    ST3Di Modelsmart 280 - Duet Maestro repair/upgrade
    My Duet controlled machine
    13
    139
    9.0k
      A Former User
      Also as you'll tweak the print profile it doesn't matter if you print at 210 or 215 as long as you get consistent results - i.e. precision is more important than accuracy unless running a print farm.
      Blacksheep99undefined 1 Reply Last reply Reply Quote 0
      • Blacksheep99undefined
        Blacksheep99 @A Former User
        @bearer said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
        That's a good point. It will be run as a lone printer.
        • Vetiundefined
          Veti @Blacksheep99
          @Blacksheep99 said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
          I have an infrared thermometer gun (for the pizza oven). How about in the oven and use that to read the surface temp of it?
          that will work for the bed, but for the hotend there will be a temperature difference between the nozzle and the surface.
          maybe its possible to replace the thermistor with a known one. thats why i asked for a picture.
          yes the problem is that the difference between a semitec 104gt2 and a b3950 setting is more than 20C at 200C
            Blacksheep99 @Veti
            @Veti said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
            I'll take the hotend out tonight and see if it can be ID'd.
              Blacksheep99
              Not sure these help?
                Blacksheep99
                The endstop/probe. 12v, is that an issue?
                • JamesMundefined
                  JamesM
                  It could just be a simple microswitch that is rated to handle 12 volts in which case it won't matter if you only use 3.3 volts. You'll need to just use an ohm meter on the wire ends to see if it that style switch. If it only has two wires I would suspect it's just a normal microswitch.
                    Blacksheep99 @JamesM
                    @JamesM said in ST3Di Modelsmart 280 - Duet Maestro repair/upgrade:
                    Thanks. I would think/hope you're right.
                      A Former User
                      Is the thermistor the white sleeved wirng or the red fiberglass insulated wiring? i'd guess the latter as the heater appears to be a cartridge poking out the other end.
                        @bearer Sorry, it's the red wiring. The white ones are attached to the cartridge.
                          A Former User
                          Thats what I thought but the pictures seemed focused on the white wiring, I guess its hard to get a good angle on the thermistor then?
                            @bearer It's not too easy especially with the double print head. I'll try again now. I may take one apart if that would be helpful.
                              A Former User
                              If the wires just disappear into some black goo like the heater then i doubt we can identify them visually. But given the construction, a glass bead ntc is the most likely candidate if you want to replace it - but if the mounting is just some sort of adhesive or not idk.
                                Blacksheep99
                                Pretty much
                                • Vetiundefined
                                  Veti
                                  well you can try your ir thermometer to see if the temperature is close
                                    Blacksheep99 @Veti
                                    @Veti On the heater block? As in wire up to the board and heat to 220? measure resistance ....
                                    • Vetiundefined
                                      Veti
                                      sorry i was under the impression you had an ir thermometer
                                        Blacksheep99 @Veti
                                        @Veti I have one of these
                                        https://www.amazon.co.uk/gp/product/B01AT9TON0/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
                                        So heat in the oven and then if it measures 220 check resistance. Sorry if I'm been dense
                                        • Vetiundefined
                                          Veti
                                          unless you have an all metal hotend, go for 200
                                          let it stay at that for a min or so and measure the temperature on the nozzle with the ir thermometer.
                                            A Former User
                                            need to set the correct emissivity for the nozzle to get an reasonably accurate reading, but by the looks of it thats likely to be less accurate then just picking a beta value
