Changing pt100 to standard thermistor
@Atraedes said in Changing pt100 to standard thermistor:
sovol sv01
according to this
https://github.com/CopterTec/Marlin-Sovol_SV01/blob/master/config/SOVOL/SV01/Configuration.h
EPCOS 100k
Can you also post the results of M122?
Is your power supply 12v or 24v?
Is the heater cartridge 12v or 24v?
Normally the warning of over powered heater is just a warning, but your estimated temp of 1500c or whatever it was is abnormally large. That makes me worry that your heater cartridge may be 12v and your power supply 24v, which would be a dangerous combination.
sorry tried m122 but its says the response is to long
Send it from the console tab
ok i will take a pic, 2 secs
@Veti cheers mate
@Phaedrux M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MS8-6JKFL-3SD6N-KVGQN
Used output buffers: 3 of 24 (17 max)
Static ram: 25712
Dynamic ram: 93176 of which 0 recycled
Exception stack ram used: 320
Never used ram: 11864
Tasks: NETWORK(ready,628) HEAT(blocked,832) MAIN(running,3728) IDLE(ready,160)
Owned mutexes:
Last reset 00:18:35 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11956 bytes (slot 0)
Error status: 0
Free file entries: 10
MCU temperature: min 28.3, current 28.4, max 28.8
Supply voltage: min 26.3, current 26.4, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
Date/time: 2021-01-11 21:09:04
Cache data hit count 3407316226
Slowest loop: 3.10ms; fastest: 0.07ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 201.14ms; fastest: 0.08ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
Failed messages: pending 0, notready 0, noresp 4
WiFi firmware version 1.23
WiFi MAC address cc:50:e3:e3:ad:08
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 23952
WiFi IP address 192.168.0.28
WiFi signal strength -58dBm, reconnections 0, sleep mode modem
- WiFi -
@Phaedrux said in Changing pt100 to standard thermistor:
M305 P1 T100000 B3950
so M305 P1 T100000 B3950 is the g code for the standard epcos 100k thermistor i can install instead? and then just wire it to the conventional thermistor terminal instead and simply remove the daughter board?
Your power supply seems to be tuned a bit high. Can you carefully check the output voltage with a multimeter?
Are you sure your hotend heater cartridge is 24v?
Correct.
@Phaedrux i thought so to lol, but the multimeter is at the inlaws and i cant get it back, lockdown lol, but thanks, i will check it when i get it back
@Phaedrux fantastic, many thanks, so programme the G-Code first and then wire it in, or it doesn't matter? I cant say for sure about the heater cartridge as i have so many spares lying around it might very well be a 12v but I didn't think it was due to its size, but now that i can rewire to the standard thermistor i have the complete hotend for the direct drive rig, sir, thanks again for your assistance, much appreciated!
If your PSU has a trim pot for adjusting the output voltage try giving it a slight tweak and see if it reduces the value in the M122 a bit. Aim for 24v.
Then if you connect your new thermistor and run a PID tuning see if the warning is the same. If it still estimates a 1000c+ max temp you should beware.
You can also check your thermistor resistance with a multimeter to see if it's closer to 12v or 24v, but.. multimeter...
@Phaedrux thanks, ive just sent the comand and this came back, is this ok to now rewire or is there a problem? it says error...
Heater 1 uses PT100 (MAX31865) sensor channel 200, last error: short-circuit in sensor, 2/4 wires, reject 50Hz, reference resistor 400 ohms -
You should make the change to config.g and then reboot. You can rewire whenever you wish.
actually the epocs is T98801 B4185
@Veti said in Changing pt100 to standard thermistor:
Great, thanks, so instead then - M305 P1 T100000 B4185 ?
; Tool 0
M307 H1 A1230.8 C312.7 D7.2 S1.00 V26.3 B0
M305 P1 X200 ; Set PT100 + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280Cgreat, thanks, so change it here in config :
; Tool 0
So change M305 to the code you said, change M143 to new max temp on new hotend, thanks again for all
