BLTouch Pin won't come out
497
    heinrich.platau
    retractprobe.g deployprobe.g config.g
      Phaedrux Moderator @heinrich.platau
      @heinrich-platau said in BLTouch Pin won't come out:
      t FIRMWARE_VERSION: 3.2-RC2
      Also please update your firmware to 3.2 final. Upload this zip file as is to the system tab in DWC.
      https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
        heinrich.platau
        ; generated by RepRapFirmware Configuration Tool v3.2.1 on Fri Jan 15 2021 19:04:07 GMT+0100 (Mitteleuropäische Normalzeit)
        M550 P"X400-PLATAU" ; set printer name
        M552 P172.192.196.112 S1 ; enable network and set IP address
        M553 P255.255.255.0 ; set netmask
        M554 P172.192.196.1 ; set gateway
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P2 S0 ; physical drive 2 goes backwards
        M584 X0 Y1:4 Z2 E3 ; set drive mapping
        M92 X66.67 Y66.67 Z2400.00 E420.00 ; set steps per mm
        M566 X900.00 Y900.00 Z60.00 E480.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X24000.00 Y24000.00 Z300.00 E4800.00 ; set maximum speeds (mm/min)
        M201 X2000.00 Y2000.00 Z80.00 E800.00 ; set accelerations (mm/s^2)
        M84 S30 ; Set idle timeout
        M208 X400 Y400 Z320 S0 ; set axis maxima
        M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H5 F500 T4000 X0 Y0 Z1 ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X-37 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
        M557 X15:385 Y15:385 S20 ; define mesh grid
        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
        M307 H0 R0.085 C1598.722:1598.722 D40.63 S1.00 V24.3 B0 ; set the process parameters for heater 0
        M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
        M143 H1 S350 ; set temperature limit for heater 1 to 350C
        M950 P0 C"exp. heater7" ; BLTouch - Heaters. Disable the 7th Heater to free up PWM channel 5 on the DuexBoard (Outbreak-Port)
        M106 P0 C"Druckteil-Kühler" S0 H1 T200 ; set fan 0 name and value. Thermostatic control is turned on
        M106 P1 C"HotEnd-Lüfter" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
        M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
          Your retract and deploy macros need to change.
          M280 P7 S90 I1 ; retract BLTouch
          The P7 needs to be P0 in both. And remove the I1.
          undefined 1 Reply Last reply 15 Jan 2021, 20:49 Reply Quote 0
            Veti
            remove this line
            this means you have no part cooling fan. is that really what you want?
            is that the correct current for your motors?
            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.2-RC2
            please update to 3.2 final
            undefined 1 Reply Last reply 15 Jan 2021, 20:54 Reply Quote 0
              heinrich.platau @Phaedrux
              @Phaedrux thank you,
              I have changed the macros to P0.
              Also I have updated the firmware to 3.2 final.
                Send M98 P"config.g" to check the rest of your config.g for any syntax errors.
                undefined 1 Reply Last reply 15 Jan 2021, 20:56 Reply Quote 0
                  heinrich.platau @Veti
                  @Veti thank you very much Veti
                  after removing the line M950 P0C"exp. heater7" the BLTouch works.
                  Can you please help me further with you other questiones.
                  Just right now I don't have installed a part cooling fan. But I thought that I've configured the duet so, that there is a part cooling fan and I will just need to plug the fan in.
                  (First I need to order 24V Fans. My old fans from the old setup were 12V Fans)
                  The current for my motors? It's 800 mA for each motor. That's the default in configtool.... I haven't tuned them so far. Do you have another suggestion for default setting for the current?
                    @Phaedrux after sending M98 duet says:
                    M98 P"config.g"
                    HTTP is enabled on port 80
                    FTP is disabled
                    TELNET is disabled
                    FTP is disabled
                    TELNET is disabled
                    FTP is disabled
                    TELNET is disabled
                    What does this mean? That I have duplicate lines in my config?
                      Veti
                      @Veti said in BLTouch Pin won't come out:
                      you want
                      M106 P0 C"Druckteil-Kühler" S0 H-1
                      this allows the slicer to control the fan with the M106 command.
                      if you have a buck converted you can use 12v fans with the duet.
                      if you connect 12v to the v_fan selector pin.
                      see https://cdn.thingiverse.com/assets/aa/49/81/b2/23/wiring_12v_fan_on_24v_system-min.jpg
                      go for 75% of the rated current of the motors.
                      14 out of 14
