    Tool board remote heater auto tune not implemented
    12
    689
    • jdumoulinundefined
      jdumoulin
      I am in the process of setting up my printer with a tool board. The hot end is working but faults out....so I tried to do a tuning.
      M303 H0 S200 D360
      Error: M303: remote heater auto tune not implemented
      Not really sure how to get past this. When I turn the heater on it does heat up for a few seconds....and then goes to fault.
      Here is my current config. While I am at it I am also getting this error in my console which I cannot figure out " M350: Driver 2 does not support x0 microstepping
      Driver 3 does not support x0 microstepping
      Driver 4 does not support x0 microstepping
      Driver 5 does not support x0 microstepping"
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Apr 28 2020 11:14:35 GMT-0400 (Eastern Daylight Time)
      M550 P"Duet 3" ; set printer name
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P0.3 S0 ; physical drive 0.3 goes backwards
      M569 P0.4 S0 ; physical drive 0.4 goes backwards
      M569 P0.5 S0 ; physical drive 0.5 goes forwards
      M569 P20.0 S1 D2 ; physical tool board drive 20.0 goes forwards spreadCycle mode
      M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E20.0 ; set drive mapping
      M350 X16 Y16 Z16:16:16:16 E16 ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z1600.00:1600.00:1600.00:1600.00 E409 ; set steps per mm
      M566 X400.00 Y400.00 Z8.00:8.00:8.00:8.00 E200 ; set maximum instantaneous speed changes (mm/min)
      M203 X35000.00 Y535000.00 Z1200.00:1200.00:1200.00:1200.00 E5000 ; set maximum speeds (mm/min)
      M201 X6000.00 Y6000.00 Z400.00:400.00:400.00:400.00 E2500 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000:1000:1000:1000 e1000 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S3000 ; Set idle timeout
      M208 X775 Y700 Z825 S0 ; set axis maxima
      M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
      M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
      M574 Z1 S1 P"io3.in" ; configure active-high endstop for low end on Z via pin io3.in
      M574 X1 Y1 S3 ; Set X / Y endstop stall detection
      M558 P0 H5 F120 T18000 ; disable Z probe but set dive height, probe speed and travel speed
      M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 ; configure sensor 1 as thermistor on pin 20.temp0
      M950 H0 C"20.out0" T1 ; create nozzle heater output on 20.out0 and map it to sensor 0
      M143 H0 S300 ; set temperature limit for heater 0 to 280C
      ;M307 H1 B0 S1.00 disable bang-bang mode for heater and set PWM limit
      M950 F0 C"20.out2" ; Tool board hot end fan
      M106 P0 S1 H0 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"20.out1" ; Tool board print cooling fan, no tacho
      M106 P1 S0 ; set fan 1 value. Thermostatic control is turned off
      M563 P0 D0 F0 H0 ; define tool 0
      ; Custom settings
        As it says, PID tuning on a tool board is not yet implemented. To work around it, you can connect the heater and sensor to the main board, do the tuning there, and then copy the parameters over.
        jdumoulinundefined 1 Reply Last reply Reply Quote 0
          jdumoulin @Phaedrux
          @Phaedrux I missed that. Thanks
            Alternatively, follow the manual tuning instructions.
            • bernie-mixundefined
              bernie-mix
              Will that be built in at some point?
                @bernie-mix
                Yes, the first step was updating the tuning algorithm, which is part of 3.2. Next step would be tuning remote heaters.
                ctilley79undefined 1 Reply Last reply Reply Quote 2
                • ctilley79undefined
                  ctilley79 @Phaedrux
                  @Phaedrux Is that slated for 3.3 beta?
                    Phaedrux Moderator @ctilley79
                    @ctilley79 I don't think it's in the 3.3 that is currently available for testing, but it's planned to be there eventually.
                    psychotik2k3undefined 1 Reply Last reply Reply Quote 1
                    • psychotik2k3undefined
                      psychotik2k3 @Phaedrux
                      @phaedrux
                      i just discovered this problem, and it's not only the tool board but also the expansion board 3HC. which will be pain in the ass now that i installed and wired my 3 tools on it (and they are short on wire so never be able to put them on the mainboard
                      could you mention this limitation on the documentation of M303 ?
                      jay_s_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
                        jay_s_uk @psychotik2k3
                        @psychotik2k3 upgrade to the latest 3.3RC. Remote tuning is available and the release seems stable
                        psychotik2k3undefined 1 Reply Last reply Reply Quote 0
                          deckingman @psychotik2k3
                          @psychotik2k3 said in Tool board remote heater auto tune not implemented:
                          @phaedrux
                          This was fixed starting with firmware 3.3 beta1 around the beginning of March 2021.
                            psychotik2k3 @jay_s_uk
                            @jay_s_uk @deckingman thanks for the info i will do that especially if the release is stable
