Duet 3 - New user - few quires
1.0k
    Usually running a PID auto tune on the heaters is all that's needed to resolve those errors since it gives the firmware an expectation of performance.
    https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
    undefined 1 Reply Last reply 13 Jan 2021, 21:28 Reply Quote 0
      Dan1990 @Phaedrux
      @Phaedrux
      I have done that, hopefully will help.
        Make sure you remember to use M500 to save the results to confif-override.g and add M501 to the end of config.g to load those results at startup.
        undefined 1 Reply Last reply 13 Jan 2021, 21:35 Reply Quote 0
          Dan1990 @Phaedrux
          @Phaedrux
          Did that, the RRF notified me after PID tuning!
          I am so amazed by the firmware!
          Worth the money!
            Phaedrux Moderator @Dan1990
            @Dan1990 said in Duet 3 - New user - few quires:
            My chamber heater is not powerful enough to reach 1,7oC/ sec.
            Can you share the tuned results for the chamber heater? Increasing the dead time value can sometimes help.
            Share the entire config.g as well.
            undefined 1 Reply Last reply 13 Jan 2021, 21:47 Reply Quote 0
              Dan1990 @Phaedrux
              @Phaedrux
              ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sun Jan 10 2021 17:23:39 GMT+0000 (GMT)
              M550 P"Duet 3" ; set printer name
              M569 P0.0 S0 ; physical drive 0.0 goes backwards
              M569 P0.2 S0 ; physical drive 0.2 goes backwards
              M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
              M92 X201.27 Y201.23 Z800.00 E420.00 ; set steps per mm
              M84 S30 ; Set idle timeout
              M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
              M671 X-20:220 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
              M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
              M208 X220 Y220 Z240 S0 ; set axis maxima
              M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin io0.in
              M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin io1.in
              M574 Z1 S1 P"!io2.in" ; configure active-high endstop for low end on Z via pin io2.in
              ;;M558 P5 C"^io3.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
              ;G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
              ;M557 X15:215 Y15:195 S20 ; define mesh grid
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
              M308 S2 P"temp2" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin temp2
              M950 H2 C"out2" T2 ; create chamber heater output on out2 and map it to sensor 2
              M307 H2 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
              M141 H2 ; map chamber to heater 2
              M143 H2 S100 A0 ; set temperature limit for heater 2 to 100C
              M301 H2 B1
              M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
              M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
              M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
              M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
              The PID as below:
              Heater 2 model: gain 340.0, time constant 140.0, dead time 5.5, max PWM 1.oo, calibration voltage 0.0, mode PID
              Computed PID parameters for setpoint change P13.4, I0, 482, D51,4
              Computed PID parameters for load change P13.4 i0.949, D51.4
              Could you advise me on how to invert the Z2 motor, I did the Z1.
              undefined 3 Replies Last reply 13 Jan 2021, 21:48 Reply Quote 0
                I don't know what you mean by this.
                undefined 1 Reply Last reply 13 Jan 2021, 21:50 Reply Quote 0
                  Share the contents of your config-override.g so we can see the actual formatted M307 commands
                  undefined 1 Reply Last reply 13 Jan 2021, 21:51 Reply Quote 0
                    Dan1990 @Phaedrux
                    @Phaedrux
                    I am sorry for not being clear enough,
                    I have two Z-axis, I have changed the rotation of Z1 (rotating anticlockwise) but Z2 rotating clockwise
                      Dan1990 @Phaedrux
                      @Phaedrux
                      ; config-override.g file generated in response to M500 at 2021-01-05 16:33
                      ; Heater model parameters
                      M307 H0 R0.000 C495.100:140.000 D0.80 S1.00 V24.0 B0
                      M307 H1 R0.000 C140.000:140.000 D5.50 S1.00 V0.0 B0
                      M307 H2 R0.000 C140.000:140.000 D5.50 S1.00 V0.0 B0
                      ; Workplace coordinates
                      G10 L2 P1 X0.00 Y0.00 Z0.00
                      G10 L2 P2 X0.00 Y0.00 Z0.00
                      G10 L2 P3 X0.00 Y0.00 Z0.00
                      G10 L2 P4 X0.00 Y0.00 Z0.00
                      G10 L2 P5 X0.00 Y0.00 Z0.00
                      G10 L2 P6 X0.00 Y0.00 Z0.00
                      G10 L2 P7 X0.00 Y0.00 Z0.00
                      G10 L2 P8 X0.00 Y0.00 Z0.00
                      G10 L2 P9 X0.00 Y0.00 Z0.00
                      undefined 1 Reply Last reply 13 Jan 2021, 21:53 Reply Quote 0
                        You only have a single Z driver defined, so I'm surprised the other is turning at all. Which driver are you using for Z1 and which for Z2?
                        undefined 1 Reply Last reply 13 Jan 2021, 21:54 Reply Quote 0
                          I find it odd that your hotend heater and chamber heater are using the same values.
                          I suggest you re-run the PID turning for each heater in turn and then save the results again with M500
                            Dan1990 @Phaedrux
                            @Phaedrux
                            See above, I have read that I should add those g-codes and it is in the file
                            I am using 0.4 pin
                              Ah I see now.
                              The M584 you have needs to move up and replace the one above it that I quoted.
                              undefined 1 Reply Last reply 13 Jan 2021, 21:58 Reply Quote 0
                                Dan1990 @Phaedrux
                                @Phaedrux
                                Silly me, I should notice that, changing that right away.
                                I will perform PID tuning and will paste the results here.
                                Btw: Should the Diagnostic LED blink all the time? I have Duet 3.
                                I have read that is normal but prefer to confirm
                                  yes that is normal
                                  undefined 1 Reply Last reply 14 Jan 2021, 18:06 Reply Quote 0
                                    Dan1990
                                    The PID from yesterday tunning as follow:
                                    ; config-override.g file generated in response to M500 at 2021-01-05 16:59
                                    M307 H0 R0.000 C140.000:140.000 D5.50 S1.00 V0.0 B0
                                    M307 H1 R0.000 C167.200:140.000 D4.50 S1.00 V24.1 B0
                                    M307 H2 R0.000 C231.100:140.000 D4.60 S1.00 V24.1 B0
                                    I have runout into one problem. When I tried to do homing the all axis are behaving kind of strange. They are doing normal homing, moving towards endstop, engaging them and repreating that like in the loop.
                                    I checked the endstops by M119, all of the are working.
                                    Any idea what that could be?
                                    Thats the homeall.g file:
                                    ; homeall.g
                                    ; called to home all axes
                                    G91 ; relative positioning
                                    G1 H1 X-225 Y-225 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                    G1 H2 X5 Y5 F6000 ; go back a few mm
                                    G1 H1 X-225 Y-225 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                    G1 H1 Z-245 F360 ; move Z down stopping at the endstop
                                    G90 ; absolute positioning
                                    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                                    G1 Z5 F100 ; lift Z relative to current position
                                      Dan1990
                                      Can that be related to M122?
                                      When I do diagnostic it says M122 response too long, see the console.
                                      M122 below:
                                      M122
                                      RepRapFirmware for Duet 3 MB6HC version 3.01-RC9 running on Duet 3 MB6HC v1.01 or later
                                      Board ID: 08DJM-956BA-NA3TJ-6JTD4-3S06M-KV8GSUsed output buffers: 1 of 40 (12 max)
                                      Static ram: 154572
                                      Dynamic ram: 162108 of which 52 recycled
                                      Exception stack ram used: 216
                                      Never used ram: 76268
                                      Tasks: NETWORK(ready,2076) HEAT(blocked,1184) CanReceiv(suspended,3824) CanSender(suspended,1484) CanClock(blocked,1432) TMC(blocked,216) MAIN(running,4444) IDLE(ready,80)
                                      Owned mutexes:
                                      Last reset 00:07:50 ago, cause: power up
                                      Last software reset at 2021-01-05 17:38, reason: User, spinning module LinuxInterface, available RAM 76036 bytes (slot 3)
                                      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
                                      Error status: 0
                                      Free file entries: 10
                                      MCU temperature: min 28.5, current 28.8, max 28.9
                                      Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                      12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                                      Driver 0: standstill, reads 57130, writes 0 timeouts 0, SG min/max not available
                                      Driver 1: standstill, reads 57129, writes 0 timeouts 0, SG min/max not available
                                      Driver 2: standstill, reads 57130, writes 0 timeouts 0, SG min/max not available
                                      Driver 3: standstill, reads 57130, writes 0 timeouts 0, SG min/max not available
                                      Driver 4: standstill, reads 57130, writes 0 timeouts 0, SG min/max not available
                                      Driver 5: standstill, reads 57130, writes 0 timeouts 0, SG min/max not available
                                      Date/time: 2021-01-14 13:11:15
                                      Slowest loop: 3.55ms; fastest: 0.21ms
                                      === MainDDARing ===
                                      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                      === AuxDDARing ===
                                      Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
                                      Segments left: 0
                                      Movement lock held by null
                                      HTTP* is ready with "M122" in state(s) 0
                                      Telnet is idle in state(s) 0
                                      File is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      LCD is idle in state(s) 0
                                      SBC is idle in state(s) 0
                                      Daemon* is idle in state(s) 0
                                      Code queue is empty.
                                      === Network ===
                                      Slowest loop: 0.46ms; fastest: 0.01ms
                                      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                                      HTTP sessions: 0 of 8
                                      • Ethernet -
                                        State: disabled
                                        Error counts: 0 0 0 0 0
                                        === CAN ===
                                        Messages sent 258, longest wait 0ms for type 0
                                        === Linux interface ===
                                        State: 0, failed transfers: 1
                                        Last transfer: 17ms ago
                                        RX/TX seq numbers: 17840/17841
                                        SPI underruns 1, overruns 1
                                        Number of disconnects: 0
                                        Buffer RX/TX: 0/0-0
                                        === Duet Control Server ===
                                        Duet Control Server v3.2.0
                                        Code buffer space: 4096
                                        Full transfers per second: 39.64
                                        Maximum length of RX/TX data transfers: 3140/624
                                      undefined 1 Reply Last reply 14 Jan 2021, 17:01 Reply Quote 0
                                        jay_s_uk
                                        your homing file has 2 homing passes in.
                                        Are you saying the axis approach and back away more than twice?
                                        undefined 1 Reply Last reply 14 Jan 2021, 13:29 Reply Quote 0
                                          Dan1990 @jay_s_uk
                                          @jay_s_uk
                                          Yes, it is like the homing file was in the loop.
                                          19 out of 34
