, spinning module GCodes, available RAM 8528 bytes (slot 3)
                      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                      Error status: 0
                      MCU temperature: min 40.1, current 40.5, max 40.7
                      Supply voltage: min 23.8, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                      Driver 0: ok, SG min/max 0/126
                      Driver 1: standstill, SG min/max 0/1023
                      Driver 3: ok, SG min/max not available
                      Date/time: 2021-01-04 16:43:33
                      Slowest loop: 88.77ms; fastest: 0.14ms
                      === Storage ===
                      Free file entries: 9
                      SD card longest read time 1.3ms, write time 41.5ms, max retries 0
                      Hiccups: 0(0), FreeDm: 166, MinFreeDm: 154, MaxWait: 0ms
                      === MainDDARing ===
                      Scheduled moves: 2501, completed moves: 2493, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                      === AuxDDARing ===
                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                      Heater 0 is on, I-accum = 0.2
                      Heater 1 is on, I-accum = 0.5
                      Segments left: 1
                      Movement lock held by null
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is doing "G1 X120.948 Y165.948 E2.6605" in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      Daemon is idle in state(s) 0
                      Code queue is empty.
                      === Network ===
                      Slowest loop: 201.12ms; fastest: 0.09ms
                      HTTP sessions: 1 of 8
                      • WiFi -
                        Network state is active
                        Failed messages: pending 0, notready 0, noresp 1
                        WiFi firmware version 1.23
                        WiFi MAC address bc:dd:c2:31:a5:92
                        WiFi Vcc 3.40, reset reason Unknown
                        WiFi flash size 4194304, free heap 22840
                        WiFi IP address 192.168.1.10
                        WiFi signal strength -54dBm, reconnections 0, sleep mode modem
                        Socket states: 0 4 0 0 0 0 0 0
                      • fcwiltundefined
                        fcwilt @Kwad3d
                        The movement can be very hard to see if you are looking at the gear.
                        Affix a pointer of some sort to magnify the apparent movement. I use a 50mm nail held to the lead screw with a small magnet.
                        Once I did that I could see the mesh adjustments.
                        • Kwad3dundefined
                          Kwad3d @fcwilt
                          @fcwilt Its not moving. I have 17 printers in the shop and I can visually see the z axis move when compensating for irregularities in the bed. Also you should be able to feel minor adjustments if you lightly tough the pully on the Z motor as well. I mean I can place a 3mm spacer under the front of the bed where the z is homed to exaggerate a out of level platform to prove its not working but its simply a waste of my time as I can tell its not working. I'm not speculating...
                            M122 indicates it's active. What does the heightmap image look like? Did you re-create the mesh with G29 after changing the bed surface? Do you have any taper off set with M376?
                            This thread is very long at this point and this is a completely unrelated issue. It might be a good idea to start a new thread with all your config files, etc
                            • Kwad3dundefined
                              Kwad3d @Phaedrux
                              @Phaedrux So Im having trouble with the Wifi connection again. Guessing my router reset or something. I identified the new address for the board but when I connect it says "Your Duet rejected the HTTP request: overflow". I went through the guide again and also referred to our previous messages on this chain but I can not figure it out. My research only comes up with a SD card problem but nothing changed besides the address on the router
                                So your router gave the duet a new IP address? Can you set a DHCP reservation in the router so that the duet can keep the same ip long term?
                                • Kwad3dundefined
                                  Kwad3d @Phaedrux
                                  @Phaedrux said in Help me get connected to my Duet2Wifi:
                                  DHCP reservation
                                  Ok I figured it out and have it reserved
                                    What URL are you using to try and reach the Duet?
                                    Kwad3dundefined 3 Replies Last reply Reply Quote 0
                                    • Kwad3dundefined
                                      Kwad3d @Phaedrux
                                      @Phaedrux 192.168.1.3
                                      • Kwad3dundefined
                                        Kwad3d @Phaedrux
                                        @Phaedrux I connected to YAT and went through the steps in the guide and confirmed the URL
                                          Have you tried a new SD card yet in case the /www folder has been corrupted?
                                          • Kwad3dundefined
                                            Kwad3d @Phaedrux
                                            @Phaedrux I also turned off all other wifi devices and deleted them from my router for now untill I get the duet connected
