    Changing pt100 to standard thermistor
    3.1k
      Phaedrux Moderator @Atraedes
      @Atraedes said in Changing pt100 to standard thermistor:
      ; Tool 0
      M307 H1 A1230.8 C312.7 D7.2 S1.00 V26.3 B0
      M305 P1 X200 ; Set PT100 + ADC parameters for heater 1
      It's the M305 P1 X200 that configures it to use a PT100.
      Compare that to the M305 line for the bed which is using a thermistor.
      You'd change the X200 to be the thermistor values for your new thermistor.
      M305 P1 T100000 B3950 for example, is what you'd use for a generic NTC100K 3950 thermisor.
      • Atraedesundefined
        Atraedes
        the first errors were what i mentioned before about the temp warning that the heater was over powered and may get to over 2k c, but then also intermittent heater 1 faults and i have to reset all the time, the daughter board seems ok but i guess i may have got a pt100 to big perhaps?
        • Vetiundefined
          Veti
          sovol sv01
          according to this
          https://github.com/CopterTec/Marlin-Sovol_SV01/blob/master/config/SOVOL/SV01/Configuration.h
          EPCOS 100k
          Atraedesundefined 1 Reply Last reply Reply Quote 0
            Can you also post the results of M122?
            Is your power supply 12v or 24v?
            Is the heater cartridge 12v or 24v?
            Normally the warning of over powered heater is just a warning, but your estimated temp of 1500c or whatever it was is abnormally large. That makes me worry that your heater cartridge may be 12v and your power supply 24v, which would be a dangerous combination.
            • Atraedesundefined
              Atraedes
              sorry tried m122 but its says the response is to long
                Send it from the console tab
                • Atraedesundefined
                  Atraedes
                  ok i will take a pic, 2 secs
                  • Atraedesundefined
                    Atraedes
                    chiron.jpg )
                    • Atraedesundefined
                      Atraedes @Veti
                      @Veti cheers mate
                      • Atraedesundefined
                        Atraedes @Phaedrux
                        @Phaedrux M122
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                        Board ID: 08DJM-9178L-L2MS8-6JKFL-3SD6N-KVGQN
                        Used output buffers: 3 of 24 (17 max)
                        Static ram: 25712
                        Dynamic ram: 93176 of which 0 recycled
                        Exception stack ram used: 320
                        Never used ram: 11864
                        Tasks: NETWORK(ready,628) HEAT(blocked,832) MAIN(running,3728) IDLE(ready,160)
                        Owned mutexes:
                        Last reset 00:18:35 ago, cause: power up
                        Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11956 bytes (slot 0)
                        Error status: 0
                        Free file entries: 10
                        MCU temperature: min 28.3, current 28.4, max 28.8
                        Supply voltage: min 26.3, current 26.4, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
                        Date/time: 2021-01-11 21:09:04
                        Cache data hit count 3407316226
                        Slowest loop: 3.10ms; fastest: 0.07ms
                        Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
                        === DDARing ===
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        http is idle in state(s) 0
                        telnet is idle in state(s) 0
                        file is idle in state(s) 0
                        serial is idle in state(s) 0
                        aux is idle in state(s) 0
                        daemon is idle in state(s) 0
                        queue is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 201.14ms; fastest: 0.08ms
                        HTTP sessions: 1 of 8
                        • WiFi -
                          Network state is running
                          Failed messages: pending 0, notready 0, noresp 4
                          WiFi firmware version 1.23
                          WiFi MAC address cc:50:e3:e3:ad:08
                          WiFi Vcc 3.40, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 23952
                          WiFi IP address 192.168.0.28
                          WiFi signal strength -58dBm, reconnections 0, sleep mode modem
                        • Atraedesundefined
                          Atraedes
                          @Phaedrux said in Changing pt100 to standard thermistor:
                          so M305 P1 T100000 B3950 is the g code for the standard epcos 100k thermistor i can install instead? and then just wire it to the conventional thermistor terminal instead and simply remove the daughter board?
                            Your power supply seems to be tuned a bit high. Can you carefully check the output voltage with a multimeter?
                            Are you sure your hotend heater cartridge is 24v?
                              Correct.
                              • Atraedesundefined
                                Atraedes @Phaedrux
                                @Phaedrux i thought so to lol, but the multimeter is at the inlaws and i cant get it back, lockdown lol, but thanks, i will check it when i get it back
                                • Atraedesundefined
                                  Atraedes @Phaedrux
                                  @Phaedrux fantastic, many thanks, so programme the G-Code first and then wire it in, or it doesn't matter? I cant say for sure about the heater cartridge as i have so many spares lying around it might very well be a 12v but I didn't think it was due to its size, but now that i can rewire to the standard thermistor i have the complete hotend for the direct drive rig, sir, thanks again for your assistance, much appreciated!
                                    If your PSU has a trim pot for adjusting the output voltage try giving it a slight tweak and see if it reduces the value in the M122 a bit. Aim for 24v.
                                    Then if you connect your new thermistor and run a PID tuning see if the warning is the same. If it still estimates a 1000c+ max temp you should beware.
                                    You can also check your thermistor resistance with a multimeter to see if it's closer to 12v or 24v, but.. multimeter...
                                    • Atraedesundefined
                                      Atraedes @Phaedrux
                                      @Phaedrux thanks, ive just sent the comand and this came back, is this ok to now rewire or is there a problem? it says error...
                                      Heater 1 uses PT100 (MAX31865) sensor channel 200, last error: short-circuit in sensor, 2/4 wires, reject 50Hz, reference resistor 400 ohms
                                        You should make the change to config.g and then reboot. You can rewire whenever you wish.
                                        • Vetiundefined
                                          Veti @Atraedes
                                          actually the epocs is T98801 B4185
                                          • Atraedesundefined
                                            Atraedes
                                            @Veti said in Changing pt100 to standard thermistor:
                                            Great, thanks, so instead then - M305 P1 T100000 B4185 ?
