    Duet 3 - New user - few quires
    1.1k
    • Dan1990undefined
      Dan1990
      Hello everyone, I'm a new user of duet 3 and have few queries to ensure my understanding of the guide.
      1. I would like to connect an external power supply. I have a 5V 7 amp power supply that powering up the SBC and I would like to connect that to the duet3. I must remove the jumper from 5V->SBC and leave it one on Internal 5V EN. Then connect external 5V power supply to EXT 5V?
      2. My printer has dual z-axis and I would like to define that in duet. On the RRF config tool, there is no such option to do it. Do I have to do it via macros or g-code?
      3. I have micro endstops that are NO. Connected them to IO_0 black to ground and red to 3.3V. Is that correct?
      4. I have a heated chamber that has a heating element connected to SSR. So:
        a) The wires to control SSR are connected to IO_3. Is that correct or it must be connected to OUT_2?
        b) I want to have an additional relay that will disconnect the heating element power supply. Can I connect that to IO_4? This is a typical Arduino relay.
      Thank you for all your answers in advance.
      Cheers
      Dan
      Vetiundefined Dan1990undefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti @Dan1990
        @Dan1990 said in Duet 3 - New user - few quires:
        see
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        no. if they are not powered and have just two wired you connect gnd and io.in. otherwise you are shorting 3.3v to ground.
        see
        https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater
        see
        https://duet3d.dozuki.com/Wiki/Power_Wiring#Section_Controlling_the_external_power_supply
        • Dan1990undefined
          Dan1990
          Veti, thanks for the answer.
          @Veti said in Duet 3 - New user - few quires:
          see
          Understood, thank you.
          see
          I understood that I must connect that to the OUT_2. Thanks
          see
          Regarding that, I am not sure, I must connect the relay to pson pin? Does not make sense to me. I thought that 3 pins are to connect the external supply to power on the duet.
          Any advice regarding the first question?
          Thanks
          Dan
          • Dan1990undefined
            Dan1990 @Dan1990
            Also, what I have read on the forum is that I have to remove all the jumpers if I want to connect the 5v ext supply. Therefore, there will be no jumpers on the 5V headers? Is that correct?
            Can't edit my previous post.
              Phaedrux Moderator @Dan1990
              @Dan1990 See here: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_5V
                dc42 administrators @Dan1990
                see
                Bed heater should be connected to OUT0 unless you are using an external SSR or mosfet switch to control it.
                Dan1990undefined 1 Reply Last reply Reply Quote 0
                • Dan1990undefined
                  Dan1990 @dc42
                  That question was related to the chamber heater but I have solved it - thanks to the very rich documentation that has been made from you.
                  If the sensor is a 2-wire microswitch, we recommend that you use the normally-closed contacts, which are the two outermost tags on the switch (leave the centre tag not connected).
                  However, I am facing another issue a the moment, I have read that Duet recommends having endstops (the very simple one, with two wires) to be wired NC but I have another way around and I wonder if is possible to change that in firmware?
                  I have tried to change the S value from 1 to 0 and from 1 to 2 but that did not work.
                    In RRF3 you would use M574 S1 but invert the signal by adding a ! to the pin name.
                    ex M574 Z1 S1 P"!zstop"
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
                    • Dan1990undefined
                      Dan1990 @Phaedrux
                      @Phaedrux
                      Thank you, that worked!
                      One more question - how I can change the safety values for heaters? My chamber heater is not powerful enough to reach 1,7oC/ sec.
                        Usually running a PID auto tune on the heaters is all that's needed to resolve those errors since it gives the firmware an expectation of performance.
                        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                        • Dan1990undefined
                          Dan1990 @Phaedrux
                          @Phaedrux
                          I have done that, hopefully will help.
                            Make sure you remember to use M500 to save the results to confif-override.g and add M501 to the end of config.g to load those results at startup.
                            • Dan1990undefined
                              Dan1990 @Phaedrux
                              @Phaedrux
                              Did that, the RRF notified me after PID tuning!
                              I am so amazed by the firmware!
                              Worth the money!
                                Can you share the tuned results for the chamber heater? Increasing the dead time value can sometimes help.
                                Share the entire config.g as well.
                                • Dan1990undefined
                                  Dan1990 @Phaedrux
                                  @Phaedrux
                                  ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sun Jan 10 2021 17:23:39 GMT+0000 (GMT)
                                  M550 P"Duet 3" ; set printer name
                                  M569 P0.0 S0 ; physical drive 0.0 goes backwards
                                  M569 P0.2 S0 ; physical drive 0.2 goes backwards
                                  M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                                  M92 X201.27 Y201.23 Z800.00 E420.00 ; set steps per mm
                                  M84 S30 ; Set idle timeout
                                  M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
                                  M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                                  M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                                  M208 X220 Y220 Z240 S0 ; set axis maxima
                                  M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin io0.in
                                  M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin io1.in
                                  M574 Z1 S1 P"!io2.in" ; configure active-high endstop for low end on Z via pin io2.in
                                  ;;M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
                                  ;G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
                                  ;M557 X15:215 Y15:195 S20 ; define mesh grid
                                  M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                                  M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                                  M308 S2 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin temp2
                                  M950 H2 C"out2" T2 ; create chamber heater output on out2 and map it to sensor 2
                                  M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
                                  M141 H2 ; map chamber to heater 2
                                  M143 H2 S100 A0 ; set temperature limit for heater 2 to 100C
                                  M301 H2 B1
                                  M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                                  M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
                                  M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                                  M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
                                  The PID as below:
                                  Heater 2 model: gain 340.0, time constant 140.0, dead time 5.5, max PWM 1.oo, calibration voltage 0.0, mode PID
                                  Computed PID parameters for setpoint change P13.4, I0, 482, D51,4
                                  Computed PID parameters for load change P13.4 i0.949, D51.4
                                  Could you advise me on how to invert the Z2 motor, I did the Z1.
                                  Phaedruxundefined 3 Replies Last reply Reply Quote 0
                                    I don't know what you mean by this.
                                      Share the contents of your config-override.g so we can see the actual formatted M307 commands
                                      • Dan1990undefined
                                        Dan1990 @Phaedrux
                                        @Phaedrux
                                        I am sorry for not being clear enough,
                                        I have two Z-axis, I have changed the rotation of Z1 (rotating anticlockwise) but Z2 rotating clockwise
                                        • Dan1990undefined
                                          Dan1990 @Phaedrux
                                          @Phaedrux
                                          ; config-override.g file generated in response to M500 at 2021-01-05 16:33
                                          ; Heater model parameters
                                          M307 H0 R0.000 C495.100:140.000 D0.80 S1.00 V24.0 B0
                                          M307 H1 R0.000 C140.000:140.000 D5.50 S1.00 V0.0 B0
                                          M307 H2 R0.000 C140.000:140.000 D5.50 S1.00 V0.0 B0
                                          ; Workplace coordinates
                                          G10 L2 P1 X0.00 Y0.00 Z0.00
                                          G10 L2 P2 X0.00 Y0.00 Z0.00
                                          G10 L2 P3 X0.00 Y0.00 Z0.00
                                          G10 L2 P4 X0.00 Y0.00 Z0.00
                                          G10 L2 P5 X0.00 Y0.00 Z0.00
                                          G10 L2 P6 X0.00 Y0.00 Z0.00
                                          G10 L2 P7 X0.00 Y0.00 Z0.00
                                          G10 L2 P8 X0.00 Y0.00 Z0.00
                                          G10 L2 P9 X0.00 Y0.00 Z0.00
                                            You only have a single Z driver defined, so I'm surprised the other is turning at all. Which driver are you using for Z1 and which for Z2?
