BLTouch Pin won't come out
Hello everyone,
I followed the tutorial from betrue3d.dk to set up my BLTouch.
BLTouch is wired to "heater7" just like in the tutorial.
Unfortunately the pin from my BLTouch will not go down when I send "M280 P7 S10"
Can you help me out? What's the problem?
When turning on the printer, the BLTouch lights red and the pin comes out two times automatically and drives in (lifts up). That's it. No manually positioning of the pin.
post your config.
output of M115
and a picture of your wiring
@Veti do you mean just the config.g or all config files?
M115
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet Ethernet 1.02 or later FIRMWARE_DATE: 2020-12-24I post my wiring in some minutes
@heinrich-platau said in BLTouch Pin won't come out:
M280 P7 S10
ok this is not the command for version 3 firmware
version 3 is
M280 P0 S10i would suggest that you generate the config with the configurtor, as it will generate it correctly for version 3
also post your config.g
Also please update your firmware to 3.2 final. Upload this zip file as is to the system tab in DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
; generated by RepRapFirmware Configuration Tool v3.2.1 on Fri Jan 15 2021 19:04:07 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M550 P"X400-PLATAU" ; set printer name; Network
M552 P172.192.196.112 S1 ; enable network and set IP address
M553 P255.255.255.0 ; set netmask
M554 P172.192.196.1 ; set gateway
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M584 X0 Y1:4 Z2 E3 ; set drive mapping
M92 X66.67 Y66.67 Z2400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E480.00 ; set maximum instantaneous speed changes (mm/min)
M203 X24000.00 Y24000.00 Z300.00 E4800.00 ; set maximum speeds (mm/min)
M201 X2000.00 Y2000.00 Z80.00 E800.00 ; set accelerations (mm/s^2)
M208 X400 Y400 Z320 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F500 T4000 X0 Y0 Z1 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-37 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:385 Y15:385 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 R0.085 C1598.722:1598.722 D40.63 S1.00 V24.3 B0 ; set the process parameters for heater 0
M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
M143 H1 S350 ; set temperature limit for heater 1 to 350C
M950 P0 C"exp. heater7" ; BLTouch - Heaters. Disable the 7th Heater to free up PWM channel 5 on the DuexBoard (Outbreak-Port); Fans
M106 P0 C"Druckteil-Kühler" S0 H1 T200 ; set fan 0 name and value. Thermostatic control is turned on
M106 P1 C"HotEnd-Lüfter" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on; Tools
M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
Your retract and deploy macros need to change.
M280 P7 S90 I1 ; retract BLTouch
The P7 needs to be P0 in both. And remove the I1.
remove this line
M106 P1 C"HotEnd-Lüfter" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned onthis means you have no part cooling fan. is that really what you want?
is that the correct current for your motors?
please update to 3.2 final
@Phaedrux thank you,
I have changed the macros to P0.
Also I have updated the firmware to 3.2 final.
Send M98 P"config.g" to check the rest of your config.g for any syntax errors.
@Veti thank you very much Veti
after removing the line M950 P0C"exp. heater7" the BLTouch works.
Can you please help me further with you other questiones.
Just right now I don't have installed a part cooling fan. But I thought that I've configured the duet so, that there is a part cooling fan and I will just need to plug the fan in.
(First I need to order 24V Fans. My old fans from the old setup were 12V Fans)
The current for my motors? It's 800 mA for each motor. That's the default in configtool.... I haven't tuned them so far. Do you have another suggestion for default setting for the current?
@Phaedrux after sending M98 duet says:
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabledHTTP is enabled on port 80
FTP is disabled
FTP is disabled
TELNET is disabledWhat does this mean? That I have duplicate lines in my config?
@Veti said in BLTouch Pin won't come out:
you want
M106 P0 C"Druckteil-Kühler" S0 H-1
this allows the slicer to control the fan with the M106 command.
if you have a buck converted you can use 12v fans with the duet.
if you connect 12v to the v_fan selector pin.
see https://cdn.thingiverse.com/assets/aa/49/81/b2/23/wiring_12v_fan_on_24v_system-min.jpgThe current for my motors? It's 800 mA for each motor. That's the default in configtool.... I haven't tuned them so far. Do you have another suggestion for default setting for the current?
go for 75% of the rated current of the motors.
