    G30 S-1 is giving me heart stitches [SOLVED]
    4.4k
    • Vetiundefined
      Veti
      that is not a home script. as it disregards any endstop
      nevermind. it used the old S syntax.
      that is the reason why its set to S-1
      when the endstop is triggered the axis is set to the endstop position.
      with a G30 this will not happen as this sets the current positon to z=0
      that would also get rid of the Z=0 datum message.
      o_lampeundefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @Veti
        @Veti
        To be clear, it uses the Z-probe as endstop.
        • Vetiundefined
          Veti
          that is wrong.
          try a default homez.
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 20 2021 13:31:39 GMT+0100 (Central European Standard Time)
          G91 ; relative positioning
          G90 ; absolute positioning
          G1 X15 Y15 F6000 ; go to first probe point
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
          • o_lampeundefined
            o_lampe @Veti
            @Veti said in G30 S-1 is giving me heart stitches:
            So, I should use G30 instead of G1 S1?
            • Vetiundefined
              Veti @o_lampe
              @o_lampe
              yes
              you REALLY need to use a standard config that is generated by the config tool.
              • o_lampeundefined
                o_lampe @Veti
                @o_lampe
                yes
                I started filling out the config wizard, but then got stuck with the stepper settings. I would have to copy my existing config settings into the wizard, so what is it good for?
                I'd just copy any possible mistake into the new file, if there's any...
                • Vetiundefined
                  Veti @o_lampe
                  @o_lampe
                  well it would have generated a correct homing script for once.
                  and as i said it will make the migration to version 3 easier
                  • o_lampeundefined
                    o_lampe
                    The head moves to that first probe point and then throws an error insufficient axes homed
                    As always I homed X/Y before homeZ with G92 X0 Y0.
                    Do I really have to install endstops for X/Y axis?
                    I never needed them for my CNC. I just parked the toolhead at 0,0 before I switched off and went the G92 way to start...
                    I checked the homeX/Y files. They all look similar to the one I originally posted. (I had this SD-card backup from my CNC machine)
                    • Vetiundefined
                      Veti
                      the G30 command give you insufficient axis homed?
                      • fcwiltundefined
                        fcwilt @o_lampe
                        @o_lampe said in G30 S-1 is giving me heart stitches:
                        The would work IF the actual positions of X and Y were zero. How do you know they are?
                        No - you can use sensor-less homing.
                        I don't care for that myself. To me using physical end stop sensors for homing is like stopping your car using the brakes. Sensor-less homing seems like stopping your car by running into the car in front of you. 😉
                        As to using G30: did you read the docs on what each variant of G30 does?
                        o_lampeundefined 1 Reply Last reply Reply Quote 1
                        • o_lampeundefined
                          o_lampe @Veti
                          No, the macro doesn't run G30 because of the error message.
                          I used jumpers on X/Y endstops and defined them as active high
                          When I ask M119 it reports X/Y at min endstops. Now I should be able to use the homeall macro. But it stops after the same line as above mentioned.
                          • Vetiundefined
                            Veti
                            post your homeall then
                            • o_lampeundefined
                              o_lampe @fcwilt
                              @fcwilt said in G30 S-1 is giving me heart stitches:
                              Yes, and I also tried some other versions with various Px and Sx parameters.
                              • o_lampeundefined
                                o_lampe @Veti
                                ; homeall file for use with dc42 Duet firmware on CoreXY printers
                                ; This file assumes the endstop switches are at the low end of each axis.
                                ; Reverse the X and Y movement for high-end switches.
                                ; Adjust the bed upper and lower limits in config.g (M208 commands) to get the correct homing positions
                                G91                       ; relative mode
                                G1 F2400 		   		; course home X or Y //S1 X-340 Y-240
                                G1 S1 X-340               ; course home X
                                G1 S1 Y-240               ; course home Y
                                G1 X14 Y14 F600             ; move away from the endstops
                                G1 S1 X-20                ; fine home X
                                G1 S1 Y-20                ; fine home Y
                                G1 X20 Y20 F4000
                                G1 F600
                                G1 S1 Z-300 F600
                                G1 Z5 F200
                                G30
                                ; If you are using a microswitch for Z homing, insert similar code for the Z axis here,
                                ; but use lower feed rates suitable for your Z axis.
                                G90                       ; back to absolute mode
                                ; If you homed the Z axis using an endstop switch, you can insert a G92 command here to correct the height.
                                • Vetiundefined
                                  Veti
                                  what script wont work without endstops
                                  • o_lampeundefined
                                    o_lampe
                                    with the homeall script the behaviour is a bit different: it runs to 20,20 then probes (G1 S1) and runs against the rear beam.
                                    Whenever G30 is issued,the printer freaks out.
                                    • o_lampeundefined
                                      o_lampe @Veti
                                      @Veti
                                      that was just my interpretation why homeZ doesn't work even after I homed X/Y
                                      Seems the fake endstops doesn't change anything
                                      • Vetiundefined
                                        Veti
                                        if you dont want to use endstops, you should just setup sensorless homing
                                        https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
                                        • fcwiltundefined
                                          fcwilt @o_lampe
                                          Do you understand what a G1 command with the S1 (now H1) parameter does?
                                          If you have the X and Y end stops forced active your homeall.g script will not work.
                                          If you wish to use the Z probe for homing you don't use any G1 S1 Znnn command - just G30 BUT you likely want to use a G1 Xnnn Ynnn command to move to the center of the bed first.
                                          You also need to have M574 Z0 and a valid Z probe configuration - which you appear to have.
                                          If you aren't going to have actual end stops and are not going to use sensor-less homing you can force any axis to be "homed" with G92 Xnnn (or Y) but naturally the value nnn should be where the axis is actually positioned at the time.
                                          I suggest you just install actual end stop sensors.
                                            Phaedrux Moderator @o_lampe
                                            Can you send M98 P"config.g" in the console to check for some syntax error messages that are normally lost in startup?
                                            M584 X0 Y1 Z2 E3 ; drive mapping
                                            The M584 should come earlier than any of the commands that reference the axis that it creates. I think the only reason it's worked so far is that you're using default mappings, but still weird things can happen.
                                            Copying your values into the config generator won't duplicate any of the syntax errors that may be there. I really suggest you try generating a fresh set even just to see what it looks like to compare to yours. And yes it will make switching over to RRF3 much easier.
