    stepper precision
    3D Printing General Chat
    6.4k
    • arhiundefined
      arhi
      open loop, full circle, S42B
      • arhiundefined
        arhi
        in closed loop mode the S42B display show constantly error between -0.04° to +0.04°
        closed loop is running "much" colder than open loop and I doubt it's using full current I configured it to use (can't dig out my current probe to test, no way to get to it now)
        • alankilianundefined
          alankilian
          The closed-loop mode of the S42B is not intended to improve accuracy compared to open-loop mode when the motor load is well below the motor's load limit.
          It's intended to improve accuracy when the load intermittently exceeds the maximum motor load.
          Try your open-loop vs. closed-loop experiment and hold the rotor with something for 10 steps and see how the closed-loop corrects for that once you remove the load and the open loop mode does not correct the error.
          THAT'S what the closed-loop mode is for. It might cost you some accuracy in the step-to-step positioning, but you gain the ability to (when the load is lessened) correct for overload conditions and missed-steps.
          Open-loop cannot do that.
          • arhiundefined
            arhi
            • arhiundefined
              arhi @alankilian
              @alankilian said in stepper precision:
              it does correct the missed steps, but it should be also more precise than what I'm seeing 😞 ... 1° error !?!? that's more than half a step
              Anyhow done with S42B, moving on to TMC2208 driver and different motors
              • arhiundefined
                arhi
                Would also be cool if someone can reproduce measurements with S42B as this does not require super good/expensive/high resolution encoder, even cheap 1000 lines encoder should be able to see error 0.5° and 1°
                • arhiundefined
                  arhi
                  • fcwiltundefined
                    fcwilt @arhi
                    @arhi said in stepper precision:
                    Have you done any testing of the "two piece" closed loop systems consisting of a stepper/encoder and separate control unit?
                    • arhiundefined
                      arhi @fcwilt
                      @fcwilt said in stepper precision:
                      Haven't got to it yet, can't find where I put my vallder stepper with encoder and driver combo. Also I wanna finish with few nema17 before I have to use another mount to test the bigger motor
                      • arhiundefined
                        arhi
                        • arhiundefined
                          arhi
                          second super whooper
                          • arhiundefined
                            arhi
                            third super whapper motor
                            • DaBitundefined
                              DaBit
                              So, basically, at 180 steps or so the actual vs demanded position deviation of the last motor is more than half a step with the others close to that, with zero load?
                              That is way worse than what I would have expected...
                              • fcwiltundefined
                                fcwilt @arhi
                                That's funny.
                                A while back I purchased such a system for testing but the project got put on hold as other more important things needed to be done.
                                And now I cannot find it.
                                • arhiundefined
                                  arhi
                                  • arhiundefined
                                    arhi @DaBit
                                    @DaBit said in stepper precision:
                                    will have to spend more time looking at all this data, so far I'm running the tests and just showing the error of going forward than backwards. The other data I'm interested is spread of steps going in one direction only, how much off each step is from ideal position but I will do those graphs after I finish all the tests as I need to return this encoder in few days
                                    • arhiundefined
                                      arhi @fcwilt
                                      so you understand my frustration 😞
                                      I'm not used to everything being "in order" and everything "having it's place" but I hate working from "storage", can't find anything, $@^%#^ is getting on my nerves and breaks my concentration too .. and I don't see the end, I doubt my house will be ready before summer 😞
                                      • arhiundefined
                                        arhi
                                        second DPM motor
                                        • fcwiltundefined
                                          fcwilt @arhi
                                          @arhi
                                          I found the box with the stepper/encoder and controller!
                                          Now I just need to find the time - still looking for that.
                                          • arhiundefined
                                            arhi @fcwilt
                                            @fcwilt 🙂
