    Help me get connected to my Duet2Wifi
    6.4k
    • Kwad3dundefined
      Kwad3d @Phaedrux
      @Phaedrux Im almost there now. X and Y are homing great now and Im on the BLtouch set up now. when homing Z im getting this error now "Failed to enable endstops".
      Here is my endstop and z probe setup
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-26 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X36:290 Y46:290 S48 ; define mesh grid
      I have tested the probe and it will deploy, retract, and reset as well.
      I tried adding M574 Z1 S2 to the endstop lines but the probe failed to deploy
      • Vetiundefined
        Veti
        most likely are missing the G30 in your homing files and are trying to hit the none existing endstop
        post your homing files
          jay_s_uk
          You need to change your homez and homeall files to something like
          G91
          G1 H2 Z5
          G90
          G1 X150 Y150
          G30
          A probe doesn't use the typical G1 H1 moves to home.
          That code above basically lifts the bed away from the nozzle, moves to a position (usually the centre of the bed so adjust taking into account your probe offset) and then it proves the bed at that point to set Z to whatever your probe offset is.
          Kwad3dundefined 1 Reply Last reply Reply Quote 0
          • Kwad3dundefined
            Kwad3d @jay_s_uk
            @jay_s_uk Ok that seemed to get me going.
            Now I just have to figure out how to adjust where the mesh starts for each axis. the XY max probe points are perfect at 10mm inside the max points of the bed. However the X is starting at 40mm (62 at the nozzle) and the Y is starting at 55mm.
              Phaedrux Moderator @Kwad3d
              @Kwad3d said in Help me get connected to my Duet2Wifi:
              If it's starting too far inside the limit, increase/decrease the limits in M557
              Try X10:290 Y10:290
              To make testing faster, change S48 to P2:2, this would result in a 2x2 grid instead of a full detailed grid. Once you're happy with the extends you can switch back to the spacing method, or increase the number of points.
              https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M557_Set_Z_probe_point_or_define_probing_grid
              Kwad3dundefined 3 Replies Last reply Reply Quote 0
              • Kwad3dundefined
                Kwad3d @Phaedrux
                @Phaedrux Thanks. Yea I'm slowly getting it where I want by making those adjustments. Despite my negative opinion on senseless homing the BL touch setup it way simpler and easier than marlin which continuously tried to probe off the bed regardless of adjustments made.
                • Kwad3dundefined
                  Kwad3d @Phaedrux
                  @Phaedrux Seems I got the bed mesh dialed in pretty good. I used previous Hight maps to adjust the bed mounting points and this is my result. Sure its not %100 perfect but I will take it. Hopefully that is the last of the assistance I need. Thanks again for your patience and professionalism fd3ac3e7-943b-43c2-a46c-8292f02b86f9-image.png
                  • Kwad3dundefined
                    Kwad3d @Phaedrux
                    @Phaedrux So I think Im done setting up the machine. I got a message when sending M500 so save my pid tune saying "Warning: M500: No M501 command was executed in config.g"
                    Do I just add M501 after the last line in config.g or am I good to turn it off now?
                      Yeah you need to add M501 at the end of config.g to load the saved values at boot from config-override.g.
                      The saved values are still there in config-override.g whether you turn it off or not.
                      • Kwad3dundefined
                        Kwad3d @Phaedrux
                        @Phaedrux Hi again. So I ran into a issue with my bed leveling. When I got the probe grid mapped out for my printer I used the hight map to manually level the bed. I did such a good job that I never noticed that the printer was not compensating for irregularities. I recently changed the build surface and now my mesh is no longer as flat as I posted in the pic. Now Im noticing that the printer is not adjusting the z axis for a good first layer. What to I need to do to turn on leveling based off the generated hight map?
                          The heightmap is not loaded at startup automatically. You need to either use G29 to create a fresh map, or use G29 S1 to load the previously created heightmap. That would usually happen in your slicer start gcode after the axis have been homed (and Z has been homed with the probe).
                          • Kwad3dundefined
                            Kwad3d @Phaedrux
                            @Phaedrux Yea I have G29 in my start G code but the Z axis makes no adjustments to follow the mesh. Here is my G code.
                            G28 ; home all axes
                            G29 S1
                            G1 Z5 F3000 ; lift
                            G1 X10 Y10 F1500 ; move to prime
                            G1 Z0.2 F3000 ; get ready to prime
                            G92 E0 ; reset extrusion distance
                            G1 X120 E15 F600 ; prime nozzle
                            G1 X140 F5000 ; quick wipe-
                              How are you determining that it's not compensating?
                              If you send M122 after the print is started, does it show "compensation: mesh"?
                              • Kwad3dundefined
                                Kwad3d
                                I marked my Z motor's 20T gear with a black line. There is no movement other than adjusting for a new layer. I entered M122 in the console and this is what came back
                                M122
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                                Board ID: 08DJM-9178L-L4MSJ-6JTD8-3S86L-K826N
                                Used output buffers: 3 of 24 (21 max)
                                Static ram: 27980
                                Dynamic ram: 93912 of which 52 recycled
                                Exception stack ram used: 648
                                Never used ram: 8480
                                Tasks: NETWORK(ready,268) HEAT(blocked,1224) MAIN(running,1732) IDLE(ready,80)
                                Owned mutexes: WiFi(NETWORK)
                                Last reset 105:28:54 ago, cause: software
                                Last software reset at 2020-12-31 07:13, reason: User, spinning module GCodes, available RAM 8528 bytes (slot 3)
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                Error status: 0
                                MCU temperature: min 40.1, current 40.5, max 40.7
                                Supply voltage: min 23.8, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: ok, SG min/max 0/126
                                Driver 1: standstill, SG min/max 0/1023
                                Driver 3: ok, SG min/max not available
                                Date/time: 2021-01-04 16:43:33
                                Slowest loop: 88.77ms; fastest: 0.14ms
                                === Storage ===
                                Free file entries: 9
                                SD card longest read time 1.3ms, write time 41.5ms, max retries 0
                                Hiccups: 0(0), FreeDm: 166, MinFreeDm: 154, MaxWait: 0ms
                                === MainDDARing ===
                                Scheduled moves: 2501, completed moves: 2493, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                                === AuxDDARing ===
                                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                Heater 0 is on, I-accum = 0.2
                                Heater 1 is on, I-accum = 0.5
                                Segments left: 1
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is doing "G1 X120.948 Y165.948 E2.6605" in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 201.12ms; fastest: 0.09ms
                                HTTP sessions: 1 of 8
                                • WiFi -
                                  Network state is active
                                  Failed messages: pending 0, notready 0, noresp 1
                                  WiFi firmware version 1.23
                                  WiFi MAC address bc:dd:c2:31:a5:92
                                  WiFi Vcc 3.40, reset reason Unknown
                                  WiFi flash size 4194304, free heap 22840
                                  WiFi IP address 192.168.1.10
                                  WiFi signal strength -54dBm, reconnections 0, sleep mode modem
                                  Socket states: 0 4 0 0 0 0 0 0
                                • fcwiltundefined
                                  fcwilt @Kwad3d
                                  The movement can be very hard to see if you are looking at the gear.
                                  Affix a pointer of some sort to magnify the apparent movement. I use a 50mm nail held to the lead screw with a small magnet.
                                  Once I did that I could see the mesh adjustments.
                                  • Kwad3dundefined
                                    Kwad3d @fcwilt
                                    @fcwilt Its not moving. I have 17 printers in the shop and I can visually see the z axis move when compensating for irregularities in the bed. Also you should be able to feel minor adjustments if you lightly tough the pully on the Z motor as well. I mean I can place a 3mm spacer under the front of the bed where the z is homed to exaggerate a out of level platform to prove its not working but its simply a waste of my time as I can tell its not working. I'm not speculating...
                                      M122 indicates it's active. What does the heightmap image look like? Did you re-create the mesh with G29 after changing the bed surface? Do you have any taper off set with M376?
                                      This thread is very long at this point and this is a completely unrelated issue. It might be a good idea to start a new thread with all your config files, etc
                                      • Kwad3dundefined
                                        Kwad3d @Phaedrux
                                        @Phaedrux So Im having trouble with the Wifi connection again. Guessing my router reset or something. I identified the new address for the board but when I connect it says "Your Duet rejected the HTTP request: overflow". I went through the guide again and also referred to our previous messages on this chain but I can not figure it out. My research only comes up with a SD card problem but nothing changed besides the address on the router
                                          So your router gave the duet a new IP address? Can you set a DHCP reservation in the router so that the duet can keep the same ip long term?
                                          • Kwad3dundefined
                                            Kwad3d @Phaedrux
                                            @Phaedrux said in Help me get connected to my Duet2Wifi:
                                            DHCP reservation
                                            Ok I figured it out and have it reserved
