    Changing pt100 to standard thermistor
    3.1k
    • Atraedesundefined
      Atraedes @Veti
      @Veti cheers mate
      • Atraedesundefined
        Atraedes @Phaedrux
        @Phaedrux M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
        Board ID: 08DJM-9178L-L2MS8-6JKFL-3SD6N-KVGQN
        Used output buffers: 3 of 24 (17 max)
        Static ram: 25712
        Dynamic ram: 93176 of which 0 recycled
        Exception stack ram used: 320
        Never used ram: 11864
        Tasks: NETWORK(ready,628) HEAT(blocked,832) MAIN(running,3728) IDLE(ready,160)
        Owned mutexes:
        Last reset 00:18:35 ago, cause: power up
        Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11956 bytes (slot 0)
        Error status: 0
        Free file entries: 10
        MCU temperature: min 28.3, current 28.4, max 28.8
        Supply voltage: min 26.3, current 26.4, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
        Date/time: 2021-01-11 21:09:04
        Cache data hit count 3407316226
        Slowest loop: 3.10ms; fastest: 0.07ms
        Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
        === DDARing ===
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is idle in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 201.14ms; fastest: 0.08ms
        HTTP sessions: 1 of 8
        • WiFi -
          Network state is running
          Failed messages: pending 0, notready 0, noresp 4
          WiFi firmware version 1.23
          WiFi MAC address cc:50:e3:e3:ad:08
          WiFi Vcc 3.40, reset reason Turned on by main processor
          WiFi flash size 4194304, free heap 23952
          WiFi IP address 192.168.0.28
          WiFi signal strength -58dBm, reconnections 0, sleep mode modem
        • Atraedesundefined
          Atraedes
          @Phaedrux said in Changing pt100 to standard thermistor:
          M305 P1 T100000 B3950
          so M305 P1 T100000 B3950 is the g code for the standard epcos 100k thermistor i can install instead? and then just wire it to the conventional thermistor terminal instead and simply remove the daughter board?
            @Atraedes said in Changing pt100 to standard thermistor:
            Your power supply seems to be tuned a bit high. Can you carefully check the output voltage with a multimeter?
            Are you sure your hotend heater cartridge is 24v?
            Atraedesundefined 1 Reply Last reply Reply Quote 0
              Phaedrux Moderator @Atraedes
              Correct.
              • Atraedesundefined
                Atraedes @Phaedrux
                @Phaedrux i thought so to lol, but the multimeter is at the inlaws and i cant get it back, lockdown lol, but thanks, i will check it when i get it back
                • Atraedesundefined
                  Atraedes @Phaedrux
                  @Phaedrux fantastic, many thanks, so programme the G-Code first and then wire it in, or it doesn't matter? I cant say for sure about the heater cartridge as i have so many spares lying around it might very well be a 12v but I didn't think it was due to its size, but now that i can rewire to the standard thermistor i have the complete hotend for the direct drive rig, sir, thanks again for your assistance, much appreciated!
                    If your PSU has a trim pot for adjusting the output voltage try giving it a slight tweak and see if it reduces the value in the M122 a bit. Aim for 24v.
                    Then if you connect your new thermistor and run a PID tuning see if the warning is the same. If it still estimates a 1000c+ max temp you should beware.
                    You can also check your thermistor resistance with a multimeter to see if it's closer to 12v or 24v, but.. multimeter...
                    • Atraedesundefined
                      Atraedes @Phaedrux
                      @Phaedrux thanks, ive just sent the comand and this came back, is this ok to now rewire or is there a problem? it says error...
                      Heater 1 uses PT100 (MAX31865) sensor channel 200, last error: short-circuit in sensor, 2/4 wires, reject 50Hz, reference resistor 400 ohms
                        You should make the change to config.g and then reboot. You can rewire whenever you wish.
                        • Vetiundefined
                          Veti @Atraedes
                          actually the epocs is T98801 B4185
                          • Atraedesundefined
                            Atraedes
                            @Veti said in Changing pt100 to standard thermistor:
                            Great, thanks, so instead then - M305 P1 T100000 B4185 ?
                              T98801 B4185
                              M305 P1 T98801 B4185
                              • Atraedesundefined
                                Atraedes
                                ; Tool 0
                                M307 H1 A1230.8 C312.7 D7.2 S1.00 V26.3 B0
                                M305 P1 X200 ; Set PT100 + ADC parameters for heater 1
                                great, thanks, so change it here in config :
                                ; Tool 0
                                So change M305 to the code you said, change M143 to new max temp on new hotend, thanks again for all
                                • Atraedesundefined
                                  Atraedes
                                  Hi @Phaedrux, thanks again for your help, it worked great, however, after i did the pid tune i tried to save it with M500 but it says "Warning: No M501 command was executed in config.g", ive since done a couple test prints also and it has flagged up "Error: Heating fault on heater 1" a couple of times, im stumped, the wiring is fine and checked, not sure where to go or why it doesnt take the M500 command
                                  Stephen6309undefined 1 Reply Last reply Reply Quote 0
                                  • Stephen6309undefined
                                    Stephen6309 @Atraedes
                                    @Atraedes You need a M510 at the end of config,g.
                                    • Atraedesundefined
                                      Atraedes
                                      thanks, tried it, it says "Warning: M510 command is not supported"
                                        https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
                                        M500 saves to config-override.g, and M501 loads it. You need to add M501 to the end of config.g to load the saved values at startup.
                                        • Atraedesundefined
                                          Atraedes
                                          the sd card is buried deep in the machine also so i cant easily get to it without taking the bottom of etc.., i just assumed i could do everything via the console?
                                            @Atraedes Oops, i ment M501. The keyboard keeps reversing things. 🙂
