    ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
    My Duet controlled machine
    13
    139
    9.0k
    • Vetiundefined
      Veti
      can you post a picture of the thermistor in the hotend?
      Blacksheep99undefined 1 Reply Last reply Reply Quote 0
      • Blacksheep99undefined
        Blacksheep99 @Veti
        @Veti said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
        I'll try. I've a work call now but will do it after.
        thanks for your help.
          A Former User
          How was the original board configured - maybe you can borrow some info from there?
            Blacksheep99
            Best I can manage at the moment. I'll have to take the shroud off etc.
              Blacksheep99 @A Former User
              @bearer said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
              Pics.
                Blacksheep99
                This other board was below the touch screen.
                  A Former User
                  Ouch / RIP. No immediately obvious easy way to get anything from that, the main cpu on the motion controller had seen better days indeed.
                  (there is what looks like a 8 pin soic flash chip, but might not be worth while extracting it if settings are in the other cpu's flash / eeprom)
                    @bearer It didn't smell too great when that happened 😧
                      Blacksheep99 @Veti
                      ok thats inline with a 100k ntc thermistor.
                      but which one is not as easy to determine.
                      can you put the thermistor at 100C using a known good temperature measuring tool?
                      i.e here is a beta 3950 resistance table.
                      https://www.keenovo.com/NTC-Thermistor-R-T-Table.pdf
                      I have an infrared thermometer gun (for the pizza oven). How about in the oven and use that to read the surface temp of it?
                        A Former User
                        if the oven temp is stable then it should work if left long enough for temperature to equalize on the board and oven; i prefer to use water with crushed ice and boiling water for a 2 point calibration as its more stable and water conducts the temperature better than air (but water does have its own challenges)
                          A Former User
                          Also as you'll tweak the print profile it doesn't matter if you print at 210 or 215 as long as you get consistent results - i.e. precision is more important than accuracy unless running a print farm.
                            That's a good point. It will be run as a lone printer.
                            • Vetiundefined
                              Veti @Blacksheep99
                              @Blacksheep99 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                              that will work for the bed, but for the hotend there will be a temperature difference between the nozzle and the surface.
                              maybe its possible to replace the thermistor with a known one. thats why i asked for a picture.
                              yes the problem is that the difference between a semitec 104gt2 and a b3950 setting is more than 20C at 200C
                                Blacksheep99 @Veti
                                I'll take the hotend out tonight and see if it can be ID'd.
                                  Blacksheep99
                                  Not sure these help?
                                    Blacksheep99
                                    The endstop/probe. 12v, is that an issue?
                                    • JamesMundefined
                                      JamesM
                                      It could just be a simple microswitch that is rated to handle 12 volts in which case it won't matter if you only use 3.3 volts. You'll need to just use an ohm meter on the wire ends to see if it that style switch. If it only has two wires I would suspect it's just a normal microswitch.
                                        Blacksheep99 @JamesM
                                        @JamesM said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                                        Thanks. I would think/hope you're right.
                                          A Former User
                                          Is the thermistor the white sleeved wirng or the red fiberglass insulated wiring? i'd guess the latter as the heater appears to be a cartridge poking out the other end.
                                            @bearer Sorry, it's the red wiring. The white ones are attached to the cartridge.
