    G30 S-1 is giving me heart stitches [SOLVED]
    4.6k
    • Vetiundefined
      Veti @o_lampe
      @o_lampe said in G30 S-1 is giving me heart stitches:
      Now, when I home Z, the homed height is set to -2 or whatever I set in M208.
      post you home script
      • fcwiltundefined
        fcwilt
        M574 X Y S3 - where are the values for X and Y specify the location of the end stop?
        You have specified the Z trigger height in G31 as 0. Usually a capacitive probe triggers a few mm off the surface.
        Also capacitive probes can be slow to respond so you might need to change the F value in M558.
        When you home any axis the position is set to the axis min/max based on the axis parameter in M574.
        You have specified that the end stop of Z is at the low end so it gets set to Z min which you have as -2.
        Why do you have Z min as -2?
        • o_lampeundefined
          o_lampe @Veti
          @Veti said in G30 S-1 is giving me heart stitches:
          G91
          G29 S2
          G1 S1 Z-300 F800
          G1  Z5 F800
          G1 S1 Z-10
          ;G92  Z0.0
          G90
          ;G29 S1
          What does it mean, when DWC is giving me a warning about Z=0 datum isn't set everytime i load the heightmap?
          Is it trying to do that, when it crashes against the leadscrew?
          I've made two short videos to show what happens, but I'm not sure when I find the nerve to upload them to u-tube.
          • Vetiundefined
            Veti
            that is not a home script. as it disregards any endstop
            nevermind. it used the old S syntax.
            that is the reason why its set to S-1
            when the endstop is triggered the axis is set to the endstop position.
            with a G30 this will not happen as this sets the current positon to z=0
            that would also get rid of the Z=0 datum message.
            o_lampeundefined 2 Replies Last reply Reply Quote 0
            • o_lampeundefined
              o_lampe @Veti
              @Veti
              To be clear, it uses the Z-probe as endstop.
              • Vetiundefined
                Veti
                that is wrong.
                try a default homez.
                ; homez.g
                ; called to home the Z axis
                ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 20 2021 13:31:39 GMT+0100 (Central European Standard Time)
                G91 ; relative positioning
                G90 ; absolute positioning
                G1 X15 Y15 F6000 ; go to first probe point
                ;G91 ; relative positioning
                ;G90 ; absolute positioning
                • o_lampeundefined
                  o_lampe @Veti
                  So, I should use G30 instead of G1 S1?
                  • Vetiundefined
                    Veti @o_lampe
                    @o_lampe
                    yes
                    you REALLY need to use a standard config that is generated by the config tool.
                    • o_lampeundefined
                      o_lampe @Veti
                      @o_lampe
                      yes
                      I started filling out the config wizard, but then got stuck with the stepper settings. I would have to copy my existing config settings into the wizard, so what is it good for?
                      I'd just copy any possible mistake into the new file, if there's any...
                      • Vetiundefined
                        Veti @o_lampe
                        @o_lampe
                        well it would have generated a correct homing script for once.
                        and as i said it will make the migration to version 3 easier
                        • o_lampeundefined
                          o_lampe
                          The head moves to that first probe point and then throws an error insufficient axes homed
                          As always I homed X/Y before homeZ with G92 X0 Y0.
                          Do I really have to install endstops for X/Y axis?
                          I never needed them for my CNC. I just parked the toolhead at 0,0 before I switched off and went the G92 way to start...
                          I checked the homeX/Y files. They all look similar to the one I originally posted. (I had this SD-card backup from my CNC machine)
                          • Vetiundefined
                            Veti
                            the G30 command give you insufficient axis homed?
                            • fcwiltundefined
                              fcwilt @o_lampe
                              The would work IF the actual positions of X and Y were zero. How do you know they are?
                              No - you can use sensor-less homing.
                              I don't care for that myself. To me using physical end stop sensors for homing is like stopping your car using the brakes. Sensor-less homing seems like stopping your car by running into the car in front of you. 😉
                              As to using G30: did you read the docs on what each variant of G30 does?
                              o_lampeundefined 1 Reply Last reply Reply Quote 1
                              • o_lampeundefined
                                o_lampe @Veti
                                No, the macro doesn't run G30 because of the error message.
                                I used jumpers on X/Y endstops and defined them as active high
                                When I ask M119 it reports X/Y at min endstops. Now I should be able to use the homeall macro. But it stops after the same line as above mentioned.
                                • Vetiundefined
                                  Veti
                                  post your homeall then
                                  • o_lampeundefined
                                    o_lampe @fcwilt
                                    @fcwilt said in G30 S-1 is giving me heart stitches:
                                    Yes, and I also tried some other versions with various Px and Sx parameters.
                                    • o_lampeundefined
                                      o_lampe @Veti
                                      ; homeall file for use with dc42 Duet firmware on CoreXY printers
                                      ; This file assumes the endstop switches are at the low end of each axis.
                                      ; Reverse the X and Y movement for high-end switches.
                                      ; Adjust the bed upper and lower limits in config.g (M208 commands) to get the correct homing positions
                                      G91                       ; relative mode
                                      G1 F2400 		   		; course home X or Y //S1 X-340 Y-240
                                      G1 S1 X-340               ; course home X
                                      G1 S1 Y-240               ; course home Y
                                      G1 X14 Y14 F600             ; move away from the endstops
                                      G1 S1 X-20                ; fine home X
                                      G1 S1 Y-20                ; fine home Y
                                      G1 X20 Y20 F4000
                                      G1 F600
                                      G1 S1 Z-300 F600
                                      G1 Z5 F200
                                      G30
                                      ; If you are using a microswitch for Z homing, insert similar code for the Z axis here,
                                      ; but use lower feed rates suitable for your Z axis.
                                      G90                       ; back to absolute mode
                                      ; If you homed the Z axis using an endstop switch, you can insert a G92 command here to correct the height.
                                      • Vetiundefined
                                        Veti
                                        what script wont work without endstops
                                        • o_lampeundefined
                                          o_lampe
                                          with the homeall script the behaviour is a bit different: it runs to 20,20 then probes (G1 S1) and runs against the rear beam.
                                          Whenever G30 is issued,the printer freaks out.
                                          • o_lampeundefined
                                            o_lampe @Veti
                                            @Veti
                                            that was just my interpretation why homeZ doesn't work even after I homed X/Y
                                            Seems the fake endstops doesn't change anything
