    BL-Touch blinking after retract?
    1.5k
    • Chrissundefined
      Chriss @Veti
      @Veti
      I had a ir-probe on my CR-10 pro v2 with a PEI sheet and I was unable to get reliable results. I gave up there after to many crashes of the nozzle to the bed.
      The results on my CoreXY with a bright PrintBite+ where also not very reliable. I lost on one of them the IR-Diode, whether by temperature or by a crash. One simply died for "whatever" reason.
      So I simply gave up, I will give them a next chance sometime in the future but I'm done with them for now.
      Cheers, Chriss
      • Vetiundefined
        Veti
        sorry i mean to post a link
        https://www.thingiverse.com/thing:3303618
        Chrissundefined 1 Reply Last reply Reply Quote 0
        • Chrissundefined
          Chriss @Veti
          @Veti
          Or V2: https://www.thingiverse.com/thing:3756428
          That is basically a home made bl-touch if I understand both correctly.
          Well, is that technically a better solution? I do not see any benefits here when I compare it with the BL-Touch.
          Cheers, Chriss
          Vetiundefined JadonMundefined 2 Replies Last reply Reply Quote 0
          • Vetiundefined
            Veti @Chriss
            @Chriss
            it has the advantage that if the pin does not drop, probing will fail.
            the bltouch will ram into the bed.
            its very accurate.
            not susceptible to interference.
            price
            • fcwiltundefined
              fcwilt @Veti
              @Veti said in BL-Touch blinking after retract?:
              @Chriss
              its very accurate.
              price
              I wish somebody had this ready to buy - I would like to try one.
              • Chrissundefined
                Chriss @Veti
                but if it is working now..
                The problem is back... 😞 I think that I need to find a real solution now. Screw?
                I think that it must be flush with the top end of the device if my memory is correct here.
                Cheers, Chriss
                  If the probe is overwise working you could add the commands to reset errors and retract the pin to the end of config.g and the start of your homing files so that the probe is prepared to be used.
                  • Stephen6309undefined
                    Stephen6309 @Chriss
                    @Chriss Have you updated the boot loader for the 1LC?
                    https://github.com/Duet3D/Duet3Bootloader/releases
                    Chrissundefined 1 Reply Last reply Reply Quote 1
                    • JadonMundefined
                      JadonM @Chriss
                      @Chriss said in BL-Touch blinking after retract?:
                      I have both a genuine BLTouch 3.1 and this on a few of my production printers, which run almost all day most days. Believe it or not, the homemade version is faster, more accurate, and has not caused a single inconvenience. Not once in the almost-year that I've used it have I had to tinker with it or worry about it. It just works!
                      I wish I could say the same about my BLTouch! 😃
                      • Chrissundefined
                        Chriss @Stephen6309
                        @Stephen6309 said in BL-Touch blinking after retract?:
                        Not yet.... Can that really make a difference? At the end is the bootloader only loading the firmware... well, I will give it a try.
                        @Phaedrux Yes, the probe seams to work correctly. The probe is at duty since 3 days and I still work on the hardware. So there is not sooo much to say about the long term experience with that one.
                        I will update the bootloader and I change the tiny bugger with the one in my CR10 with a duet2, just to know which device is the source.
                        So it seems that this is not a soooo comon problem. 😞
                        Cheers, Chriss
                        • Chrissundefined
                          Chriss @Chriss
                          @Phaedrux
                          It seams that the problem is solved now. I upgraded the bootloader of the toolboard to 2.2. I do not understand how that should have influence here but I'm not a embedded device programmer.
                          To my future me:
                          Firmware Update howto:
                          https://duet3d.dozuki.com/Wiki/Updating_the_bootloader_on_Duet_3_expansion_and_tool_boards
                          Cheers, Chriss
                          • Vetiundefined
                            Veti
                            there was a bug that debug information was written to the pwm pin during the bootloader process. this causes problems with bltouch.
                            • Chrissundefined
                              Chriss @Veti
                              @Veti Good to know. 🙂
                              It is a much better solution to fix that than try to work around. The trick with the resets produced a lot of other problems. That seemed to me like a endless process. Anyway, happy now. I'm so happy that I can start with the fist first tests with hot filament. 🙂
