    stepper precision
    3D Printing General Chat
    6.4k
    • arhiundefined
      arhi
      third super whapper motor
      • DaBitundefined
        DaBit
        So, basically, at 180 steps or so the actual vs demanded position deviation of the last motor is more than half a step with the others close to that, with zero load?
        That is way worse than what I would have expected...
        • fcwiltundefined
          fcwilt @arhi
          @arhi said in stepper precision:
          Haven't got to it yet, can't find where I put my vallder stepper with encoder and driver combo. Also I wanna finish with few nema17 before I have to use another mount to test the bigger motor
          That's funny.
          A while back I purchased such a system for testing but the project got put on hold as other more important things needed to be done.
          And now I cannot find it.
          • arhiundefined
            arhi
            • arhiundefined
              arhi @DaBit
              @DaBit said in stepper precision:
              will have to spend more time looking at all this data, so far I'm running the tests and just showing the error of going forward than backwards. The other data I'm interested is spread of steps going in one direction only, how much off each step is from ideal position but I will do those graphs after I finish all the tests as I need to return this encoder in few days
              • arhiundefined
                arhi @fcwilt
                @fcwilt said in stepper precision:
                so you understand my frustration 😞
                I'm not used to everything being "in order" and everything "having it's place" but I hate working from "storage", can't find anything, $@^%#^ is getting on my nerves and breaks my concentration too .. and I don't see the end, I doubt my house will be ready before summer 😞
                • arhiundefined
                  arhi
                  second DPM motor
                  • fcwiltundefined
                    fcwilt @arhi
                    @arhi
                    I found the box with the stepper/encoder and controller!
                    Now I just need to find the time - still looking for that.
                    • arhiundefined
                      arhi @fcwilt
                      @fcwilt 🙂
                      • alankilianundefined
                        alankilian @arhi
                        @arhi Are you sure you're calibrating the controller every time?
                        It looks like going forward, you get 0.5-degree of error, but going backwards, you get MUCH LESS error. Under 0.1 degree
                        Maybe try going three turns forward and then three turns backwards just in case it take one-turn to calibrate or something.
                        • arhiundefined
                          arhi @alankilian
                          @alankilian said in stepper precision:
                          For S42B - yes, I am sure, I calibrated every time when running closed loop. I don't see a point as nothing physically changed in the setup between runs but I still run the calibration every time before I run the test as calibration is rather quick (it goes full circle one direction and then full circle other direction) ... anyhow notice these lasts graphs are with TMC2208, nothing to calibrate there
                          • arhiundefined
                            arhi
                            same motor as earlier only run again to see how "repeatable" this is (not very)
                            • arhiundefined
                              arhi
                              JK42HS48-1684-01
                              • arhiundefined
                                arhi
                                  A Former User @arhi
                                  @arhi
                                  This looks interesting!
                                  do you also think, that comparing one and the same motor once in Fullstep and once in 1/16microsteps, one session with one without microplying to 256 would also tell a bit of how much those features within the driver do contribute to the error?
                                  Great work! Keep it up!
                                  • arhiundefined
                                    arhi @A Former User
                                    @LB said in stepper precision:
                                    @arhi
                                    Well I only have 2208 and there I cannot turn on/off the 256 interpolation, I can only play with MS0 and MS1 .. so change 1/2, 1/8, 1/16 ... since I was looking at testing motors and not drivers the idea is to use single driver on all motors, introducing new driver and spi control would require a new hat with spi interface too and that all requires time 😞 ... I just managed to find the stepper with encoder but the driver is still missing for that test .. I'm now going to run this last JK42HS48-1684-01 with few more microstepping options on the 2208 before I turn this place upside down finding that driver
                                    • arhiundefined
                                      arhi
                                      the graphs (and data behind them) so far:
                                      encoder-readings.ods
                                      What's presented in these graphs so far and in this ods is
                                      move full circle forward
                                      move then full circle backwards
                                      record both positions in the array
                                      display difference of position readout as error
                                      • arhiundefined
                                        arhi
                                        • fcwiltundefined
                                          fcwilt
                                          These graphs are all very interesting (as if I understand what you are doing) but what is the real world application for this information?
                                          • arhiundefined
                                            arhi
