Solved Mini 5 (with toolboard) and leveling using X2 Motors
yes it does.
I re-installed my Duet-2 all is working again with the same bed.g file.
i have compared my Duet-2 & mini-5 config's and i can see nothing wrong with the mini-5 config
neither can i. and the probing working sometimes is not something you can configure.
@Veti said in Mini 5 (with toolboard) and leveling using X2 Motors:
Thank for the help, i will just wait and see what any of the duet team have to say , this board was a christmas gift so i will ask my uncle where he bought it
Firmware version? Can you post the results of M122?
@Phaedrux said in Mini 5 (with toolboard) and leveling using X2 Motors:
The Board is removed so the M122 will show some errors i think.
i installed the board (and toolboard) in my core-xy , which normally has a duet-3-6hc fitted and the mini-5 runs fine in there, so im not sure why it doesnt like being in my hacked up i3, and even stranger that my Duet-2 wifi runs fine when i put it back into the i3, both printers sit side by side so its not a location related issue.
i have been racking my brains with this one as it makes no sense at all.
M115:
FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-RC2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-12-24
M122
RepRapFirmware for Duet 3 Mini 5+ version 3.2-RC2 running on Duet 3 Mini5plus WiFi (standalone mode)
Used output buffers: 3 of 40 (11 max)
Static ram: 98732
Dynamic ram: 107196 of which 496 recycled
Never used RAM 38792, free system stack 140 words
Tasks: NETWORK(ready,192) HEAT(blocked,316) CanReceiv(blocked,947) CanSender(blocked,372) CanClock(blocked,360) TMC(blocked,123) MAIN(running,444) IDLE(ready,20) AIN(blocked,267)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:54 ago, cause: power up
Last software reset at 2020-12-30 22:53, reason: User, GCodes spinning, available RAM 38752, slot 2
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00451000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
Supply voltage: min 0.0, current 0.9, max 0.9, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 1: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 2: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 3: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 4: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 5: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Driver 6: position 0, ok, SG min/max not available, read errors 0, write errors 0, ifcnt 0, reads 0, writes 0, timeouts 0, DMA errors 0
Date/time: 2021-01-01 15:00:52
Cache data hit count 222524317
Slowest loop: 5.31ms; fastest: 0.11ms
=== Storage ===
Free file entries: 10
SD card longest read time 4.2ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Bed heaters = 0 -1, chamberHeaters = -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 10.70ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25beta0
WiFi MAC address f4:cf:a2:6f:bd:af
WiFi Vcc 3.37, reset reason Power up
WiFi flash size 2097152, free heap 25264
WiFi IP address 192.168.0.115
WiFi signal strength -57dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
=== CAN ===
Messages queued 1015, send timeouts 1012, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
- WiFi -
@JayJay said in Mini 5 (with toolboard) and leveling using X2 Motors:
That is confusing. An intermittent short in something connected?
its the exact same wiring between the mini-5 and the Duet-2 and i thought about that and have been probing for shorts and found nothing
Some thoughts:
- Is the tool board definitely running 3.2RC2 as well?
- Try adding a settling delay parameter (R) to the M558 command, e.g. R0.2 or R0.5
- You said the probe doesn't register as triggered, yet you don't get a head crash. That means either the dive height is too low to probe deep enough, or the probe trigger is being registered for the purpose of stopping the Z move but not for the purpose of recording the stop height. So try increasing the dive height - very carefully!
Well I finally fixed it....
My homeall.g had G30 S-3 in the script.
I removed that and changed it to single G30 command on its own and now it completes the G32 action with no errors, I dont know why it works fine on my Duet-2 with the S-3 switch in my homeall but the mini 5 doesnt like it
Perhaps your Duet 2 is running old firmware that doesn't support the S3 parameter?
@dc42 said in Mini 5 (with toolboard) and leveling using X2 Motors:
The Duet-2 was/is on Release 3.2-RC1
And to confirm
Duet-2 WOULD complete the action with G30 S-3
Duet-3 Mini-5+ WOULD NOT complete the action G30 S-3
The Mini-5+ would only complete after i removed the S-3 switch
