    Haq XY
    Firmware developers
    15.3k
    • Haggan90undefined
      Haggan90 @RootCNC
      @RootCNC Hi,
      Sure I can share how to set it up.
      But I'm having a hard time understanding how you route your belts to make it a Haq-XY kinematics?
      RootCNCundefined 1 Reply Last reply Reply Quote 0
      • RootCNCundefined
        RootCNC @Haggan90
        @Haggan90
        Ah sorry about that - Please see this photo.
        I currently have two motors driving the Y axis - these shall be configured in a series configuration.
        then two independent carriages driven from independent steppers.
        Does that help?
        Thanks 🙂
        Haggan90undefined 1 Reply Last reply Reply Quote 0
        • Haggan90undefined
          Haggan90 @RootCNC
          @RootCNC Aha I see!
          I routed my 2 X belts on the same route but at different heights instead 😃
          And I used one stepper for the Y axis but with a rod connecting both sides of the Y axis.
          But the kinematics are exactly the same.
          Btw, are you stepper mounted in the bottom with rods going to the top?
          • RootCNCundefined
            RootCNC @Haggan90
            @Haggan90
            Yeah, to keep its low profile and symmetrical I went this way with the belts.
            I plan in the future to try a heated chamber, so keeping the motors below the 6mm plate seemed a good idea.
            I just purchased my Duet 3 and LCD, hopefully it'll turn up soon and then we can get this printer moving!
            Was the setup difficult?
            • MaxGyverundefined
              MaxGyver @Haggan90
              @Haggan90 said in Haq XY:
              @dc42 I just reversed the Y motor and when I do G1 X10 F1000 S2 the Y axis moves in the right direction (+10).
              But I've noticed a new thing when homing.
              This is my homeall.g now:
              G91 				; relative positioning
              G1 Z5 F6000 S2 			; lift Z relative to current position
              G1 S1 Y550 U540 X-540 F2500 	; move quickly to Y axis endstops and stop there (first pass)
              G1 S1 Y550 F2500		; Home Y seperate
              G1 S1 X-540 F2500		; Home X seperate
              G1 S1 U540 F2500		; Home U seperate
              G1 Y-5 X5 U-5 F2000		; Go back 5mm on all axis
              G1 S1 Y550 F600			; slowly home Y
              G1 S1 X-100 F600		; Slowly home X
              G1 S1 U100 F600			; Slowly home U
              G90				; absolute positioning
              G1 X300 Y310 F2500        	; go to first bed probe point and home Z
              G30                     	; home Z by probing the bed
              G1 S2 Z5 F100          		; lift Z relative to current position
              But when it comes to G1 X300 Y310 F2500 the X axis just smashes into it's endstop.
              It seems like both U and X looses their position somehow, or that X and U switches...so X becomes U and U becomes X.
              If I manually home Y first and then try to home X the U axis moves.
              If I manually home U and X first, their postion is X0 U550.
              If I then home Y manually X position is X1100.3 and U is U-560.
              Does this make any sense at all?
              I am still having this bug, even after updating from the latest beta to 3.2 stable.
              When I home one axis, the other two lose their position. Although I think the correct axis are moving when they are homing.
              Visionaryundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • Visionaryundefined
                Visionary @MaxGyver
                @MaxGyver
                I had problem where when doing homing U and X axes lost position during all axis homing. Those axes moved against endstops and lost steps/belt skipped.
                This was because homeall.g included wrong move type: 1 motor move -type move (H2-command)
                I switched it to H0. I think that you are also suppose to use H-command instead of S-commands.
                check: https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move
                My corrected homeall.g
                ; Haq xy homing, U and X axes concurrently, Y axis after that and Z axis last
                G91
                G1 H2 Z7 F200 					; raise head 7mm to keep it clear of the bed
                G1 H1 X-405 U405 F3000 			 ; coarse home X and U
                G1 H2 X5 U-5 F600              ; move 4mm away from the homing switches
                G1 H1 X-10 U10 F600           			; fine home X and U
                G1 H1 Y-420 F2000
                G1 H0 Y5 F600
                G1 H0 Y-5.5 F600
                G1 H1 Z-380 F360                ; move Z down stopping at the endstop
                G90
                Main printer: 3-5 Axis, 400x400x450 Duet 6HC || https://grabcad.com/eetu-4/models
                MaxGyverundefined 1 Reply Last reply Reply Quote 0
                • MaxGyverundefined
                  MaxGyver @Visionary
                  @Visionary
                  Would you do me a favour and post your config file? I think with my setup there is more wrong than just the homing file. 😬
                  -Cheers
                  Max
                  Visionaryundefined 1 Reply Last reply Reply Quote 0
                    dc42 administrators @MaxGyver
                    @MaxGyver said in Haq XY:
                    That will have changed the direction of X axis movement too.
                    • RootCNCundefined
                      RootCNC
                      Hey everyone,
                      last night I got my HAQ XY or markforged IDEX printer moving and homing correctly last night.
                      you can see it moving here: https://fb.watch/38agipCwQx/
                      Here is my config, once you get your head around the matrix manipulation it was easy to ensure it was moving in the correct direction.
                      The magic happens on M669 command....
                      ; generated by RepRapFirmware Configuration Tool v3.2.2 on Tue Jan 19 2021 18:42:53 GMT+0000 (Greenwich Mean Time)
                      G90                                     ; send absolute coordinates...
                      M83                                     ; ...but relative extruder moves
                      M550 P"Duet3"                          ; set printer name
                      M569 P0.0 S0                            ; (Y)  physical drive 0.0 goes forwards
                      M569 P0.1 S0                            ; (X1) physical drive 0.1 goes forwards
                      M569 P0.2 S1                            ; (X2) physical drive 0.2 goes forwards
                      M569 P0.3 S1                            ; (Z)  physical drive 0.3 goes forwards
                      M569 P0.4 S1                            ; (E1) physical drive 0.4 goes forwards
                      M584 X0.1 U0.2 Y0.0 Z0.3 E0.4           ; set drive mapping
                      M350 X64 U64 Y64 Z64 E16 I1                 ; configure microstepping with interpolation
                      M669 K1 X1:0:0:0 Y1:-1:0:1 Z0:0:1:0 U0:0:0:1; Matrix mapping for Axis - X:Y:Z:U
                      M92 X400.00 U400.00 Y400.00 Z1600.00 E420.00    ; set steps per mm
                      M566 X900.00 U900.00 Y900.00 Z180.00 E120.00    ; set maximum instantaneous speed changes (mm/min)
                      M203 X6000.00 U6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                      M201 X500.00 U500.00 Y500.00 Z20.00 E250.00     ; set accelerations (mm/s^2)
                      M906 X1200 U1200 Y1200 Z1200 E800 I30         ; set motor currents (mA) and motor idle factor in per cent
                      M84 S30                                 ; Set idle timeout
                      M208 X-45 U45 Y0 Z0 S1                        ; set axis minima
                      M208 X220 U310 Y215 Z200 S0                  ; set axis maxima
                      M574 X1 S3                              ; configure sensorless endstop for low end on X
                      M574 Y1 S3                              ; configure sensorless endstop for low end on Y
                      M574 Z1 S3                              ; configure sensorless endstop for low end on Z
                      M574 U2 S3                              ; configure sensorless endstop for high end on U
                      M915 X U Y Z R0 F0						; Configure motor stall detection
                      M558 P0 H5 F120 T6000                   ; disable Z probe but set dive height, probe speed and travel speed
                      M557 X15:215 Y15:195 S20                ; define mesh grid
                      M950 F0 C"out8" Q500                    ; create fan 0 on pin out8 and set its frequency
                      M106 P0 S0 H-1                          ; set fan 0 value. Thermostatic control is turned off
                      M950 F1 C"out9" Q500                    ; create fan 1 on pin out9 and set its frequency
                      M106 P1 S1 H-1                          ; set fan 1 value. Thermostatic control is turned off
                      M563 P0 D0 F0                           ; define tool 0
                      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
                      G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
                      M575 P1 S1 B57600                       ; enable support for PanelDue
                      Homing wise:
                      here is an example of my homing script (the standard IDEX setup guild is very good)
                      ; homex.g
                      ; called to home the X axis
                      M400
                      M913 X50 U50 Y50 ; drop motor current to 70%
                      M400
                      G91; relative positioning
                      ;G1 H2 Z10 F12000 ; lift Z relative to current position
                      G1 H1 X-320.5 F10000 ; move quickly to X axis endstop and stop there (first pass)
                      G1 H2 X5 F12000 ; go back a few mm
                      G1 H1 X-320.5 F7000 ; move slowly to X axis endstop once more (second pass)
                      ;G1 H2 Z-10 F6000 ; lower Z again
                      M400
                      M913 X100 U100 Y100 ; return current to 100%
                      M400
                      Please note I'm doing sensorless homing
                        dc42 administrators @dc42
                        @dc42 said in Haq XY:
                        I'm sorry, that would have been correct for CoreXY kinematics, not MarkForged kinematics. HaqXY is dual MarkForged.
                          Visionary @MaxGyver
                          @MaxGyver
                          Note that I'am too trying to get my printer working correctly. I have some problems for example with tool offsets. Please make sure that any parameters you take from it are correct for your machine.
                          my config at the moment:
                          M550 P"My Printer"                                 ; set printer name
                          M669 K11 Y-1:-1:0:1
                          M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
                          M586 P0 S1                                         ; enable HTTP
                          M586 P1 S0                                         ; disable FTP
                          M586 P2 S0                                         ; disable Telnet
                          M569 P0.0 S1                              		   ; physical drive 0.0 goes forwards X
                          M569 P0.1 S1                               		   ; physical drive 0.1 goes forwards U
                          M569 P0.2 S1                                       ; physical drive 0.2 goes forwards Y
                          M569 P0.3 S1                                       ; physical drive 0.3 goes forwards Z
                          M569 P0.4 S1                                       ; physical drive 0.4 goes forwards E0
                          M569 P0.5 S1                                       ; physical drive 0.5 goes forwards E1
                          M584 X0.1 U0.0 Y0.2 Z0.3 E0.4:0.5                          	; set drive mapping
                          M350 X16 U16 Y16 Z16 E16:16 I1                              ; configure microstepping without interpolation
                          M92 X80.00 U80.00 Y80.00 Z640.00 E2700:208          		; set steps per mm
                          M566 X600.00 U600.00 Y600.00 Z60.00 E40.00:300              ; set maximum instantaneous speed changes (mm/min)
                          M203 X12000.00 U12000.00 Y12000.00 Z180.00 E1800.00:1000          ; set maximum speeds (mm/min)
                          M201 X1000.00 U1000.00 Y1000.00 Z20.00 E120.00:600                ; set accelerations (mm/s^2)
                          M906 X1200 U1200 Y1000 Z1000 E980:980 I45                    	; set motor currents (mA) and motor idle factor in per cent
                          M569 P0.0 V25 H25 D3
                          M569 P0.1 V25 H25 D3
                          M569 P0.2 V25 H25 D3
                          M915 P0.0 S3 R0 H134 T25 F1
                          M915 P0.1 S3 R0 H134 T25 F1
                          M915 P0.2 S3 R0 H134 T25 F1
                          M208 X-42.3 U41 Y0 Z0 S1                                   	; set axis minima
                          M208 X400 U439.6 Y400 Z375 S0                             	; set axis maxima
                          M574 X1 S1 P"!^io1.in"                             	; configure active-high endstop for low end on X via pin !^io2.in
                          M574 U2 S1 P"!^io2.in"                             	; configure active-high endstop for high end on U via pin !^io1.in
                          M574 Y1 S1 P"io5.in"                             	; configure active-high endstop for low end on Y via pin !^io3.in
                          M574 Z1 S1 P"!^io4.in"                             	; configure active-high endstop for low end on Z via pin !^io4.in
                          M308 S0 P"temp0" Y"thermistor" T100000 B3974       ; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
                          M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                            ; map heated bed to heater 0
                          M143 H0 S130                                       ; set temperature limit for heater 0 to 120C
                          M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8       ; configure sensor 1 as thermistor on pin temp2
                          M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
                          M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                          M307 H1 R2.399 C262.2 D5.02 S1 V23.8
                          M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
                          M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8       ; configure sensor 1 as thermistor on pin temp2
                          M950 H2 C"out2" T2                                 ; create nozzle heater output on out1 and map it to sensor 1
                          M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                          M307 H2 R2.125 C261.6 D5.93 S1.00 V23.8
                          M143 H2 S280                                       ; set temperature limit for heater 1 to 280C
                          M307 H0 A110 C180 D5 B1 						   ; Bed slow temperature rise
                          M950 F0 C"out7" Q500                               ; create fan 0 on pin out7 and set its frequency
                          M950 F1 C"out8" Q500                               ; create fan 1 on pin out8 and set its frequency
                          M106 P1 S0 H-1                                     ; set fan 1 value. Thermostatic control is turned off
                          ; tool 0, X-axis
                          M563 P0 D0 H1 X0 F0                                 		; define tool 0
                          G10 P0 R0 S0 X0 Y0 Z0                                    	; set tool 0 axis offsets
                          ; tool 1, U-axis
                          M563 P1 D1 H2 X3 F1
                          G10 P1 R0 S0 Y-0.1 U0 Z0                                      	; set initial tool 1 active and standby temperatures to 0C
                          T0													; select tool
                          • MaxGyverundefined
                            MaxGyver
                            @Visionary
                            I have tested multiple configurations, but the issue is persistent.
                            Every time I home Y-Axis, the distance the axis has to travel to hit the end stop minus the amount it is allowed to travel is added to X and U.
                            Example:
                            1. I set the Y-Axis at a distance of 100mm from the endstop and restart the printer to set everything to zero.
                            2. I run homey.g
                            G1 H1 Y-330 F2500	; coarse home Y
                            1. Y is now 0, X is -230 and U is at 230
                            (-230mm = 100mm distance to Endstop -330mm maximum homing distance as specified homey.g)
                            I don't know what I am missing here...
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 05 2020 11:42:30 GMT+0200 (Mitteleuropäische Sommerzeit)
                            M550 P"Duet 3"                                  ; set printer name
                            ; Chamer Fan
                            M950 F2 C"!out5" F25000
                            M106 P2 S0 B0 L0.20 X0.5 H1 T40:200
                            M80 ; Power ON
                            M669 K11 Y1:-1:0:-1
                            ;M669 K1 X1:0:0:0 Y1:-1:0:1 Z0:0:1:0 U0:0:0:-1		; Matrix mapping for Axis - X:Y:Z:U
                            M569 P0.0 S1		; Drive 0.0/Z1
                            M569 P0.1 S1		; Drive 0.1/Z2
                            M569 P0.2 S1		; Drive 0.2/Z3
                            M569 P0.3 S1		; Drive 0.3/Z4
                            M569 P0.4 S0		; Drive 0.4/Y1
                            M569 P0.5 S1		; Drive 0.5/Y2
                            M569 P1.0 S0		; Drive 1.0/X
                            M569 P1.1 S0		; Drive 1.1/U
                            M569 P1.2 S0		; Drive 1.2/E0
                            M584 Z0.0:0.1:0.2:0.3 Y0.4:0.5 X1.0 U1.1 E1.2 		; set 4 Z drivers and add one U driver -> Must come earlier than M350,M906,M92, M201, M203, M208, M350, M566, M574, M667 and M669
                            M671 X-49:498:498:-39 Y-21:-21:309:309 S10 			; lead screw positions
                            M350 U16 X16 Y16 Z16 I1    		            		; Configure microstepping with interpolation
                            M350 E16 I0 										; Configure microstepping with interpolation
                            M92 U80 X80 Y80 Z800 V2500 W2500 E455	;476.5 		; Set steps per mm
                            M203 U48000 X48000 Y48000 V1000 W1000 Z2000 E6000	; Set maximum speeds (mm/min)
                            M566 U800 X800 Y800 V50 W50 Z300 E3000          	; set maximum instantaneous speed changes (mm/min)
                            M201 U2500 X2500 Y2500 V250 W250 Z200 E3000	 		; Set accelerations (mm/s^2)
                            M906 U1500 X1500 Y1500 V1000 W1000 Z1500 E800 I30	; Set motor currents (mA) and motor idle factor in per cent
                            M84 S10                                       		; Set idle timeout
                            ;M208 U-30:400 X430:0 Y0:320 Z0:337.5 V-9999:9999 W-9999:9999	; Set axis minima:maxima
                            M208 X0 U0 Y0 Z0 S1                      ; set axis minima
                            M208 X430 U430 Y320 Z337.5 S0                  ; set axis maxima
                            ;M574 X1 U2 Y2 Z1.5 S1                          	; Set active high endstops
                            M574 X2 S1 P"io0.in"                            	; configure active-high endstop for high end on X via pin io1.in
                            M574 Y1 S1 P"io1.in"                            	; configure active-high endstop for low end on Y via pin io1.in
                            M574 U1 S1 P"io2.in"                            	; configure active-high endstop for low end on U via pin io3.in
                            M574 Z2 S1 P"io3.in"                            	; configure active-high endstop for high end on Z via pin io0.in
                            ; Servo
                            ;M950 S0 C"io4.out"
                            ;M280 P0 S0
                            ; Bed Heater
                            M308 S0 P"temp0" A"Bed" Y"thermistor" T100000 B3950 ; define bed temperature sensor
                            M950 H0 C"out8" T0                              	; create bed heater output on bed output and map it to sensor 0
                            M143 H0 S120                                    	; set temperature limit for heater 0 to 120C
                            ; Hotend1 Heater
                            M308 S1 P"temp1" A"Extruder1" Y"pt1000" 			; configure sensor 1 as PT1000 on pin temp1
                            M307 H1 A765.9 C354.3 D4.8 S1.0 V23.8 B0
                            M307 H0 A103.3 C269.6 D1.6 S1.0 V23.9 B0
                            ; Temperature Sensors
                            ;M308 S3 P"temp2" Y"pt1000"  A"Chamber"
                            M308 S2 P"temp3" Y"pt1000"  A"Chamber"
                            M950 F0 C"out7" A"Hotend Fan"			 	; create fan 0 on pin out7 and set its frequency
                            M106 P0 S1 H1 T65 L1	 		            ; set fan 0 value. Thermostatic control is turned on
                            M950 F1 C"out3" Q-1 A"Part Fan"       		; create fan 1 on pin out8 and set its frequency
                            ; MCU Fan
                            ;M308 S4 Y"drivers" 			  			; configure sensor 4 as temperature warning and overheat flags on the TMC2660 on Duet
                            M308 S4 Y"mcu-temp" A"MCU" 					; configure sensor5 as thermistor on pin e1temp for left stepper
                            M950 F4 C"out4" Q100 						; create fan 4 on out4 and set its frequency
                            M106 P4 S0 B1 H4 L0.3 X1 T40:60 			; set fan 4 value
                            M563 P0 D0 H1 F1                            ; define tool 0
                            G10 P0 X0 Y0 Z0 R0 S0
                            ; LED
                            M950 P3 C"1.out0"
                            M42 P3 S1
                            ; Air Cooler
                            M950 F5 C"out6"
                            ;M106 P5 L0.2 X1 H2 T18:20
                            M106 P5 S1 H1
                            ;Pressure Advance
                            M572 D0 S0.025 ; Extruder Drive Number, Pressure advance amount
                            ;Dynamic acceleration adjustment
                            ;M593 F50  ; cancel ringing at 40.5Hz
                            ; M911 S22 R23 P"M18 M106 P1 S0 M42 P3 S0"				; set voltage thresholds and actions to run on power loss G91 M83 G1 Z1 E-1 F1000
                            T0                                                  	; select first tool
                            M501													; set the active parameters to those stored in sys/config-override.g
                              Visionary @MaxGyver
                              @MaxGyver
                              In my HaqXY I have X-, Y- and Z-axes endstops at low end of the axes, but in your config.g you have Z- and X-axis endstops at high end. Is this on purpose? Only axis that I home to high end is U-axis.
                                That's either a firmware bug that nobody else has reported, or an incorrect matrix, or an incorrect homing file.
                                After homing both X and Y (or sending G92 X0 Y0 to pretend they are homed), do normal G1 Xxx and G1 Yyy moves with no H parameter work correctly?
                                • MaxGyverundefined
                                  MaxGyver @dc42
                                  @Visionary Yes, this is correct. I have my XUY zero at the rear right-hand side of my printer with the first extruder on the left (X-Axis) and the second on the right (U-Axis).
                                  @dc42 Yes, these moves are executed correctly. I am using this printer for quite a while now. Most of the time this issue is not a problem since I rehome all axes before starting prints or executing macros. But If I don't rehome all axis in the correct order it leads to crashes.
                                    Thans, I'll log this as a bug to be fixed in RRF 3.3.
                                      Hi @MaxGyver, I have reproduced this and tracked down two issues that are causing it:
                                      • The first issue (the main one) is that when the homing move stops, the firmware needs to retrieve the number of steps taken by the X, Y and U motors. This data is not currently available for the X and U motors because they are CAN-connected and the move has been terminated early.
                                      • The second issue is that in config.g the M584 command should precede the M669 command, so that the U axis exists when you use M669 and in consequence it builds and inverts a 4x4 matrix instead of a 3x3 matrix.
                                      I will work on a solution to the first issue.
                                      • MaxGyverundefined
                                        MaxGyver @dc42
                                        I am glad to hear that! Thank you very much for your feedback.
                                        -Max
                                        • sonderzugundefined sonderzug referenced this topic
                                        • RogerPodacterundefined RogerPodacter referenced this topic
