    Duet 3 mini 5+ sensorless homing will not work
    80
    4.6k
    • fcwiltundefined
      fcwilt @Phaedrux
      @Phaedrux said in Duet 3 mini can't configure sensorless homing + missing extruder:
      @fcwilt What settings did you end up with?
      You would ask me that. Let's see...
      I basically followed the documentation and used the suggested values.
      The following were already in the config file that I was using for testing my new board:
      M92 X80
      M201 X1000
      M203 X10000
      M566 X600
      M906 X1000 I30
      These I added for testing:
      M569 P0 S1 V?? (I cannot remember V but it set the crossover speed around 180 mm/s)
      M574 X2 S3 (the doc example has M574 X Y S3 which is missing the X and Y values)
      M913 X70
      M915 X S1 F0 H400 R1 (0.9 stepper - I just grabbed a handy one)
      The "home" command was G91 G1 H1 X999 F10000 G90
      Now I have never tried this before and I wasn't going to spend a lot of time trying to tweak it.
      I was content to verify that it did work sometimes and perhaps just needed different settings or perhaps a different
      stepper.
      Back to my trusty optical end stop sensors. 😉
      Alucardiundefined 1 Reply Last reply Reply Quote 1
      • Alucardiundefined
        Alucardi @fcwilt
        @fcwilt I don’t see what I am missing. My stepper works fine with my old board I guess I am sol. Others have made it work. Think I have a defective board or is it that firmware is not working as it should? Cause it seem like all I find are people having issues.
        Edit: I did find this. But it is unclear if I should use s3 or s4. S4 says it stops the motors individuality but I don’t want that. S3 refers to be used with only 1 motor so I should not use that either. So what should I use?
        86636D32-9257-4113-AA9A-5694B4C9F592.jpeg BBD3DEC4-9DB2-49D1-AD37-995D449AAAAC.jpeg
        • fcwiltundefined
          fcwilt @Alucardi
          @Alucardi said in Duet 3 mini 5+ sensorless homing will not work:
          I wouldn't exactly say I got it to work. It worked maybe 1 time out of 10 tries.
          For a Core XY I THINK you would use S4 so each motor would keep moving until it stalled.
          OK so it turns out you use S3.
          Did I mention that optical end stop sensors work great? 😉
          Alucardiundefined 1 Reply Last reply Reply Quote 0
            S4 is intended for Z axis leveling with multiple motors but instead of endstops stall detection.
            • Alucardiundefined
              Alucardi @fcwilt
              @fcwilt I will not redesign my printer setup to use endstops. The card says it support sensorless homing so that feature should work right? It has worked fine for years using duet 2 card. It took me 2 minutes to get it setup there and now it is a pain in the but.
              Regarding s3 it clearly says single motor. A coreXY don’t have a single motor 🤷‍♂️
              Unless @dc42 have a suggestion it is time for me to leave rrf and move over to klipper where I know sensorless homing works with 2209 drivers.
              • oliofundefined
                oliof
                Did you follow @gloomyandy s suggestion to try the inverted sensitivity setting?
                • Alucardiundefined
                  Alucardi @oliof
                  @oliof yes I replied to him and said it did not work using 64. At -64 it should trigger directly which it does not. It does not even trigger which means something is not working. Either it is a broken firmware or wrong code we can’t figure out.
                  I believe it to be firmware though since even if downloading 3.2 firmware we are stuck on beta, Wonder why they don’t fix that 🤷‍♂️
                  • oliofundefined
                    oliof
                    I'll try a small setup tonight. unfortunately my mini beta board is on a version that doesn't support sensorless homing yet and won't be updated anymore. But downstream I see your problem with sensorless homing was fixed, so yay!
                    • Vetiundefined
                      Veti @Alucardi
                      if you are on the beta, then stall detection is not implemented
                      to update see
                      https://forum.duet3d.com/topic/20382/unable-to-update-firmware-on-duet-mini-5-ethernet
                        jay_s_uk
                        TBH, I couldn't get mine to stall with a simple movement with S set to -64 either.
                        • Alucardiundefined
                          Alucardi @Veti
                          @Veti why is this not fixed in the stable release?
                          • Vetiundefined
                            Veti @Alucardi
                            @Alucardi
                            it is. but the problem is your current programmer
                            • Alucardiundefined
                              Alucardi @jay_s_uk
                              @jay_s_uk which means something is not working. It should detect directly. I tried it in my old duet 2 when I was setting that up. It detected a stall as soon as it tried to move the axis.
                              • Alucardiundefined
                                Alucardi @Veti
                                @Veti my current programmer?
                                • Vetiundefined
                                  Veti @Alucardi
                                  have you read the linked thread?
                                  • Alucardiundefined
                                    Alucardi @Veti
                                    @Veti yes and I am no coder so I do not know what a iap file is 🤷‍♂️ Thread is a month old.
                                    • Vetiundefined
                                      Veti @Alucardi
                                      @Alucardi
                                      just replace the iap file linked in the thread and update the firmware again.
                                      • Alucardiundefined
                                        Alucardi @Veti
                                        @Veti I have uploaded that file to my card and managed to update I believe. But why does it have to be manually fixed? Not everyone goes to the forum and look on that thread. I downloaded 3.2 a week ago and assumed it was working fine cause I got no error. Just by luck did I see it still said beta when looking around in the menus. I then redownloaded the needed files but it was still on beta.
                                        • Alucardiundefined
                                          Alucardi
                                          This might be one thing that cause my issue. Changed to X2 and Y2 and it seem to work.
                                          M574 X1 S3                                               ; configure sensorless endstop for low end on X
                                          M574 Y1 S3                                               ; configure sensorless endstop for low end on Y
                                          M574 Z1 S2                                               ; configure Z-probe endstop for low end on Z
                                          • fcwiltundefined
                                            fcwilt
                                            All these posts and we forgot to verify what firmware you were using?
                                            That's a bit embarrassing.
