    Changing fan out from out9 to out5 has no effect
    707
    • Snippyundefined
      Snippy
      In the default setting so fans are running at 12v
      The fan im trying to run at Out5 is two https://www.digikey.fi/product-detail/en/109BC12GC7-1/1688-1035-ND/6191751?utm_medium=email&utm_source=oce&utm_campaign=3480_OCE21RT&utm_content=productdetail_FI&utm_cid=1663675&so=67660528&mkt_tok=eyJpIjoiWVdZNVptWmtPRFl4WW1FNCIsInQiOiJZcTZHWWQzZVcwc1RiNncrdnVIbTFnZlZ5WXNENmFKYXoyeWJpSXl4Rlg5TnJyVmtwTkVsVGQ3bzhvb0k5YzZseWdJNkpVcnJ5bFYybGl3SGRSaUR0M2c3MmJtRmZhd1crY1BXcEJJaENwSHZHWVFOUnZtM3F0b2FNaVwvQVZBZmYifQ%3D%3D
      Cant set Out5 to be the print cooling fan header
      • Snippyundefined
        Snippy @alankilian
        @alankilian wires 2-3mm of the connector housing are covered in a black nylon sock that has a glue, so taking pictures is pointless, its just a back wire, to elaborate its red 12v, back gnd and yellow tach, a9848d59-0948-4e3a-8291-3db7396b9ad4-kuva.png
        1=gnd so black
        2=12v
        3=tach
        4=not connected
        near the hot end with duppont connectors the 2nd fan has no tach connected.
        • Vetiundefined
          Veti @Snippy
          @Snippy said in Changing fan out from out9 to out5 has no effect:
          1=gnd so black
          2=12v
          3=tach
          4=not connected
          if you have connected the fan like that, no wonder its not working
          Snippyundefined 1 Reply Last reply Reply Quote 0
          • alankilianundefined
            alankilian
            OK, from the Wiki: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Wiring_Diagram
            "4-pin KK connectors with offset spigot OUT_4 thru OUT_6: these are intended for PWM-controllable fans. The connector fits a standard PC-type 4-pin PWM fan. Alternatively, a 2-pin fan may be connected between the V_OULCn pin (+ve) and the OUT_n_NEG pin (-ve). "
            It looks like you should be able to start with two wires connected to your fan going to (BLACK)-> OUT5 and (RED) to V_OUTLC1
            Is that how you have it connected?
            It seems like you <may> have the fan connected to +12 and GND which will make it run all the time.
            I've never used a DUET3 (I have a DUET2) so I may be mistaken here, but this gets a lot of people, so hopefully you've done the same thing others have.
            • Vetiundefined
              Veti
              well he said his wiring is not the problem, so
              alankilianundefined 1 Reply Last reply Reply Quote -1
              • Snippyundefined
                Snippy @Veti
                @Veti Well it is spinning fine, i just cant controll it in webcontroll.
                • Vetiundefined
                  Veti @Snippy
                  yes that is because of your wiring
                    alankilian @Veti
                    @Veti said in Changing fan out from out9 to out5 has no effect:
                    We all assume we know which part of our work is correct, so let's try to remain helpful.
                    Because LORD KNOWS I've been wrong so many times on forums where I'm asking for help I should get spanked.
                    • Vetiundefined
                      Veti
                      that is why i asked for a picture so i can be sure that his wiring is incorrect
                        alankilian
                        @alankilian said in Changing fan out from out9 to out5 has no effect:
                        @Snippy
                        Try this and see if it works for you.
                        • Snippyundefined
                          Snippy @alankilian
                          @alankilian Still running at 100% cant controll it from webcontroll.
                          • Snippyundefined
                            Snippy
                            And i cant run it from Out7-9 since fans in Out8-9 are 24v.
                            • Snippyundefined
                              Snippy @Veti
                              @Veti it is correct...
                              • Snippyundefined
                                Snippy
                                Got it to work, now the broblem is that the fans stop spinning at 70% in webcontroll, full blast at 100% and about 50% speed when set to 94% in webcontroll.
                                Vetiundefined 1 Reply Last reply Reply Quote 1
                                • Vetiundefined
                                  Veti @Snippy
                                  Got it to work,
                                  so what was wrong?
                                  try adjusting the frequency q.
                                  try 10 , 50, 5000 25000
                                  Snippyundefined 1 Reply Last reply Reply Quote 1
                                  • Snippyundefined
                                    Snippy @Veti
                                    @Veti no idea, did the old ''have you tried turning it on and off again'' for about 5 times and told the printer i will build a new one so i think the tea and bisquits chip in the duet started to listen.
                                    • Snippyundefined
                                      Snippy
                                      yes 10 was good, 1d0a835c-d1e7-4202-a4d2-cc5ca8c4c88a.jpg Now all i need to do is design and simulate the cooling pipes.
                                      • Snippyundefined
                                        Snippy
                                        Thanks for the help.
                                          alankilian @Snippy
                                          I'm glad you got it worked out.
                                          • Snippyundefined
                                            Snippy
                                            These duet boards are great if you dont haveto touch the settings, it seems to allways open a can of worms that requires a sacrifice or two to appease the great one.
